Cycling Shorts Recommendations
I have bought the Louis Garneau Tour Cycling Shorts and the Pearl Izumi Peleton ( I believe) Cycling Shorts, two highly recommended brands, and the Pad was so clunky and unbearable I sent them both back, one at my expense. Anyone want to weigh in on Aerotech Designs....Thanks, mjac
Okay lets edit this, any brand you would recommend. I am frustrated here and felt like I paid for a name. Do not want to do that again.
I had some Aerotech a few years ago, so I can't really recall what I thought of them. Last season I bought shorts from https://www.theblackbibs.com and found them to be nice quality and comfortable.
Bikes: A few older US made Cannondales, a modern Soma Saga (no longer made, alas!), and one gifted crabon Specialized. Never enough.
Quoted: 45 Post(s)
Liked 60 Times
Another vote for the Black Bibs brand, although not answering your question about Aerotech I know. Next to Assos, they are the most comfortable bibs for me, and easily 1/4 the price.
I've been riding Aerotech Pro series exclusively for about 10 years now. My average ride is 40-50 miles with an annual mileage of 5K. I'd say that was an endorsement.
Winna
Not sure what you mean by clunky and unbearable though. The chamois is thick and cushioning across contact areas. It’s also a little wide yet very flexible through the crouch. The way they fit and ride tends to allow ample crouch room as I ride. So while they don’t mash that area, they create enough slack in that area that the shorts could catch on the saddle horn if not careful. Just something to pay attention to, and depending on physic they may fit you differently anyway. The legs are on the longer side and the openings stay in place very well. The pull-loop drawstring works well and stays put when tucked inside at the top of the shorts I can’t feel it. Compression throughout is good and snug without being restrictive at the hips. The net side pockets are nice to have.
Just my two-cents worth. Others may differ. Again, I like and use them. They are currently my go-to shorts.
Happy cycling!
I lIke AeroTech Designs but I had trouble picking out a style, a lot of marketing hype. You like the Pro Series? That is where I might start. Their Pads seem very well designed, did you find this to be the case. Obviously so if you have been doing them for 10 years. They came out with multi layered, multi density pad called their Racing Pad they advertise on their website, it is about medium thickness, but they do not have a short yet with it in it. They said they only sell it as a replacement pad right now. People actually take out a worn pad and pay to have another pad sewn in?...Thanks, mjac
Clunky
I like Areotech Designs touring cycling shorts. I have a couple of pairs. One pair is close to two years old and still fits and rides like new. I have not tried their other models.
Happy cycling!
Happy cycling!
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
I like the black bibs and have 2. But many comments i've read about them mostly complain about the pad.
Just a caution because the pad is what most folks complain about in any short/bib.
Too thick, too thin, too hard, wrong shape, etc....
edit: The last Pearl Izumi shorts i bought had a large, stiff pad.
I lIke AeroTech Designs but I had trouble picking out a style, a lot of marketing hype. You like the Pro Series? That is where I might start. Their Pads seem very well designed, did you find this to be the case. Obviously so if you have been doing them for 10 years. ...Thanks, mjac
Hard
Be forewarned, the Pro chamois has NO padding, just the fabric for anti-chafe not additional comfort. It provides a soft absorbent fabric layer between my butt and the saddle. I also ride a classic Fizik Arrione which has limited padding, guess you could say I'm a hard as*. Their return policy always was pretty good.
Veteran, Pacifist
Liked 4,832 Times
The pad in the black bibs has a minimal bit of softness at sit bones and while wider than some, does not chafe inner upper thighs on me.
But all this is all So Very Subjective as to be near meaningless. At least with black bibs your $$$ risk is minimal.
I like the company's stated philosophy but I want a state of the art pad. If that is AeroTech Design fine. If Black Bib has that I will buy from them because I like the Company and its no nonsense approach. But they must have a good pad...mjac
Veteran, Pacifist
Liked 4,832 Times
feed back your impressions of your purchase on this thread after a few rides.
good luck
good luck
Quoted: 4559 Post(s)
Liked 2,802 Times
I have a pair of Aero Tech Pro shorts with than tan/black pad. It's very low loft and density, mostly to absorb sweat and reduce abrasion. I wear 'em only with a padded saddle or as underwear under my jeans or baggy shorts.
