Pinging spokes
Bikes: General 80's MTB "Icebreaker", Motobecane Grand Jubilee (vintage mint), Trek 1.1, 2014 Motobecane Mirage (steel) Trek 3500 MTB
Quoted: 39 Post(s)
Pinging spokes
Recently got a bike in a box. Got it all put together and most of the gremlins sorted out (really an amateur, so some things I had to do twice) have noticed a faint pinging that I believe is coming from the spokes while under load, esp climbing. I didn't do anything but install the wheels out of the box. Is it time for a trip to the lbs? I have a tool set with adjustment tools, but don't want to monkey with stuff like that without knowing what I'm doing.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Keep riding until they stop pinging, then see if the wheel is still true. If not, time for the trip.
Pinging means they're unwinding a little bit... probably built in a hurry, or by a machine.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
check for unusually loose spokes and/or out-of-true rims... look ok? you're fine....
a good wheel builder relieves that stress before the wheel gets ridden... no time for such silliness at big factories...
Quoted: 659 Post(s)
Liked 7 Times
If they continue to ping it's usually an indication that the spokes are too loose and the ones at the bottom of the wheel are losing their tension. This can eventually lead to fatigue failure of the spokes so it would be a good idea to take it to a shop and have them tighten the spokes.
Quoted: 5224 Post(s)
Liked 3,585 Times
cpl years ago I read somewhere here that for new bikes have a tech check the spokes & wheels, then again after the 1st 100 miles
last time I heard mine pinging, not long after, spokes broke, got tangled up & wheel warped. needed daughter to rescue me w a car :/
Really Old Senior Member
On the wheels I've built, any pinging was gone in 2-3 revolutions.
If you have continually pinging, the spokes probably need to be properly tensioned.
You can also try a drop of oil on the spoke crosses to see if they are the problem.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Since this is a new bike, I would suspect machine built wheels that need to be tensioned before riding. You should get it done checked soon, Motolegs, before those spokes start to break.
Stuart Black
Stuart Black
Quoted: 6196 Post(s)
Liked 4,811 Times
In addition to all the advice above, you might consider making sure there are not any really loose spokes.
You don't need any thing but your fingers. Just pinch one between your thumb and finger and try to wiggle each. If some wiggle significantly more than the others, then you might need to go to the LBS sooner.
Some might say plink the spokes with your fingernail and listen to the sound. This is generally excellent way to see if they are all tensioned the same. But an off sounding spoke might not be bad enough to warrant the trip to the LBS at this point. IMO.
I'm not a wheel expert so I'll defer to any wheel builders that take me to task on that.
It is unlikely that a bike in a box has properly tensioned wheels, so I'd definitely check that. I would offer to check them out for you but alas you are waaaaay too far away, unless you want to take a trip to Brooklyn. I would take them to a shop if you can't do it yourself.
Quoted: 39 Post(s)
A couple more variables I should have mentioned. This is a performance oriented bike with aero (bladed?) spokes, 20 on the front, 24 on the rear. They only cross on the drive side rear. I weigh 183 lbs. I'm not a powerful rider but do like to stand and stomp up hills now and then. Hills are where the pinging generally manifests itself. It has continued for upwards of about 40 miles since new. It's a soft,musical pinging, not sharp like a creak..(had a genuine creak coming from the seat post that I cured with assembly paste and a torque wrench)
Wiggled the spokes and none really seem much looser than the others. Plucking them reveals differing tones.
Will try a drop of oil where the spokes cross tomorrow and test ride. I'll also double check the QR's. If it persists I won't take it on a planned 35 mile group ride Sunday, but instead take it to the LBS.
Liked 4,221 Times
With low spoke count wheels, this is harder on the spokes than with higher spoke count wheels because the spoke is carrying much more load.
Stuart Black
Stuart Black
Quoted: 39 Post(s)
It definitely sounds like loose spokes. I've experienced this before on a spoke that unwound near Biggs, OR while on tour. The "ping" is probably the spoke head moving in the hub as you tension/detension the spoke as you weight the rim during riding. Your weight deforms the rim a little which allows the spoke to move up and when that section of rim is unweighted, the spoke tightens again and slams into the hub flange.
at your weight, even lower than mine, you are stressing those wheels a bit. And if the spokes are not tight, definitely stressing them. Aero spokes tend to stretch and flex a more than round ones too. Under magnification, curly hair is flat while straight hair is round. The same goes for spokes. Flat spokes bend and round ones don't.
Quoted: 39 Post(s)
Quoted: 39 Post(s)
Update: after dropping wheel off @ LBS got a call later on that they had finished working on it. The spokes were not under enough tension.
Location: Creede CO in summer & Okeechobee, FL or TX Gulf Coast in winter
Bikes: Zenetto Stealth road bike & Sundeal M7 MTN bike
Quoted: 90 Post(s)
Wheel service in Houston
Rear wheel spokes make noise at crossover points on modest effort. Thanks to posts here I proved source with oil drops at each X. I have no desire to try DIY. Any recommendations on where to get it done? Near Hwy 6 and Westpark Toll Rd would be nice but can go just about anywhere.
