Front Derailleur Esoteric Quest
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Let me describe the situation. I have a bicycle that is set up as an 81 speed. In order to keep gearing in the range of mere mortals, I went with a front triple with 34-36-40 gearing. In theory, it should be a breeze to find a front derailleur that can handle the massive 6-tooth gap, but I have an issue.
I can't lower the FD any further to get it any closer to the chainrings because it will hit the cable and chainstay.
This shows the chainline when at the limit. I have fiddled with angling the derailleur, but in order for it to reliably shift to the inner chain, it ends up hitting the tire.
Does anyone know of a FD that can handle the triple that either has a shallower angle, or which has an adjustable angle (like the old Simplex FDs)? Hoping to find something that doesn't cost more than the frame did.
Quoted: 4806 Post(s)
Liked 3,928 Times
Or, modify that one. My thought - drill for a #2 or #4 screw though the outside plate, run a nice neat SS pan head from the outside, through the outer plate, through a bushing made from aluminum or steel tubing, though a washer, through the cutout on the inner cage plate, through another washer and a lock washer and nut or just a red locktite'd nut. Cut off the bottom of the cage. Could look like it was made that way.
Ben, the guy who enjoys making bikes different. (I have three I could show you for inspiration.)
Likes For 79pmooney:
Quoted: 1143 Post(s)
Liked 1,740 Times
I would try a MTB triple type it may have a smaller arc, and double check your chainline. It takes one heck of a spindle to have the Maxi tripled from double.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Paging our resident constructeur @gugie.
Yes. That type of modification.
Alternatively, would anyone know the dimensions of the current Tiagra FD-4700? Looks pretty short.
-Kurt
-Kurt
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
either an old shimano 60 or 600ex will do it and clear the stay. i have tried both in very similar circumstance. the 600ex is currently still in operation on a 39/36/24 half step on one of my gran turismos. the shimano 60 would work except the tail end is a bit too short and the chain rubs when down in the granny. iow's, it can clear the stay, handle the triple shift, but not the amount of drop
Likes For thook:
Quoted: 3464 Post(s)
Liked 2,829 Times
This is C&V, Campagnolo Gran Sport, cage is rotatable.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,799 Times
-Kurt
-Kurt
That's all I've got.
Señor Member
Liked 1,090 Times
-Kurt
-Kurt
That looks like it would be a viable answer - presuming it's a bottom pull and would come with an adapter for a 28.6 seat tube. I can look that up.
Other points about C&Vyness are taken, however this project has already strayed so far from purity, it is no longer really a concern of mine.
Likes For USAZorro:
Liked 5,799 Times
Oops, sorry, senior moment. I meant front derailleur, and I still recommend a Cyclone MkII
Likes For gugie:
small ring
Quoted: 437 Post(s)
Liked 925 Times
Having been through a similar situation, there is no easy solution. The problem with moving the lower cage bolt up is that the plates don't line up, as 2nd photo shows. The problem with using a MTB triple is the small difference in ring sizes. You would have to gap the inner plate to the middle ring, which would leave a large gap to the outer. That could work but the chain will overshift the big ring rather easily. Gevenalle makes a CX FD for slightly smaller rings but I don't know if it can handle a triple.
https://www.gevenalle.com/product/bu...nt-derailleur/
You might try to find a MTB triple FD with a large inner plate and then shave it down for better clearance.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
3 front * 7 cogs * 3 IGH, I presume? Cool! This reminds me of Charlie Harding's 90-speed bike, on display in his Westwood (Los Angeles) shop in the 1970s. I think he went 3x6 derailleur gears with a 5-speed IGH.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 697 Times
Coincidental post
Likes For sd5782:
Quoted: 3241 Post(s)
Liked 2,512 Times
What about one of the Suntour Microdrive FDs? Those were made for small chainrings. Suntour BL FDs have small cages also.
https://velobase.com/ViewComponent.as...=113&AbsPos=64
Likes For seypat:
Quoted: 1372 Post(s)
Liked 1,751 Times
@USAZorro...
Eighty one speeds! Wow. I did see a guy, once outside of the liquor store, riding a home made 36 speed recimbent steed one day. I do wish that I had taken a picture but, alas, I did not.
Liked 4,395 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Newer old guy here so didn’t want to be laughed at when trying to get my Miyata 1000 from 48-38-28 to 42-34-24. My triple front wouldn’t get low enough for the 24 and looked bad. As you said a 600 from my local co-op did the trick. Might not translate to this situation, but shifted all 3 nicely.
nothing laughable about your change out, btw
Quoted: 583 Post(s)
Liked 697 Times
600EX I think
600EX I think. Came from co-op but matches one from an 85 Centurion I have that is EX I think. Paid $5 so gave it an uneducated try with good results. With careful chain length tuning I get the 5 easiest gears on the 24T before the chain hits the Miyata chainstay protector hoop.
feros ferio
Liked 1,325 Times
In the immortal words of Homer Simpson, "Doh!" My bad ...
What are you cog tooth counts in back?
0.75/1.00/1.33 IGH like a Sturmey AW, or other?
I presume you have already created a gear chart and shift diagram.
The closest I ever got was a 36-speed, with 3 in front and a 4-cog 14-16-18-20 block in back on an AW.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
As suggested, maybe a BL or Cyclone.
Señor Member
Liked 1,090 Times
Quoted: 3810 Post(s)
Liked 6,694 Times
What’s the length of the FD cage? I can route around in my deep FD bin to see if I have anything shorter.
Liked 2,512 Times
I think the Shimano 600 FD in question is a FD-6207.
Some Suntour Mountech FD have a "step" or notch at the bottom of the cage to clear the cable and chainstay on touring bikes with lots of hanger drop.
Campagnolo 8/9 speed triple FD have short cages with inner plates that can clear half step chainring differences and smaller chainrings.
Shimano 9/10 speed trekking FD are available for the lesser angle between the seat tube-chainstay on frames with more hanger drop. The angle range is stamped on the back of the inner cage.
Señor Member
Liked 1,090 Times
Center of seat tube to rear end 57mm (measured parallel to the ground - hoping this makes sense without resorting to drawings).
Haven't forgotten about the crankset, but I have practically every style besides cotterless road, and have been hoping to source one locally without success.
