NBD - 1984 Trek 620
#76
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 277 Times
I'll get some more pics soon. It looks really cool with the 1 1/4" Contis!
#77
Quoted: 171 Post(s)
Liked 277 Times
Fenders?
It actually looks fairly tight with the 1.25" Continental tires. Does anyone have experience with SKS Longboard fenders on the 620? Would I need the P45? Thanks!
#78
https://www.bikeforums.net/classic-v...-possible.html
And, this guy did an excellent blog re: his money-is-no-object 620 rebuild, including fenders:
Fuji Otaku: The Phoenix Project - Further Fender Follies
There's no secret potion because the space is limited. It's a balance between tire size and tire clearance. 700c definitely gives you a bit more breathing room.
Likes For jlaw:
#79
Quoted: 171 Post(s)
Liked 277 Times
Here's a previous thread re: fenders on a 620 - not SKS-specific.
#80
The canti brakes are the main challenge on the 1984 620 - limits your options re: wheel size and hence fender use and tire size. The 1983 and earlier had caliper brakes that allows for the substitution of long-reach brakes, 650b wheels, etc.
Still, the 84 620 is a very nice bike.
#81
Quoted: 171 Post(s)
Liked 277 Times
New bar tape.
I installed the new handlebar wrap yesterday. I hadn't anticipated so many problems with that. It was a 2 hour exercise in frustration.
I watched about a half dozen videos, and made a couple practice runs, but the real deal just didn't work out. It is mostly the finishing that I struggled with. I used this Fizik 3 mm tape and it was hard to get it to look good, being so thick.
It's plenty tight, and feels good, I just want it to look better. Ah well, next time.
#82
Quoted: 171 Post(s)
Liked 277 Times
Update on puncture protection tires.
Continental Super Sport Plus.
After last nights ride, I inspected my tires before I brought the bike in. I had a large goat head thorn broke off in the exact center of the front tire. As soon as I began to pull it out, I realized that was a mistake. It was super long! I thought I'd hear air right away.
Nothing seemed to happen and this morning the tire is fine, no air loss at all. So far this s tires seem awesome! They are also comfortable and feel fast and confident.
#83
Quoted: 171 Post(s)
Liked 277 Times
Here it is so far. Plans to come yet are service BB, all new cables, dual Blackburn SS bottle cages, front rack, and panniers.
#84
A few questions:
Is the middle chain ring the original half-step or did you change it?
What's the freewheel - 13-28? I tried a 34T Mega Range 7 speed, but that last jump to 34T is awkward.
Which frame pump?
Likes For jlaw:
#85
Quoted: 171 Post(s)
Liked 277 Times
This bike did not have the Shimano 600 crankset that the catalog specs for it. It's got a 1984 dated Sugino AT crankset, with a normal triple 52-42-34. I've seen one other midwest 620 with this crankset, so I wonder if it was an option that year?
The freewheel is 13-28.
The frame pump is a Zefal HP.
#86
Quoted: 394 Post(s)
Liked 346 Times
That's looking great. Mine has the 600 crank. The 720 came with the Sugino AT so maybe you got an upgrade.
My 620 looks just like yours except it's a 19" frame instead of a 21" which is my normal size. But the top tube is very close to the same length on both. So with a slightly taller stem and a longer seatpost it seems to fit pretty good. I've only just mocked mine up though as its still waiting for me to get to it and give it a complete overhaul.
Likes For Hobbiano:
#87
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,699 Times
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
#88
Liked 1,699 Times
I've read that the Duo Par derailleur was an expensive component with an evolutionary design in its day that allowed for wide-range touring freewheels - worked well but could be fragile. Yours will probably be fine for a long time.
Here's a little history of it: https://bikeretrogrouch.blogspot.com...et-duopar.html
The Huret Duopar is a good derailleur. Frank Berto loved them and wrote about them in Bicycling Magazine. They can take up a lot of chain that's for sure. You should never change gears under a load with any derailleur but with this one, you really should baby it a bit by lightening up on the pedals when shifting. If you do that, you will get a lot of mileage out of it. I used one when I toured across the US and it worked great.
I wanted to like them- I thought they looked cool- in that industrial sort of way. My 620 was fine for a while until I started commuting. I kept having problems with the chain coming off the upper jockey pulley and between the cage and the pulley. It happened out of nowhere and once it went... it kept getting worse and worse.
The Titanium on my 720- I used it in conjunction with the Helicomatic- even though that thing had straight, square teeth- I swear I've never felt shifting that smooth. Like seriously not knowing that the shift actually happened until I felt the resistance on the pedals change. All that changed on one ride about 15 miles away from home- I still don't know exactly what happened- but what I think ended up happening is the stop spring ended up on the wrong side of the pin on the cage. It was a cluster****. I think the very next day I replaced it with a Deore XT.
If I were to get another bike that had a Duopar on it- I would replace it immediately. There's seriously no need to play ****-**** games and taunt fate. One of our esteemed members here tested out a 1985-ish Suntour XC with a triple pulley cage- it handled a freewheel fine up to 38 teeth. (38!). XCs are easily overlooked, they're usually cheap because no one knows what they are- and the triple pulley models are, frankly, weird looking. And best of all- the XC is perfectly in the time frame of the 84 and 85 Trek 620.
