Front Brake Wobble
Front Brake Wobble
Hello all,
I decided to start using the front wheel brake more often as I've read that front wheel braking is more effective in general than using the rear wheel brake. However, after riding slowly a while getting used to using the front as primary, I feel that the braking is slightly "wobbly" when slowing down from high speeds.
Basically, under hard braking, the front wheel feels like it will pull slightly to the right and left alternately. This is a pretty unsettling feeling when trying to slow from a downhill. The wheel seems to be true when I spin it. Nothing wobbling.
Is this normal behavior that I just have to get used to or is there an adjustment I can make?
incazzare.
I'd bet the headset needs adjustment.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
