Saving bad chrome
Bikes: Surly Cross Check, Specialized Enduro Pro, Lemond Tourmalet
Quoted: 105 Post(s)
Liked 192 Times
Saving bad chrome
Hi all-
a Pinarello Treviso showed fs local. Post ‘84 model. The chrome on the chain stay is rusty. Don’t think it’ll polish up. Any good methods of saving it you’ve tried? Thinking of just cleaning it up as much as possible and slapping a chain stay guard over it…..
Quoted: 206 Post(s)
Liked 460 Times
Did you try aluminum foil yet? Soak a rag in some CLR or vinegar drape it over the chainstay and leave it for a few hours. Rub the rust off with a non scratch Scotchbrite, then rub aluminum foil on the chrome. You'd be surprised on how well it cleans up.
Likes For krakhaus:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,869 Times
Here are some results I got with just aluminum foil.
Before:
After:
As you can see, it will typically leave whatever pitting was there, but it will usually take off the rust and leave a surface that looks very good from five feet away.
Before:
After:
My Bikes
My Bikes
I'm probably gonna catch hell for this, but I've used 0000 steel wool soaked in WD-40 with excellent results.
Likes For gearbasher:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
The chain stay doesn't look awful. I'd give the crumpled aluminum foil a go first. I like to go with the least destructive methods first before pulling out heavier abrasives or chemicals.
Likes For Chuck M:
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
I've had success with aluminum foil and water.
Likes For John Nolan:
Quoted: 472 Post(s)
Liked 1,028 Times
Same here but with 30wt motor oil. I’ve used PB blaster too. Both work well. Some times I use a dull steel scraper on spots where the rust has “bloomed” up through a pin hole and flowed out onto the chromed surface. All of these can produce good results that beat throwing out the part or paying for a re-chrome.
Likes For Prowler:
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Similar (or worse....) chrome issues to the OP on a frame I'm working on.
Curious what folks do after removing the rust with one of the above methods to protect the pitted/bare metal parts? Clear-coat it? Clear nail polish?
Likes For ehcoplex:
Best to use bronze wool or brass wool. Doesnt scratch the chrone like steel wool.
Aluminum foil works, is simple and I have it on hand.
Good old Turtle Wax chrome polish works well too.
Likes For big chainring:
Am-a-tour
Bikes: 2020 New Albion Privateer, 1983 Schwinn Super Sport, 2022 Rivendell Atlantis
Quoted: 44 Post(s)
Liked 65 Times
I've had good luck with Johnson paste wax, though it takes re-application every once in a while.
0000 steel wool with chrome polish, I’ve had great results without damaging the chrome.
Semper fi
Semper fi
Likes For sloar:
TXHC
I’ll add another option to the foil:
coke. The beverage!
I’d definitely clean that up and ride it.
Hit it up with whatever car wax you have post polishing to keep it nice.
coke. The beverage!
Likes For amillhench:
Apply Metal Rescue or Evaporust with a soft tooth brush and keep brushing and applying. Then use wax to seal it.
Likes For Fat Tire Trader:
Quoted: 1143 Post(s)
Liked 1,753 Times
That's not bad, most of that can be wiped away with oil. Car wax would also do very well too, don't be afraid to use your fingernails. I would use the least amount of abrasive.
Here is the Mondia, I wiped this down with chainsaw oil, let it soak, wiped off, then scratched with my nails.
Likes For Mr. 66:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
There are as many ways to remove rust spots as there are to open a bottle of beer.
Quoted: 566 Post(s)
Liked 1,053 Times
I’m late to the aluminum foil fan club but I have become a lifetime member.
Generally, chrome is VERY hard so any metal/abrasive softer than the chrome will work. Evaporust has also worked well for me.
Side note - NOT a member of the rust converter fan club. There is a time and a place for it - never and in the trash.
Likes For RustyJames:
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
Barkeeps Friend, plus tinfoil. If it doesn’t clean up, call it Patina...
Likes For jdawginsc:
Quoted: 1372 Post(s)
Liked 1,752 Times
I DO NOT recommend steel wool! Wash the chrome with warm soapy water and a soft rag. Dry it off and then, crumple up a piece of aluminum foil, shiny side out, and rub the rust off. This works extremely well for surface rust only. Pitted rust is not nearly as easy to deal with. Same fork socks and fender struts after the aluminum magic treatment...
Quoted: 105 Post(s)
Liked 192 Times
Yep! Planning on it. A gift to myself for overcoming a partial Achilles avulsion. The Pinarello brings back a great era for me…
if only it were the tri color like Grewal’s Olympic bike!
Likes For teisco:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
I think that you will be amazed at the results that you will achieve using the above methods.
Post the results if you buy it and clean it up.
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
There is a product called "Bombz Away" that is a polish specifically for aluminum. Generally used and found within motorcycle circles. It says it doesn't work for chrome, but in my own experience it does very well. I have used it on brass and other metals as well.
Quad 0 steel wool works fine but you must keep some manner of liquid and don't dig in, just gentle circular motion. As stated above, if there is pitting there is basically nothing to do.
Likes For Juan Foote:
