Hybrid or Gravel/adventure bike
Old 06-20-22, 03:14 PM
Waseem1985
Quoted: 11 Post(s)
Liked 2 Times in 1 Post
Looking to buy my first bike in a long time for occasional leisure use. Was almost decided on the Boardman HYB 8.8 but have since come across gravel bikes and now can't decide if I should get the Boardman ADV 8.9.
Any advice would be appreciated. Just looking for a all rounded bike that I can keep long term and will build my interest in biking.
Thank you in advance.
Waseem1985 is offline
Old 06-20-22, 03:43 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
The Boardman ADV 8.9 looks significantly better to me: wider gear range, tubeless tires/rims, better tires, thru-axles, etc.
And drop bars allow multiple hand positions which helps in longer rides.
tyrion is offline
Likes For tyrion:
Old 06-20-22, 09:09 PM
Toadmeister
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times in 170 Posts
[QUOTE=tyrion;22548419]The Boardman ADV 8.9 looks significantly better to me: wider gear range, tubeless tires/rims, better tires, thru-axles, etc.
[/QUOTE
I concurr
Toadmeister is offline
Old 06-20-22, 09:11 PM
sjanzeir
BF's Resident Dumbass
sjanzeir's Avatar
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times in 496 Posts
Get a gravel-ready hybrid.
sjanzeir is offline
Old 06-20-22, 10:54 PM
gorillimo
Bikes: Surly Cross Check, Specialized Enduro Pro, Lemond Tourmalet
Quoted: 105 Post(s)
Liked 192 Times in 94 Posts
You’re planning on leisure use. Consider alt bars. Why put up with riding drops if you’re not racing? Better control, better for looking around. Definitely better on trails!
If it gets windy, bend your elbows….
gorillimo is offline
Old 06-21-22, 06:36 AM
Waseem1985
Quoted: 11 Post(s)
Thank you.
Any thoughts on the Sirrus X 4.0 which has a hardtail. I've read previously that's it's not worth having suspension on a hybrid bike would the same apply for this bike?
Old 06-21-22, 07:29 AM
prj71
Quoted: 2976 Post(s)
Liked 1,182 Times in 771 Posts
Sirrus X is a great bike for what you want to do. I have one in the household.
prj71 is offline
Old 06-21-22, 09:17 AM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
Originally Posted by Waseem1985
Thank you.
I'm not a fan of suspension on bikes that are not going to be used on terrain that requires it. I understand that Specialized Future Shock is short travel and designed to buffer the bumps. Even though it is being incorporated on multiple models, there is no guarantee that there will be support for it down the road when it becomes Past Shock and follows in the namesake's heritage.
John
70sSanO is offline
Likes For 70sSanO:
Old 06-21-22, 12:27 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10965 Post(s)
Liked 7,492 Times in 4,189 Posts
I advise you to decide what style of bike you want- flat bar or drop bar before asking for suggestions on which to buy. They are fundamentally different in feel and use. One isnt better than the other, they are simply different enough that it matters.
Nobody here can(should) advise you on which style you should choose because there isnt a 'right' or 'wrong' option.
mstateglfr is offline
Likes For mstateglfr:
Old 06-21-22, 03:48 PM
Waseem1985
Quoted: 11 Post(s)
Flat bar would be ideal as this is my first bike. However from what I have read hybrid bikes are limiting in the long run. I think it may be worth investing in a gravel bike as they seem to be more all rounded. I may be wrong.
Either way it's a decision between the Boardman HYB 8.8 or Boardman ADV 8.9.
Thank you all
Old 06-21-22, 04:13 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
While I think either bike will suit your general purposes, you might find that the gravel bike is more versatile in the long run. I like that the wheels are tubeless-ready, and IMO thru-axles are a better option for disc brakes. A gravel bike can go anywhere a hybrid bike can go, but I'm not sure the opposite is true.
Rolla is offline
Likes For Rolla:
Old 06-21-22, 04:59 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
This. In addition, consider a swept bar. All of my bikes now have them. Drop bars are useless for me because "my neck don't bend that way no more," and flat bars pound the hell out of my wrists. You can buy attachments for flat bars that address the comfort issue, but at least for me, a swept bar gives me hours of riding with no discomfort.
But it's hard to find bikes with swept bars that are also versatile and sporty. The industry is phenomenally style-conscious. On the other hand, it's pretty easy to adapt most flat-bar bikes to swept bars, not so easy to adapt a drop bar bike.
Flat bars make sense for mountain bikes due to controlling the bike on rough terrain, but not for pavement use. This is evident when you see people riding with their hands cupped around the ends of their bars, or with their fists on top of the grips. They're trying to give their wrists a break.
Gresp15C is offline
Likes For Gresp15C:
Old 06-21-22, 05:38 PM
gorillimo
Quoted: 105 Post(s)
Yep!! My Cross Check had flat, straight bars when I got it. My wrists hated it. Much better now.
Old 06-21-22, 08:19 PM
sjanzeir
sjanzeir's Avatar
Quoted: 792 Post(s)
And here I was thinking that I was the only one who did that! 😅
sjanzeir is offline
Old 06-22-22, 08:25 AM
prj71
Then go for flat bar. The Specialized Sirrus or Specialized Diverge Evo would work great for you.
prj71 is offline
Old 06-23-22, 01:33 AM
thejazz
go flat bar for first bike
thejazz is offline
