Riding Shy After Repair
Old 09-17-15, 06:49 PM
Rcrxjlb
Rcrxjlb's Avatar
Bikes: Unknown Kalin MTB, 2013 Denali, 1977 Raleigh from Malaysia, 1982 Univega Nuovo Sport
Quoted: 62 Post(s)
I just repaired my back wheel myself (new inner tube, homemade rim strip, eyeball truing attempt).
Went for a ride and can't bring myself to go over 10 mph.
Do you feel a little shy after you've repaired your bike, or do you go out and beat on it as usual?
Rcrxjlb is offline
Old 09-17-15, 07:24 PM
CliffordK
CliffordK's Avatar
Quoted: 10668 Post(s)
Liked 568 Times in 453 Posts
What did you do for the truing? Did you use something like brake pads, or a pen or pencil as a gauge?
Anyway, I do little things on my bike all the time. I might avoid some potholes, but not really babying it.
A first ride on a "new" bike might be a little cautious.
CliffordK is offline
Old 09-17-15, 07:42 PM
avidone1
avidone1's Avatar
Bikes: 2016 Specialized crosstrail comp disc
what's the point of doing the repair yourself, if you have no confidence in it?
I understand the need to save money whenever possible, but questionable bicycle repairs is a dangerous place to cut corners.
avidone1 is offline
Old 09-17-15, 07:46 PM
Rcrxjlb
Rcrxjlb's Avatar
Quoted: 62 Post(s)
I used the brake pads as a guide. Not perfect but better...
Rcrxjlb is offline
Old 09-17-15, 07:52 PM
Rcrxjlb
Rcrxjlb's Avatar
Quoted: 62 Post(s)
I like doing things myself. I've worked in construction so I know how to work with my hands.
But I'm still new to bikes...
Rcrxjlb is offline
Old 09-17-15, 08:17 PM
jimincalif
Bikes: '96 Trek 850, '08 Specialized Roubaix Comp, '18 Niner RLT RDO
Quoted: 545 Post(s)
Liked 72 Times in 47 Posts
Usually just jump on and go, don't give it much thought except when I replace the chain. I go easy on it for a mile or so, and also when I work on the brakes I give them a few tries before ramping up.
jimincalif is offline
Old 09-17-15, 08:40 PM
ddeand
ddeand's Avatar
Quoted: 164 Post(s)
Liked 36 Times in 20 Posts
Whenever I do some work on my bikes, I usually take a few laps around the neighborhood to check adjustments, then forget about it and just ride. I've done everything from bike builds, wheel builds and basic adjustment and maintenance. The wheel builds seemed to require the most caution because there's so much voodoo involved. As for your repairs, I probably wouldn't have used a homemade rim strip. But that's just me.
ddeand is online now
Old 09-17-15, 08:42 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 927 Post(s)
Liked 163 Times in 135 Posts
Full speed ahead.
Homebrew01 is offline
Old 09-17-15, 09:03 PM
02Giant
Home School Valedictorian
02Giant's Avatar
Bikes: 13 Orbea Orca 02 Giant Cypress 88 Mongoose ATB 79 frame-built to 80 spec. Schwinn Traveller
Quoted: 1107 Post(s)
Liked 181 Times in 135 Posts
Originally Posted by Homebrew01 View Post
Full speed ahead.
Absolutely...
My signature says it for me.
Elect a clown, you get a circus
I ain't broke and I ain't hungry but I'm close enough to care
tp
02Giant is offline
Old 09-17-15, 09:30 PM
bmcer
bmcer's Avatar
Bikes: Full campy Record EPS BMC Team Machine slr01
Quoted: 13 Post(s)
Liked 15 Times in 12 Posts
I trust my own work more than any shop I've been in in the last few decades. So yeah, once I'm done, it's business as usual.
If you can't trust the work of your own hands, what's the point?
bmcer is offline
Old 09-17-15, 10:17 PM
prathmann
Quoted: 659 Post(s)
I feel much more confident on my first ride after a repair than I did on the last ride before it when I knew something was wrong but hadn't fixed it yet. So as others have said, maybe a quick run-through of the gears to be sure nothing got out of adjustment, but after that just ride as usual.
prathmann is offline
Old 09-17-15, 10:47 PM
scott967
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 202 Post(s)
Liked 8 Times in 6 Posts
Maybe not for wheels, but typically I will ride a little neighborhood loop shifting through the cluster, testing brakes, just making sure I am happy with how things are running. I might have a couple allens in my pocket to make on the road adjustments, or I am close enough I can return and put her back on the stand if needed.
For truing I would think you can pretty much watch it on the stand. I don't think I've ever had a wheel just "go out of true" riding compared to on the stand. But my worst case is replacing broken spoke so maybe other repairs have a different "first post-repair ride" experience.
As far as DIY rimstrips, been there done that and if you are careful, it works but if not be ready to fix flats on the road. Speed isn't a determinant AFAICT. In the end buying decent rimstrip is easier.
scott s.
scott967 is offline
Old 09-17-15, 10:57 PM
dprayvd
makn'a phonecall to doggy
dprayvd's Avatar
Quoted: 23 Post(s)
So, us all standing in your space on the day & it's gonna be "gee, no rimstrip noride?"
dprayvd is offline
Old 09-17-15, 11:15 PM
ddeand
ddeand's Avatar
Quoted: 164 Post(s)
Exactly! If you don't go to the best LBS and buy the most expensive rim strip, you will not be allowed to ride.
