What is the reason the braking surface of a disc has so many holes?
Quoted: 1002 Post(s)
Liked 237 Times
How thick are bicycle discs?
If we assume that the holes are circular, for the surface area of a drilled disc to be larger than that of a solid disc, the following would need to be true:
surface area of exposed material due to hole > surface area of the material that would be there if there was no hole
2*pi*r*th > 2*pi*r*r
th > r
Is that usually the case? What am I doing wrong?
th > r
Whoever said that the drilled rotors have a larger surface area was wrong. It's a smaller surface area.
But that still helps with heat
First off less surface area rubbing on the brake pad means less friction overall and less heat generated in the first place. Since the smaller surface area is still plenty enough to stop the bike quickly and thus doesn't dramatically increase the amount of time friction is applied to the rotor, the drilled rotors build up less heat in the first place.
Heat does disperse more from an irregular surface than from a flat one though. But the holes aren't adding much to that. The wavy edge around the outside of the rotor does more for heat disbursement than the holes buy giving the edge flowing into the wind more surface area than it would have if it was a true circle. But even then I'd imagine that's immeasurably minimal and more for aesthetics.
The holes' bigger purpose is to give dirt a place to escape rather than be stuck in the pad like a wedge.
Liked 237 Times
How do those guys at Moto GP manage to not die while using discs without holes all over them?
Behind the brakes: stopping power in MotoGP? | MotoGP?
Bicycle brake rotors are a cut piece of sheet metal. Motorcycle racing rotors are a finely crafted piece of precision machinery made of metals that are designed to dissipate heat better.
There is also the 100+mph wind buzzing past the motorcycle brake rotor that helps keep it cool. The 10mph wins on a bicycle isn't doing much.
Most importantly...brakes? I thought the point of racing bikes was to win, not slow down and look cool blasting 'Low Rider'. Get off the brakes and hit the throttle!
Quoted: 18318 Post(s)
Liked 15,261 Times
th > r
th > r
Liked 15,261 Times
On this topic, google works just fine.
My point is that many questions have already been asked and answered about a thousand times. And I wouldn't go with this response if the OP didn't already have a history of this sort of thing.
We're talking about an OP who recently started a thread asking for advice on how to take a crap in the woods...Apparently he keeps falling into his own s**t:
https://www.bikeforums.net/general-c...se-forest.html
LOL.... Enough said...
Bikes: Shmikes
Quoted: 10101 Post(s)
Liked 5,781 Times
You're all wrong. It's to reduce windage in crosswinds. Safety first.
Quoted: 6881 Post(s)
Liked 10,869 Times
Originally Posted by KoyoteJust a question: if you think the question was stupid and beneath you (which seems a reasonable conclusion from your smartass response), then why did you bother looking up the info for me? You could have just moved on. Or do you enjoy acting this way?
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,094 Times
Tragically Ignorant
Liked 9,094 Times
Generally bewildered
Quoted: 1152 Post(s)
Liked 340 Times
th > r
th > r
Heat transfer rate = h * Area * (Rotor Temperature - Air Temperature).
The accurate set of equations are way too much for a forum post. But this equation can be used to understand the issue. The heat transfer coefficient h is affected by the flow of air over the rotor, and I suspect that the holes increase turbulence and hence increase h more than they decrease surface area.
Blue Collar Cyclist
Bikes: Motobecane Gravel X1, Iron Horse Maverick 1.0
Quoted: 43 Post(s)
Liked 21 Times
Formula 1 and Airliners also use Carbon Brakes. They are actually fantastic brakes, and have much more stopping power in any condition than metal.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2131 Post(s)
Liked 1,639 Times
Likes For Paul Barnard:
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
More surface area for cooling, less for braking. Not that either is likely to make a significant difference on bikes.
You're not wrong.
It's a SIGNIFICANTLY better brake rotor, for starters.
Your formula is correct (yay, math!). However, the heat transfer coefficient (call it "h") is affected, too. Here's an approximate equation:
Liked 237 Times
Assuming the rotor is 1/16th inch thick and you drill a hole that is 1/4 inch wide, the surface area lost will be exactly half of the original surface area of the lost piece.
The 1/4 inch 'hole' have a surface area of 1/10th of 1 inch (double pi r^2 since the missing hole would have 2 sides, thus doubling it's surface area)
So the rotor loses .1 square inch of surface area from the disc...but adds some back as the sides of the new hole
The new hole is .25 inches across with a dept of 1/16th inch. So the sidewall of the hole is .05 inches. (2 pi r = C, C*1/16th equals surface area of the circumference wall)
My 1/4 inch hole and 1/16th inch rotor make it exactly double. A thicker rotor would have more surface area on the new side of the hole, but would have to be 1/8th inch thick to even equal the surface area lost from the hole itself.
MATH FIGHT!!!!!
Liked 237 Times
It helps with cooling a little due to less friction on the rotor.
But the reason they do it is dirt dispersal.
On your car the brake pad is much closer to the rotor than on a bike and the car rotor is going much faster. So if debris gets in front of the brake pad it will eithe rnot be able to get under it or will be pushed all the way out due to the increased speed it went in.
On a bike a small piece of debris could lodge in between the pad and the rotor and get stuck, hindering brake performance. The holes in the rotor give that debris some place to escape.
Which is why I said all that in my first answer above....
Tragically Ignorant
Liked 9,094 Times
When spun fast enough, the holes have a small time warping capability which will make your times appear to be faster than they are. It's a holistic, quantum-gaussian effect, not really well-understood by mainstream physicists, but a fellow at the bus stop explained it to me quite convincingly so I'm sure it's right.
Liked 237 Times
They make the bike go faster.
(To anyone who gets this....high five)
Likes For Skipjacks:
Liked 2,560 Times
Drilling holes in the rotor does not give it more surface area.
MATH FIGHT!!!!!
MATH FIGHT!!!!!
Isn't one other reason for rotor holes to increase turbulence for cooling?
Cycleway town
The holes are primarily for gas dissipation.
When the disc and pad get hot, gases are produced between the surfaces, reducing friction. You're squeezing a bed of air. Holes (and grooves) give a pocket for these gases to escape, maintaining frictional contact.
