Where does this spacer go? Shimano 8 speed Ultegra
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
Where does this go? Wasn't paying attention...
Quoted: 18378 Post(s)
Liked 4,512 Times
I assume that is different than your other cassette spacers.
It may go behind the cassette as a first spacer.
Are you using an 11-speed hub?
Perhaps using "8 of 9" on a 7-speed hub, and using 9-speed shifters, and a partial 9-speed cassette?
Quoted: 2363 Post(s)
Liked 1,749 Times
How many (if any) of the cogs are riveted together?
Typically, I see those on cassettes where the smallest two cogs are separate from the rest, and it goes between the second smallest and the remainder that are riveted together. You could just slide everything else on, and from a side-on look it should be obvious where the spacing isn't correct.
Likes For madpogue:
Quoted: 985 Post(s)
Liked 2,378 Times
I realized after seeimg the first couple of answers that the spacer looks like the ones used on 10 sp hubs. In this case I'm running an 8 sp hub.
thanks all!
Quoted: 985 Post(s)
Liked 2,378 Times
After further review...
It does indeed go behind the cassette. I tried it between the 5/6 cogs and it goofed up the shifting. Not sure why I wanted to put it there. I was coming down with a cold, so maybe that fogged my mind.
Anyhoo, it's all good and shifting like a champ.
nickw
Bicycle Mechanics
18
03-09-15 07:07 PM
serpico7
Bicycle Mechanics
2
06-18-11 12:19 PM
