Lower end group sets (current gen Shimano)
Quoted: 35 Post(s)
I've been using a complete tiagra 4700 group on an old steel frame for about 6 months/2000 miles and am very pleased with the experience. Shifting is a major improvement from anything else I've owned, especially in the front. Weaker brakes, 10 vs 11 speed, and weight seem to be all that set it impart from 5800 and 6800. Personally 10 speed was a plus for compatibility since I owned some nice 10 speed wheels already.
I'm planning a new build of an old frame for a rain/trailer towing bike. Considering 4700 again, possibly the triple version, but am curious about Sora 3000 and Claris 2000. Any experience with these groups? Are they just as good as 4700 but 9 and 8 speed respectively? Any other caveats?
Also, can anyone comment on front shifting of the triple version of 4600 vs the double? The front derailleur arm on the triple seems much shorter - does this negatively affect performance? By how much? I might choose an ultra compact double like 26/42 for this application if the triple is significantly less crisp.
Obviously not so worried about weight for this build, but I do appreciate function of high quality parts!
Bikes: Trek 1.2 2011 => Trek Emonda ALR 4 2017
Quoted: 73 Post(s)
But I am relatively new rider, riding old 3400 Sora. Plus - I think anyone else's experience is not super relevant: some won't even come close to anything lower than 105, and Claris is OK for lots of people. Got to LBS and try for yourself.
Quoted: 24 Post(s)
I have the newest Tiagra triple and find shifting very crisp both front and back. Although all my other experience is with outdated MTB groupsets. I was pretty impressed with the shifting getting on a brand new road bike.
Quoted: 7653 Post(s)
Liked 3,481 Times
I have a Taigra 4500 triple FD and mostly a 4500 set-up on one bike. it seems quite fine. I haven't had any trouble shifting in any way related to the possible length of the derailleur arm that I have noticed. Personally if I were buying new I'd get 105 because it is 11-speed compatible and rock-solid ... but Tiagra has worked for me (have some on another bike also.) if you are running a triple, 30 speeds seems like plenty ... why spend more to get three more duplicate ratios?
I haven't tried it but I hear 3500 Sora is as good as 4700 Tiagra. If I were building a triple, I would go for new Tiagra or Sora--durable, reliable, and cost-effective.
Quoted: 35 Post(s)
Did you ride the new Claris (R2000)? That's the group I'm most curious about as I have read that Sora R3000 is identical to Tiagra 4700 but 9 speed. I'm curious if the same is true with the new Claris, just 8-speed, or if there are other differences.
My LBS is great, so I try not to bother them test riding a bunch of stuff when I know I'm not going to buy anything. Just trying to decide which group to order from the U.K. Stores.
Should Be More Popular
Quoted: 22603 Post(s)
Liked 8,929 Times
Quoted: 35 Post(s)
Good point! And I am quite satisfied with the tiagra. One question still for anyone with experience with both versions is whether front shifting on the triple is just as good as the double, which has the new FD design with the longer lever.
Quoted: 73 Post(s)
Is R2000 so much cheaper that Sora so you're considering it?
Do you not have another LBS in your area?
Quoted: 1975 Post(s)
Liked 232 Times
all shimano sti groups are great, yes even claris. They all shift and behave essentially the same when properly tuned. Shimano spends a lot of time on shift quality, even on lower end groups. The only gen that had slight worse shifting was 5700/6700/7900.
There is still plenty of room for poor adjustment and sloppy shifting technique, though.
And don't forget to consider this when testing bikes at an LBS: how much time do you think they spend tuning a Claris bike vs. a higher end bike? It's a pretty easy marketing move to actually ensure that the shifts on the cheaper bikes is a little rough/slow compared to the 105/Ultegra/Dura Ace bikes. Those are the bikes that make the shop real money after all.
Quoted: 1217 Post(s)
Liked 187 Times
I love love love Sora 3500 - it was the best cheap groupset ever.
I'm sad to see it "upgraded" to under-the-wrap cable routing in it's R3000 form as that's going to lead to worse shifting performance just like 105 5800.
Liked 3,481 Times
Quoted: 73 Post(s)
Do you know a good video how to tweak them? May be I'll go and tweak it myself
I doubt that. Latest generation - R3000, 4700, 5800 switch very quick and crisp.
I wanted Claris, really wanted: I ride in Manhattan, sick of switching few speeds up/down on every traffic light. Tried it in 4 different shops, and everywhere was the same: too slow May be you're right, it can be tuned - but my experience so far says otherwise.
One of my bikes has Claris (2400), and one of my bikes has 105 (5800). The 105 shifts smoother and slightly quicker than the Claris. However, I don't have any issues with Claris, and that bike gets beat to hell.
Liked 3,481 Times
Well, if you are having problems with 105, you are the only person on the planet having those problems.
Liked 187 Times
I did not say I was having problems. I said the under-the-wrap routing led to worse shifting than previous external routing. Shimano recognizes this issue as well and it's part of the reason they revamped their housing and PTFE cable line-up. The cable path for 5800 is extremely technical and does not lend itself to smooth shifting in the long-term.
Liked 232 Times
Quoted: 127 Post(s)
If you are buying the group by itself, the price difference among Sora, Tiagra and 105 in minimal. I would just go 105 for the extra cogs.
As for me, I've owned 4700, 5800 and 6800. 4700 I could pick out from the 3. It has weaker springs. The shifters rattle over bumps compared to 105 and ultegra. Shifting quality was damn near equal among all 3 and sometimes 6800 felt worse than 4700 when it wasn't dialed in.
Quoted: 7 Post(s)
I’m really impressed by the Tiagra groupset on my new road bike. I had originally planned on swapping to a Ultegra/105 drivetrain I have on another bike but it probably isn’t worth the effort unless Im going to Ultegra 8000 or Di2 groupset.
Woman make me faster
Bikes: General 80's MTB "Icebreaker", Motobecane Grand Jubilee (vintage mint), Trek 1.1, 2014 Motobecane Mirage (steel) Trek 3500 MTB
Quoted: 39 Post(s)
I don't think upgrading your shifting gear would make you faster.. work on the motor!
