How to remove this freewheel(?)?
Old 06-07-17, 10:24 AM
underwaterbiker
Quoted: 8 Post(s)
Hello,
newbie here
I want to fix my bike, put a 7 speed freewheel on it, but first want to know how to remove it.
I've watched a bunch of videos and browsed through Sheldon Brown's website and still can't figure what what freewheel tool do I need
I attached photos
can anyone tell me how to remove it properly? I want to clean it out and then use it a bit before putting a 7 speed on there.
Also to note, there are only 6 bearings per-side! Is that normal? Aren't there supposed to be enough evenly spaced to fill the cervices?
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
underwaterbiker is offline
Old 06-07-17, 10:43 AM
wschruba
Quoted: 465 Post(s)
You are looking at an early Uniglide cassette, not a freewheel. You hold the sprocket stack near the rear with a chainwhip, and use a second chainwhip to unscrew the smallest sprocket, allowing the rest to slide off. You would need to find either a 7 speed Uniglide cassette (difficult to find, now), a 7 speed first-position uniglide sprocket/modify a modern 7 speed cassette to fit, or replace the hub/wheel altogether for a modern setup.
*edit*
There is a "7 index" visible on one of the sprockets, so it is likely that someone removed a couple of them at some point...
wschruba is offline
Old 06-07-17, 11:19 AM
bikeman715
bikeman715's Avatar
Bikes: Bike Nashbar AL-1 ,Raligh M50 , Schwinn Traveler , and others
Quoted: 85 Post(s)
There should be 9 !/4 '' bearings in each side of the hub , Replace with new bearing and grease . As wshruba said use chainwhips to remove the cogs , at this point when you remove your smallest cog the rest of them will slide off . To remove the freehub all you need id a 10mm hex , put it in the hub to remove the bolt ,once you do that the freehub will come off .
bikeman715 is offline
Old 06-07-17, 12:38 PM
hueyhoolihan
Quoted: 86 Post(s)
if you are lucky you may be able to purchase (and use your existing hub and rim) a newer hyperglide freehub. they can be had for under 25 dollars on the web. like this one
don't let the description fool you. it'll work on pretty much any shimano freehub type hub. except for some very early ones, which is why i mentioned 'lucky'.
hueyhoolihan is offline
Old 06-07-17, 12:53 PM
Dave Mayer
Quoted: 679 Post(s)
Liked 52 Times in 35 Posts
To the OP: ignore the previous postings.
You have a first-generation Uniglide cassette hub. It is press-fit onto the hub shell. It cannot be replaced. There is no 10mm hex bolt, as in later generations of Shimano cassette hubs.
You can clean and relube the freehub without removing it; first you have to remove the axle/cones/balls. Use a solvent such as varsol/kerosene to strip the gunk out of the freehub body, and then after waiting a day for the solvent to evaporate, relube with a medium-weight oil.
You may be able to fit 7 cogs onto the freehub, provided you use 7-speed spacers, and the 7-speed threaded first cog. This cog looks like the 6-speed version, but it is narrower.
You should be able to reuse most of your existing cogs; if they are worn: flip them over.
Dave Mayer is offline
Old 06-07-17, 12:59 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6981 Post(s)
Liked 352 Times in 272 Posts
the last cog unscrews from the driver body (2 chainwhips) then the splined cogs slide off..
they made the early cassettes sort of like freewheels, 2 chain whips took those apart too,
the freewheel remover is a separate tool
Usually people with freewheels think they have cassettes..
fietsbob is offline
Old 06-08-17, 12:07 PM
underwaterbiker
Quoted: 8 Post(s)
I noticed that too. I wonder if it was sold like that. There is a rubber ring around it. made me really curious.
You think it will be too much work ? Hmmm, going to scour the internet. I saw conversion guides
You have a first-generation Uniglide cassette hub.......
shot, good to know. How can I tell if it's 1st generation? I need to do further research.
Could I buy a 7 speed cassette and add them to my existing Uniglide cassette?
Okay, I'll get 9 of 1/4" ball bearings. Also, buy those chainwhips. Hopefully I can find them locally for cheap
Old 06-08-17, 01:50 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 895 Post(s)
Liked 132 Times in 99 Posts
You need 9 balls per SIDE.
You don't need a chain whip (now) because the smallest cog is already off!
To put it back on, you just screw it on and pedaling will tighten it.
Bill Kapaun is offline
Old 06-08-17, 02:56 PM
bikeman715
bikeman715's Avatar
Quoted: 85 Post(s)
Bill Kapaun, he might still need the chainwhips to get the first clog (in his photos ) to come off then the rest will slide off . I thought the poster understood 18 bearings since I pointed out to him 9 preside . but reading his respond I guess not
Old 06-09-17, 09:40 AM
underwaterbiker
Quoted: 8 Post(s)
Okay,
I get 18 of 1/4 steel balls during this weekend.
I have time off to do more research and see how much I can mod my bike
TimeTravel_0
Bicycle Mechanics
15
10-15-19 09:21 AM
Kars
Classic & Vintage
32
02-21-19 05:56 AM
sushiboy21
Bicycle Mechanics
7
05-26-15 09:30 PM
Tuffenough
Bicycle Mechanics
6
03-18-14 10:18 AM
prettyshady
Classic & Vintage
4
06-22-10 04:52 PM
