Change Dura Ace 9100 53T/39T to 50T/34T chain rings?
Bikes: Spcialized RockHopper (free) 1992 Trek T100 Tandem ($220) 2006 Quintana Roo Seduza ($350) 2016 Giant Fastroad ($1100)
Quoted: 46 Post(s)
Hello,
I have a Dura Ace 9100 crankset with 53t/39t chain rings. I want to change to 50t/34t chain rings. I would like to know if the cranks will be compatible with smaller rings because I got conflicting info. I called one LBS and was told the rings would be compatible, however, they don't have them in stock. A second LBS said the rings are not compatible, and I need to buy a new compact crankset.
Thanks for your help...
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
All the shiumano dura ace road cranks went to the same BCD a WHILE ago so that you didn't need to buy a different crank to go from say 50/34 to 53/39. Pretty sure that's still the case.
110mm bcd for all the r9100 rings.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The first LBS is correct.
You can buy the 9100 chainrings, remove the old and bolt the new ones on yourself.
https://www.competitivecyclist.com/s...9100-chainring