As indicated, I am more comfortable with Velox rim tape on my bikes. If I am caught without that availability, I'll use whatever I can find until I can get what I like - including Scotch tape, Hello Kitty bandaids, Ace Bandages, or jock tape. I've seen too many flats caused by cheesey factory installed rim strips to trust sketchy rim tape.
Old 09-17-15, 11:53 PM
smarkinson
Quoted: 332 Post(s)
Liked 13 Times in 7 Posts
I feel more confident riding a bike that I've worked on rather than one that someone else has. That way I know that all the nuts and bolts have been properly tightened.
But I do carry a few handy allen keys for the next ride or two, e.g. if I put new cleats on shoes I would take an allen key for any adjustments/tweaks. Or if I'd worked on the truth of the wheel (is that even a phrase?) I would take a spoke key with me.
If I buy a new bike I almost always replace the cheap rim tape because I've had that stuff blow out before. The last thing I want is a blow out at 60kmh caused by dodgy rim tape. Mind you, my current wheels don't need rim tape so hopefully that's something I don't have to worry about in the near future.
smarkinson is offline
Old 09-20-15, 08:33 PM
yuoil
Bikes: 1986 Lotus Challenger, 2015 Giant Revel, Fatbike
Quoted: 18 Post(s)
if you keep repairing the bike yourself you'll eventually gain more confidence.
yuoil is offline
Old 09-20-15, 08:48 PM
bengreen79
Allez means go.
bengreen79's Avatar
Give it hell. If you get a flat or go out of true on your rear tire, you'll feel or hear it long before it causes a crash. You have to be a little bit more cautious with the front wheel, but I've hit something and lost both tires and not fallen over (while clipped in). You'll be fine.
bengreen79 is offline
Old 09-20-15, 10:13 PM
FrenchFit
The Left Coast, USA
FrenchFit's Avatar
Bikes: Bulls, Bianchi, Koga, Trek, Miyata
Quoted: 360 Post(s)
Liked 19 Times in 12 Posts
Agreed, full out; but close to home in case you need to limp home. Seriously, would you prefer to shake out a problem 50 miles from nowhere?
Frankly, what you're taking about testing is not a big deal. Frame building, wheel building - now that's a leap of faith.
FrenchFit is offline
Old 09-21-15, 05:44 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 927 Post(s)
I never had second thoughts about going 50 mph downhill on both at the same time.
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Old 09-21-15, 08:26 AM
Road Fan
Road Fan's Avatar
Quoted: 957 Post(s)
Liked 75 Times in 69 Posts
How did you make the rim strip? If it's from old inner tube, replace it.
Road Fan is offline
Old 09-21-15, 09:01 AM
Jim from Boston
Jim from Boston's Avatar
Quoted: 761 Post(s)
Liked 139 Times in 115 Posts
I recently replied to this thread on the Road Cycling Forum, ”Do You Work / Maintain Your Own Bikes?,”(particularly regarding my high-end carbon fiber bike).
… Time eventually became too much of a premium, so now my LBS does it all.
Besides time, I have never had good facilities to work easily… Having the LBS do it all, in my case is a really good deal. The shop is one block away, and they will fix many things at a convenient time for me. They are so expert that they can do these things quickly, better than me, and often spot problems that I did not see. Whenever I leave the shop, the bikes ride as if new again.
Because the bikes are a major transportation mode for me, keeping them in good repair is critical. We save a lot of money on transportation, so further using the LBS is even more cost-effective. I tip well, not, “To Insure Prompt Service,” but because I am so appreciative of their work. Hats off to Back Bay Bikes.
This summer I fractured the right-hand drop of my CF handlebars, and rode it gingerly without weight on the right. I gave it no further thought once my shop replaced the handlebars.
Jim from Boston is offline
Old 09-21-15, 06:12 PM
canklecat
canklecat's Avatar
Quoted: 3356 Post(s)
Liked 732 Times in 502 Posts
The one time I should have been shy after my own repairs, I wasn't. And I was damned lucky.
For some dumb reason in the late 1970s I thought it might be a really good idea to run my wheel hub bearings on just WD-40 and no grease. Less rolling resistance or some boneheaded logic. First time I felt the heat waves coming off the front hub when I reached down to flip the quick release to lock up the bike, I realized something was desperately wrong with my reasoning.
That afternoon I bought a tube of Phil grease and redid both wheels and the crank before the next morning's commute. I was just lucky the raceways weren't scored.
canklecat is online now
Old 09-21-15, 10:43 PM
corrado33
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1126 Post(s)
After any sort of repair or adjustment I'll head around my tiny road and jump around on the bike a bit. A few bunny hops, a few hard pedals, and a shift through the rear cluster, after that it's 100% go time.
I also trust my work more than any LBS.
corrado33 is offline
Old 09-22-15, 11:13 AM
ptempel
Bikes: 2007 Ridley Excalibur, 2003 Orbea Orca, 199? Cannondale Headshock MTB hardtail
Quoted: 515 Post(s)
Homemade rim strip? Just use Velox tape and be done with it.
File Type: jpeg
ptempel is offline
maf
Commuting
23
03-31-13 04:25 PM
squatchy
Bicycle Mechanics
10
03-21-13 03:33 PM
TomD77
Fifty Plus (50+)
2
10-30-11 03:11 PM
agobel
Bicycle Mechanics
20
03-10-11 08:09 PM
rustmyrtle
Bicycle Mechanics
13
04-21-10 02:18 PM
