BB30 cranks on BB86 frame (i.e. can install force 22 BB30 cranks on my BB86 canyon)?
hi guys
i'm getting my canyon ultimate cf sl delivered to me soon!
it's got 105 groupset on it and i'm going to swap force 22 on to it.
the thing is, most LBS in my country that i trust only carry BB30 cranks for the force 22.
i was told that they don't order the GXP crankset as you can use the BB30 cranks with a press fit BB86 (which is what the canyon frame is) adaptor from rotor (component Rotor 4130)
my question is whether this rotor 4130 BB is compatible with a force 22 BB30 crankset? or is it only usable with rotor's own cranks
i've read somewhere that a BB30 crank WILL NOT work with a BB86 frame because of the spindle length.
i'm very inexperienced when it comes to bike components and the BB standards are so damn confusing!
please help!
thank you
please help!
thank you
Quoted: 6556 Post(s)
Liked 58 Times
As I understand it, the BB30 crank has a short spindle. The BB86 designation of the bike BB shell means it is wide and requires a long spindle. I would say this is the one "direction" you can't go to adapt one system to the other. You can increase the width of a BB shell but not increase the length of the crank spindle.
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
The Force 22 BB30 crankset has a longer spindle, similar to Rotor 3D+/F, FSA 386EVO, Campy Comp Ultra/One... cranksets that aren't native BB30. With that said, it'll bolt right on using a Rotor 4130 bb onto a bb86 shell. You'll end up removing the NDS adjustment ring , spacer and substitute it with 1-3 1mm washers+ wave washer.
I'm waiting for my new frameset to arrive and it's also bb86. I plan on using FSA's bb86 to 386EVO bb so I can use my Comp Ultra.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Best Regards
Quoted: 115 Post(s)
Liked 204 Times
I could be wrong but I believe there are two variations of bb86.
One where the bearings are installed in the cups already, similar to pf30 and are pressed in. The other is similar to Trek's bb90 application where the bearings themselves(no delrin or alloy cups) are pressed directly into the bb shell.
yeah i actually bought the GXP BB but there's just no GXP Force cranks in stock anywhere
so i guess i'll go ahead with the rotor 4130 + force 22 bb30 crank combo
this is fool proof and should have no compatibility issues (squeeking etc.) right?
thanks guys!
Liked 8 Times
argh you lost me at the "NDS adjustment ring spacers washers etc."! so i assume this is a very basic thing that any LBS should be able to do?
thanks guys!
thanks guys!
As to the no squeaks thing. No squeaks whenever press fit BB's are involved is all about the knowledge and attention to detail of the installer. Tech manuals for mating parts should all be read to understand press level, tolerances and adhesives involved. Unfortunately, many that do typical integrated BB installs...many far from typical with the plethora of different BB's out there...don't do adhere to this standard.
BB30 crank to BB86 frame
Hi, did you manage to get this to work? I'm looking for an answer to myself. I have Canyon Endurance. I bought QUARQ power meter and found out the spindle is a bit short. I"m thinking of buying another crank with a longer spindle like the Force 22 you have mentioned. I measured the spindle length for the QUARQ was about 106mm. I couldn't find the info on length for the force 22. TIA
Quoted: 115 Post(s)
Liked 204 Times
I had a Quarq DZero Carbon PM on my Storck and the bb shell is BB86.
From what I remember, Quarq PMs with a 30mm spindle diameter that’ll fit BB86 and must be 386evo compatible such as Red DZero, DFour and DFour91.
I don’t understand. My bike manufacturer recommended to use Sram dub bb86 bracket. I use no washer at all. The spindle insert from the non drive side. I could not tighten the quarq spider on the drive side cause it’s too tight and won’t able to spin.
which quarq did you buy? dub is 28.99mm not 30mm that everyone is talking about here
Quoted: 164 Post(s)
Liked 44 Times
i dont know if it helps but the new force 22 cranks seem to be the similar length to the old gxp , GXP is old , GXP does fit a bb30 shell with the adapter , but BB30 is not gxp , GXP is 24to22mm diameter
i can literly shake a tree and sram gxp cranks will fall out you dont have to use force , just about all the sram road gxp cranks can be used reds ,apex , rival , really all the same at the end of the day , but i do prefer the carbons stiffness !!
https://www.facebook.com/marketplace...code=undefined
Quoted: 115 Post(s)
Liked 204 Times
