Kemimoto Sur Ron LED Light Bar Mounting Instructions / Options
Hi!
I recently purchased and wired up the Kemimoto surron headlight on my Sur Ron, connecting in via the stock connector from stock light. Removed the plastic connector from stock light, soldered in terminals on new Sur Ron LED Light. Re-inserted into stock plastic connector. Connected into stock plug on Sur Ron bike. Works great. Opted out from installing toggle switch.
Anyways, the kit comes with an aluminum bracket to install in Sur Ron original light headset location. Kit also includes (2) sets of black brackets (and related hardware).
There is (1) threaded hole on the outside of each fork. Has anyone mounted their Sur Ron LED Light bar using the black brackets into the fork? Any feedback / photos would be appreciated.
Clark W. Griswold
Quoted: 4422 Post(s)
Liked 4,066 Times
You may want to check in on a motorcycle forum for these or check with the OEM?
Randomhead
Liked 3,714 Times
It really isn't, it's an electric motorcycle. The only bike parts I see on them are brakes, which is a little scary.
