Di2 wire routing with 30mm axle in BSA BB
Hello! Does anyone have experience running Di2 wires through a BSA BB shell with a 30mm axle. I’m about to attempt this, but I understand that clearances are very tight. 1. Is this even possible? I believe the internal diameter of the BB is 34mm which means that the clearance between the axle and the shell is 2mm. 2. If/assuming it is, what options are there to prevent the wires from rubbing against the axle? Would a sleeved BB, such as this FSA model which includes a sleeve (https://shop.fullspeedahead.com/en/b...steel-bearings) work?Any advice gratefully received!Thanks. Picture of sleeved BB below:
Quoted: 3238 Post(s)
Liked 2,086 Times
Are you certain clearances are tight ? And where are you getting those measurements from ?
Have you removed the existing b-bracket to look at the area where the downtube and seat tube meet ?
On the Chinese carbon on which I installed Di2, I had a ton of clearance for the e-tube wires.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I have this BB and an SLK 386EVO crank on my gravel rig with Di2. With a straight-bore metal BB shell on a ti frame, it is a bit close. It works, just needs a bit of care.
Marcus_Ti
19
02-04-18 09:27 AM
freeloader
Road Cycling
8
05-23-13 05:03 AM
