Good 26mm Road Bars
Bikes: '15 Giant Propel Advanced SL1, '17 Trek Madone RSL
Quoted: 29 Post(s)
Liked 79 Times
Good 26mm Road Bars
I have a Trek 5200 circa 2000 that has 26mm bars. They are the old-fashion type that slopes down towards the hoods instead of being more level like modern bars. I find this to be really awkward / uncomfortable.
Does anyone have recommendations for a 26mm bar that would be shaped a little more like modern bars? I find it hard to get a good sense of the shape from pictures online…
It's an old bike so I am just looking to spend in the neighborhood of $50.
Jedi Master
Quoted: 6178 Post(s)
Liked 4,795 Times
Modern? I just thought they were slightly different styles to fit slightly different tastes and needs of the rider. I thought we had them BITD and they were modern then.
Whatever you get, you need to make sure you get the correct reach and drop for you. All the modern in the world won't help if you get those wrong.
But if you are going to only be on the bike for 20 minutes to an hour, I suppose anything will work if it makes the bike look good and you "feel" good about it.
Quoted: 29 Post(s)
Liked 79 Times
Thanks...those look like what I am looking for...especially the M177.
I see that Nitto also has an M184 that looks really too good but does cost twice as much...I'll have to think it over.
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
https://www.somafab.com/archives/product/highway-1-bar
comes in black or silver. modern compact bend with the drops extending back a bit too. ive owned 3 sets of them and still have 1 on a bike. hoods can be mounted level with the ramps.
Likes For mstateglfr:
Quoted: 1109 Post(s)
Liked 1,200 Times
I also have a set of Civia Emerson in 26 and they are nearly identical in shape, drop, reach, etc. to the HWY 1 bars. I can't remember but one or the other was a few grams heavier than the other, but very, very little difference.
Just did a quick web search and they might be discontinued. But if you find a pair, they are just like the HWY 1.
This is what the HWY1 and/or Emerson will look with modern shift/brake levers:
Likes For Camilo:
Local 1212
I have a set of the HWY1 bars in 26 and they are an excellent example of the bars the OP is looking for. And they look nice and aren't expensive.
Likes For @work:
Liked 1,200 Times
I have my Emersons installed on a bike and could have taken a picture of it, but it's a dirty gravel bike and has bar end shifters in this particular iteration, so wouldn't be a good example of what the OP is looking for. I have the HWY1s in reserve for my next build.... soon I hope!
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
I have Highway Ones on 3 out of 6 bikes. In fact I just used one to replace a Cinelli Giro d'Italia - exactly the kind of downward sloping bar the OP described.