*I really should add that many, many people have had exemplary experiences with the Duopar- including people that I respect and have much more experience than me and have more experience based knowledge than me.*
#89
Liked 1,699 Times
There's brakes that have the adjustment to go from 27" to 700C and brakes that don't. The spacing between the bosses is much tighter than on modern bikes- so most modern brakes won't work- as they're not designed to.
I have used Shimano BR MC70, and M732 brakes (and I'll bet MT-62 brakes would work equally as well), I have also used Suntour XC Pro brakes. I've read conflicting things about DC/GC 960s, but I haven't used them.
#90
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
re: canti's/old frame post spacing/wheel size....
i have an '83 univega gran turismo with the same exact canti's as riverdrifter's 620. no problem converting to 700c. i've tried 19mm, 22mm, 24mm, and 25mm (external) wide rims of different wheelsets in toying around with my set up. even with the original pads.... no problemo!
what's odd to me is i have another '83 ...same model.....and tried a 700c conversion on it when i first got it years ago. now, as my memory serves me, i couldn't convert and get the pads to hit the rim right. i have no idea how to explain the discrepancy except perhaps i didn't know/understand as much i do now about bicycles and could have simply not been doing something right.
in any event, canti's limiting? i say not. i can fit a surly knard 41c in this frame easy with the dropout spacers removed and wheel shove all the way back. it's close, but it does work just fine. dare i say, in part, because of canti's!
oh, i can fit 35c's with fender, too
Likes For thook:
#91
Quoted: 4510 Post(s)
Liked 6,377 Times
I still haven't got the BB rebuild done, and still haven't ordered the tools. It's next on my list though, then all new cables.
Today I installed a pair of 27 x 1 1/4" Continental Super Sport Plus tires. I know everyone loves the Paselas, but the one weak point I hear about is sidewall punctures. I've talked about it before, but I live in the middle of hundreds of acres of goathead thorns. They aren't part of the ground cover, they ARE the ground cover. Late summer (now) until the snow covers them, the thorns travel everywhere on animals feet, shoes, etc. You can't avoid them, it's just not possible. I've run Mr. Tuffy liners in all the family tires, but we still end up with flats from sidewall thorns. My son had 2 this week. So puncture resistance and a tough sidewall were important to me. My Jamis has Schwalbe Marathons on it and they are great, if a little heavy. These Contis are 100 grams per tire lighter than the Schwalbes, so I hope I'll be happy with them. We shall see.
I've also got bar tape arriving today. Fizik Microtex Bondcush Classic 3 mm, black. This is gonna be a low key build.
Its called a fixed cup because it has no adjustment not because it should not be removed, it should be removed to make sure it is not seized and can be taken out if it needs service or replacement without damaging the frame.
I know many here disagree with this, that's fine, I disagree with that. It can be challenging, I do agree on that but it doesn't have to be, it's all about leverage and holding the tools in place while you apply it, especially when you need a lot of it.
Anyone that finds this too challenging can PM me for a foolproof technique that never fails and has never damaged any cups, tools, frames or flesh.
#92
Quoted: 171 Post(s)
Liked 277 Times
Thanks guys!
I got a set of NOS Christophe Special toe clips installed last night. Wow they are shiny! I also received my first Ortlieb purchase! Just a saddle bag. It's super nice though, feels really tough, waterproof of course, and a good size. I wanted something for day rides just big enough for a tube, a tire lever, multitool, and phone, snack, and wallet. I ordered the size small (having read these bags are big, relatively) and the small is just the perfect size. I got the slate color and it looks great on this pewter 620.
#93
Quoted: 796 Post(s)
Liked 522 Times
Looking like a sweet ride @riverdrifter, the handlebar tape looks good btw, nice that you have it road worthy with so much good weather still left. Some people love that Vetta saddle. I was not a fan and upgraded a couple bikes that came with the Vetta to Brooks. YMMV. Have fun riding that beauty!
Likes For ryansu:
#94
Quoted: 171 Post(s)
Liked 277 Times
Here is a quick pic with the toe clips and saddle bag. I also tried to get a detail pic of that great pewter metallic paint.
Likes For riverdrifter:
#95
You've done a nice job refurbishing that bike. Enjoy it for a long time, hand it off to your kids when you're done with it.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Likes For nesteel:
#96
Liked 6,377 Times
+1 Agreed! Very nice, well done.
Likes For merziac:
#97
Quoted: 171 Post(s)
Liked 277 Times
Thank you! I hope I can hand it off to my son. He's 8 years old and on a 20" BMX now and I'd like to get him on a 24" road bike soon, so we can do some road miles together!
Likes For Hobbiano:
#100
Quoted: 171 Post(s)
Liked 277 Times
I hate to admit it, but after riding this bike for awhile, I think it's too small for me. I've got the stem and seatpost at max height and I still can't quite get the extension I need.
My other bike is a 51 cm modern compact geometry road bike with a sloping top tube. It's 51 cm and the fit is okay. I thought this Trek, being a 21", would be just marginally bigger. Instead it feels just a bit smaller. Doing some additional reading, it looks like that is common, that vintage bikes tend to "fit smaller" than comparable sized modern bikes. The next size up is 22.5", that converts to 57 cm and seems like it would be too big. Maybe not? Of course that doesn't change the fact that this is the bike I've got, and finding a bigger 620 might not happen.
I know lots of people run taller stems on these, but that isn't really my issue. I'm not sure that it would be practical to fit a longer seatpost on it, and if that would really even correct the problem?
