N+1 Flat/Swept Bars - Wide Tire - Gravel Bike
Quoted: 286 Post(s)
Liked 262 Times
I have a skinny tire road bike (custom frame, love it). And I have a Surly Cross Check that I use for mixed surface rides, rail trails, and as my winter bike when roads are safe(38mm Barlow Pass in summer, and 40mm Ventures for gravel and winter).
I was thinking I might like either a mountain bike or another gravel bike, but I want to try swept back bars (I’ve had mountain bike and flat/wide bars not comfortable for me). I want 2.1” or bigger, and would use only on gravel trails, the odd mountain bike trail (not technical). Would use flat pedals and want to be more upright (bars about level with saddle). Maybe I’ll love the bars and be a convert...won’t know until I try. Was thinking of a used hardtail and then adding bars that I want. Could also go new and have the shop help with dialing it in. New gravel bikes are typically more than I want to pay. Thoughts!?
Quoted: 4227 Post(s)
Liked 2,488 Times
I've tried many different types of handlebars over the years....Riser bars with 20-40mm of raise and with few degrees of back sweep, Ergon grips and bar ends are most comfortable for me and give me the best handling over rough terrain., I have riser bars on all of my 3 bikes.
Quoted: 286 Post(s)
Liked 262 Times
Liked 2,488 Times
Quoted: 185 Post(s)
Liked 36 Times
Alt Bars
If you end up with an early 90's mtb, maybe something like the Klunker bar would be what you're looking for? I have one of those that I built up with modern components to use as an occasional gravel bike/single track/commuter bike. While I'm ok with a little saddle to handlebar drop the bike puts me in, the Klunker bar would likely be a big improvement....might need to get longer cables to make that happen, lol
Likes For Craptacular8:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I can't say I've tried all the bars, but sometimes it feels like it. For my wide-tire gravel bikes, my current favorites are the Ritchey Kyote and the Soma Dream Riser (original). The Ritchey doesn't have much rise, but the Soma does (and comes in other versions with more and less rise and sweep). I also like the SQLabs 30X (16º version), which feels more like a traditional mountain bike riser.
My happy place for sweep is anywhere from 16º to 25º, but not everyone likes that much. Also, be prepared to try several stem lengths. A cm or two can make a big difference.
As for bike choice, a used hardtail (or used anything) is going to have the steerer tube already cut, which can be a disadvantage when dialing in the handlebar height. But I know several people who ride rigid 29er mountain bikes as gravel rigs; their geometry might be a better match for a riser than retrofitting a drop-bar frame, and you might not have to spring for new brake/shift levers.
Bikes: Surly Cross Check, Specialized Enduro Pro, Lemond Tourmalet
Quoted: 105 Post(s)
Liked 192 Times
Neck pain from an old fracture is putting me more upright. I changed my Cross Check to Velo Orange "Tourist" bars. Basic North Road/ Albatross type setup. Liking it so far. Hey, if the Rivbike guys ride all over on this type of setup, I should be fine.......
Likes For gorillimo:
Quoted: 1401 Post(s)
Liked 1,886 Times
Thoughts!?
as you aware - flat bars are not comfortable for many (especially long rides) - but the swept back bars might offer more comfort (?) ... I dunno ... flat or riser bars are fine for us - but we do primarily short rides
we have some old mountain bikes and hybrid bikes we use for paved bike paths, crushed limestone paths, dirt roads and light trails (all have flat or riser bars)
we typically go with the 26” bikes that have 2.1 tires and/or 700c bikes with 38-40mm tires (preferably) when we will be riding the dirt roads and light trails ... typically 25 miles or less ... few hours
I do miss drop bars when we are riding for extended periods (and have a ‘gravel bike’ with drop bars I plan to ride beginning next year)
Must be symmetrical
Swept back does not necessarily mean you loose the drop position or get up high. One can invert Albatross or NR style bars, and the "rise" ends up being a very comfortable drop position, in my opinion. You need to reach back for controls, but the drop position is for cruising anyway.
Here is a not so great shot from the wrong side, but you can see the bars.
i find this quite comfortable in the swept part and plenty long in the shallow drops.
Quoted: 432 Post(s)
Liked 460 Times
I love bars with a good sweep for city riding but I'm curious how they handle on dirt trails. I think for unpaved flat river trails they'd be fine but what about actual mountain biking trails (not necessarily technical, but with some elevation changes)?
Other than that, I think it's a great idea to do a sweep bar setup on an old 26er hardtail or a 70c hybrid/cyclocross frame.
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
Noonievut you gave no indication of an acceptable price range, but the Breezer Doppler Cafe+ comes fitted with a back-swept handlebar and can fit 2.1”/55mm rubber on its 650b wheelset. MSRP is $1.4k.
I have one which I use for gravel cruising and I quite like it. It’s not a sports and it’s pretty heavy at around 31lbs, but the gearing is low and the 48mm tubeless rubber I run makes it feel like a Bentley Arnage. I have another gravel bike for racing and fast rides, the T-Lab X3, so it seems like I use the Breezer in the way you imagine such a bike would fit in your life.
Admittedly, I did swap out the OE handlebar for a straight bar, to which I fixed SQ Lab inner bar ends to allow a more aero tuck when out on the open road, but that was more for looks rather than that I had a problem with the swept bar.
Here are pics as stock and my setup:
Quoted: 105 Post(s)
Liked 192 Times
Quoted: 286 Post(s)
Liked 262 Times
I ended up getting a full suspension mountain bike. Stock bars (7-8 sweep?) felt so wide to me so I had them cut down. Still wasn’t great.
Got some bars with 12 sweep, Ergon grips and the bars were also cut down. Much better. I’ve been out on some gravel trails twice, an indoor bike park, and an around-town, urban ride. It’s too early to conclude anything but a) I’m really digging the FS mountain bike and it opens up a lot of options for riding in my general area and beyond, and b) the bars feel better but I may try 17 degrees or so. Good thing with flat bars is no bar tape to deal with.
