Rear Brake As A Drag Brake
Old 04-25-14, 04:57 PM
Colorado Kid
Quoted: 358 Post(s)
Liked 136 Times in 82 Posts
I've heard that in a hilly area that it's good to have rear brake ( to use as a drag brake) then just having a front brake. What is this list real world experience about that? Does adding a rear brake make a Fixie stop better in places where there is a lot of hills?
Colorado Kid is offline
Old 04-25-14, 04:58 PM
Cyril
Cyril's Avatar
Quoted: 21 Post(s)
yes
Cyril is offline
Old 04-25-14, 09:51 PM
Coluber42
If you're riding a lot of hills, two brakes are good for a variety of reasons. The obvious one is that a certain amount of redundancy is nice when the alternative is careening out of control down a mountain.
But moreover, having two brakes means you can alternate them on a long descent and not overheat your front rim. It also means that you can distribute the work between both hands/arms, which is nice on long rides. I've done up to a hilly 400k with only a front brake, and my left arm was MUCH happier when I put a rear brake on as well after that.
Simply controlling your speed down a long descent isn't a scenario of absolute maximum stopping power (which is the usual argument for a front brake over no brakes at all on a fixie); you can scrub of some speed using either brake. But there are good reasons for having both if you ride in hills.
Coluber42 is offline
tastewar
Bicycle Mechanics
17
08-15-17 06:47 PM
flik9999
Bicycle Mechanics
19
01-08-17 04:08 PM
earthworm94
Commuting
59
04-04-12 12:57 PM
krazygluon
Singlespeed & Fixed Gear
49
02-14-11 12:49 AM
asforme
Road Cycling
10
08-19-10 11:26 PM
