Seasonal Commuters
Quoted: 5224 Post(s)
Liked 3,585 Times
Seasonal Commuters
where do the temps have to be, for you to start up again?
Some years I've ridden in any temperatures, but this year, I wimped out and only rode when it was above 0 (F) / -17.7 (C). Once it was warmer than that, I started up again.
Likes For Alligator:
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
Upper 30sF. Bus is too easy in the cold.
Likes For Korina:
Likes For Daniel4:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
When the forecast is below 100F at 5pm
Genesis 49:16-17
Genesis 49:16-17
I have commuted in years past with the temp at 15 deg fahrenheit but this year I have not just due to so many other circumstances. But now that the temps are above 20 deg fahrenheit I am back out and commuting to work. As long as there is no water/ice on the roads (or precipitation from the sky) in the am I should be fine between now and this coming November for bike commuting.
Likes For essiemyra:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Before I retired 39 months ago, I generally biked to work only when it was above freezing, which worked out to Spring through Fall in Central Indiana. Biked to work almost every day while living in Atlanta.
Likes For JanMM:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
+20F, but also very snow ice dependent and overnight freeze thaw conditions. But I retired in Dec so no commute anymore
Likes For dedhed:
Bikes: 1990 Schwinn Curcit is my main bike
Quoted: 42 Post(s)
Liked 48 Times
The older I get the higher the minimal temp. and the lower the maximum temp have become.
I am now in the medicare age group and if it is a wind chill below 40 in the morning, I am driving to work.
Likes For Lambkin55:
You actually build up to it, so it is not as noticeable. Eventually I start to wear multiple layers, switch from sunglasses to ski goggles, and from cycling gloves to large mittens. If you suddenly drop into a climate that is 5 degrees (F), you would have a hard time. But if you had been riding in 10 degree weather the week before that, it doesn't seem much different.
It's spring now, and one of my least favorite seasons. It snows, partially melts, then freezes. That makes for a mess and a slippery or bumpy commute. I also hate riding through puddles that are 3"+ deep. No matter how good my fenders are, I still end up getting wet. So all things considered, the month of March is the worst.
Miles to Go
It has been a chilly year so far here in the corner of the Southwest. Lots of 30's and low 40's. I rode many days in the low 40's, but wimped out and took the car many days, also. Be different if I do as I intend and have our family go from 2 cars to 1, then I will have at least some "have to" behind my commute.
Likes For timdow:
Sunshine
Quoted: 10971 Post(s)
Liked 7,498 Times
40 min
Likes For mstateglfr:
Likes For Germany_chris:
Likes For cabledawg:
Likes For LonelyFromage:
Likes For sloppy12:
I commute all year round. I don't mind temperatures being well below freezing. However if there is ice or snow on the ground I will work from home. 2 wheel recumbent bikes and slippery roads is a no go. Fortunately this only happens at less than 5 days a year here in North Texas. If I would live further north I would probably get a beater trike for winter roads.
Likes For Harhir:
Liked 3,585 Times
just a reminder, I was curious to hear from seasonal commuters. this Thursday will be close to 70 degrees & it's got me thinking ...
Understood. But I guess everyone has a different meaning of season. My season only stops when there is ice or snow on the road. And mainly because I don't have the right bike for these road conditions since there are normally less than 10 days a year like this here in Texas. But I also hate riding when the temp gets much north of 100F/40C. Last summer was tough with temps above the mid 90s and humidity in the 90s for weeks. This is the time when long for riding your bike in the rain.
Likes For Harhir:
Liked 3,585 Times
Liked 3,585 Times
Disco Infiltrator
Liked 2,105 Times
Phoenix, man. I grew up there. About ten years ago I visited my parents out there around Labor Day and they were having a record streak of >110F days. At night it was cooling off to 90. My Dad wanted me to get a job there and take over the house he built there. But there was just no way I was moving back. It really wasn't that hot forty years ago. Even if it got that hot in the day it cooled off more at night. Googling, I see that last year they had the first recorded five day streak of 115's, after 2020 saw two 4-day streaks. jeeesus that was a good decision
Genesis 49:16-17
Genesis 49:16-17
