Low-profile floor pump chuck
Does anyone know of "low-profile" presta valve chucks for floor pumps that will stay on by themselves? This is for disk wheels and such with little room for big chucks or chucks with thumblocks. I use a Silca presta valve right angle chuck, but I have to hold it on with one hand while I pump with the other hand. It makes inflating to high pressures difficult.
This one works well for me (I use the Presta version)
https://www.alexscycle.com/misc-/othe...hose-band.html
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
I still like the brass Silca track pump head:
Quoted: 5764 Post(s)
Liked 2,537 Times
I agree, but it doesn't work on many disc wheels because of the hose orientation. Some 30+ years ago took one, cut off the barb and soldered it into a hole I drilled in the side. I then got fancy and put a pressure relief valve in the top. Used it for many years then gave it to a friend.
Later you could buy heads with a similar design made by Zefal, and others. They were very common when disc wheels were more common. I assume someone still makes them, but it might take a bit of searching. (or you can repeat my effort of 30 years ago)
FB
Chain-L site
FB
Chain-L site
thanks
This led me to the Hirame on eBay and a Tanaka at Excel Sports. I wonder if the thumb-lock will get in the way in the little cave for the valve stem. I will see.
https://www.ebay.com/itm/HIRAME-PUMP-...-/390278354802
https://www.excelsports.com/main.asp?...ajor=3&minor=9
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
For this purpose, I'd start with an o-ringed Presta to Schrader adapter; they're pretty damn small, have to be unscrewed to come off, and will hold loads of pressure.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
