How to move my crank away from the bottom bracket?
I have a square taper BB in a Mtn bike frame.
Crank I have is like a 46t.
It is too close to the frame. The teeth rub up against the frame.
How do I space it out?
Quoted: 86 Post(s)
this, or google "bottom bracket spacer". of course it will shorten the other side.
Mad bike riding scientist
Quoted: 6215 Post(s)
Liked 4,213 Times
You need a longer spindle on the bottom bracket. Square taper bottom brackets are cheap so it shouldn't break the bank.
Stuart Black
Stuart Black
Quoted: 427 Post(s)
Liked 339 Times
As an additional option you can also shim it out a very small amount with paper thin metal shim stock bent to cover two sides of the spindle. At the very shallow angle it has insignificant impact on concentric but can push outward the crank by a sixteenth or two. You cannot shim it nearly as much as changing spindle though. Our tandem crank was shimmed his way and we did not even know it until we took it apart for maintenance. We assembled initially without the shim and derailleur was out of adjustment. We reassembled with the shim and it was in tune again. I'd say the shim moved it out about 3/32 but that is just a guess as we never measured
Bikes: 2009 Masi, 2014 Specialized Crossroads 1975 Schwinn Unicycle
Quoted: 12 Post(s)
Also the number of teeth of your big chain wheel, can make it tough to get the crankset close to the frame. With some MTB frames, the chainstays really flare outward. Don't forget to adjust the front derailer when done. Chris
