rim tape flat
rim tape flat
Old 06-03-17, 08:41 PM
rumrunn6
rumrunn6's Avatar
Quoted: 3558 Post(s)
Liked 573 Times in 411 Posts
rim tape flat
guess I moved the rim tape when I mounted these tires. had more than a cpl rides on them, surprised it didn't flat sooner. the plastic tape wouldn't go into place easily or stay put. it was hard & formed to the rim shape. I decided to change it. glad I had a roll of nice thick cloth tape with me
wasn't hard to find the puncture
this roll of tape has been in my bag a looooong time
rumrunn6 is offline
Old 06-03-17, 08:52 PM
sweeks
sweeks's Avatar
Quoted: 561 Post(s)
Liked 59 Times in 45 Posts
I like the plastic tape idea, but I find the Velox tape much easier to use, and it seems to stay in place better. Only drawback is it's not re-usable.
Steve
sweeks is offline
Old 06-03-17, 08:59 PM
rumrunn6
rumrunn6's Avatar
Originally Posted by sweeks View Post
Velox tape is not re-usable
in what respect? I don't anticipate ever replacing it
rumrunn6 is offline
himespau
himespau's Avatar
Quoted: 1789 Post(s)
Liked 190 Times in 135 Posts
Can't say I carry rim tape with me, but it's a good idea. Never occurred to me before now.
himespau is offline
Old 06-03-17, 09:02 PM
sweeks
sweeks's Avatar
Quoted: 561 Post(s)
Good point. On my folding bike with 20" wheels, I occasionally break a spoke. The rim tape has to come off to replace the nipple, so I wind up replacing the tape. On a normal wheel under normal conditions (all my other bikes, for example!) the tape lasts the life of the rim.
Steve
sweeks is offline
Old 06-03-17, 09:03 PM
rumrunn6
rumrunn6's Avatar
wouldn't need it, if I wasn't a doofus mounting tires
rumrunn6 is offline
Old 06-03-17, 11:27 PM
hueyhoolihan
Quoted: 86 Post(s)
you never know... i didn't anticipate having a quadruple bypass either.
hueyhoolihan is offline
Old 06-04-17, 05:48 AM
wschruba
Quoted: 465 Post(s)
Steve
As long as the rim was clean when it went on, I have almost never had issues re-using Velox when replacing spoke nipples. Now, if it's the older cotton tape, and rotten, that's a different story.
You can use a dab of tubular glue to help secure the overlap back down.
wschruba is offline
Old 06-04-17, 07:10 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 1979 Post(s)
Liked 325 Times in 234 Posts
I haven't found that to be a problem. You don't need to completely remove the tape to replace a nipple; just lift it enough to slide the old one out, maybe a couple centimeters on either side of the spoke hole. And there's enough residual adhesive to hold it in place after you're replaced the tire.
JohnDThompson is offline
Old 06-04-17, 08:22 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6980 Post(s)
Liked 345 Times in 269 Posts
Likewise, I've had no bugger up like that..
I have gotten to like fused loop stiff plastic rim tape... it comes off without adhesive,
For the rear wheel of my single wall Brompton rim,
I made up a shortened rubber rim tape to put beneath the stock plastic loop, not a flat caused like that , cause, so glaringly obvious,
but it cured what was causing my rear flat.
fietsbob is offline
Old 06-04-17, 08:36 AM
sweeks
sweeks's Avatar
Quoted: 561 Post(s)
Sometimes a thicker rim strip makes tire installation more difficult. Something to consider.
Steve
sweeks is offline
El Gato27
Bicycle Mechanics
21
08-01-18 07:11 AM
Teamprovicycle
Bicycle Mechanics
4
07-29-18 07:51 AM
Aubergine
Bicycle Mechanics
15
07-06-18 10:05 AM
illusiumd
Commuting
24
07-06-15 02:44 PM
Barrettscv
Bicycle Mechanics
57
11-02-13 04:02 PM