I've worn everything from old school wool with leather chamois to Pearl Izumi and Black Bibs, but the most comfortable pads I've found are the Dupont CoolMax 3D and 4D pads used in the bargain priced shorts and bibs from Przwelski and Spotti (same company, different marques). But I've lost 25 lbs since I bought those Aero Tech Pro shorts in 2015. Now, with less natural padding on my butt, I need a little extra in the shorts. The CoolMax pads look and feel diaper thick, but dang... they're comfy for all day rides on rough roads, or marathon indoor trainer sessions. Best I've worn for wicking sweat (or rain), smooth surface to avoid abrasion, easy to clean. Much better than the pads used by Black Bibs or Pearl Izumi.
Check 'em out on Amazon. They range from as little as $15 for basic shorts to $30 for bibs, including some with capri length legs just below the knee -- so I don't need separate knee warmers in cool weather. Can't beat the value.
Bikes: Moots Routt
Quoted: 94 Post(s)
Liked 22 Times
This is relatively more expensive but the comfiest bib I have ever worm Not quite rapha price but still $160
https://buckyrides.com/product-revie...ng-bib-shorts/
- james
- james
- james
- james
Bikes: Moots Routt
Quoted: 94 Post(s)
Liked 22 Times
- James
Registered User
Quoted: 188 Post(s)
Liked 276 Times
I hate aerotech shorts. I bought some years ago back in 2005, very nice fitting and comfy.
Bought more in about 2017,hated them!
The front section is cut short and does not rise up in the front at all. For me, the front of the pad ends right at my nutty buddies and is like riding a bike with a hack saw blade trying to saw my nutz in half. I had severe nut pain.
Give me Pearl Izumi. Models I buy are about $100 but well the money vs having my nuts sliced in 2. Never had a problem like that with any other pair of shorts.
This is the chamois that tried to end my life.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
Spend thousands on a bike, spend pennies on bike clothing. I just don’t understand some people’s children...
Liked 2,802 Times
I am looking for the well built short that has the best Pad. From what you know, what is the best Pad, the Pad in AeroTech Designs or the Pad in the Przwelski and Spotti? I have learned not to get hung up on names, they don't mean anything. Przwelski was mentioned when I first asked for recommendations a while back. So was AeroTech Designs. I was leaning toward AeroTech, you think these are better?,,,Thanks,mjac
The Przewalski shorts use better fabric, much more comfortable pads, and generally look, fit and feel like more expensive shorts and bibs. Same with Spotti, which appear to be the same manufacturer -- my Spotti bibs with capri length legs have a Coolmax pad labeled "Przewalski." And I find the bib mesh fabric suspenders more comfortable than the Black Bibs (which aren't bad at all and are pretty good values).
Here's the main difference I see between the Coolmax pads used by Przewalski and Spotti: the original orange pad is thicker all around, comfortable but maybe a little thick where it isn't absolutely necessary. The yellow/black two tone fade pad is thick only in the high pressure zones, and thinner elsewhere. Both have been comfortable on many rides of 20-50 miles, and a few of 60-100+ miles. (Part of that is due to better saddles, good bike fit, etc.)
My size is a bit of an awkward in-between, at 5'11" and 150 lbs. I have bird legs and disproportionate upper body. So I can wear medium and some large tops, but not small. But I can wear small or medium bottoms. The Przewalski shorts fit me well in medium but I wanted a bit more compression, so when a pair of the small went on sale for $15 I tried 'em. Perfect fit at my current weight, with the compression I was looking for to give a little more support to the thighs.
Quoted: 822 Post(s)
Liked 1,960 Times
I think you need to spend some time investigating chamois pad thicknesses and the materials used. You have two samples already that did not work for you. So at least you have two data reference points to go on with LG and PI. You might also consider Tri-bibs by DeSoto. The 400 mile pad is thicker but the Mobius and Carrera have minimal padding.
