Is a kickstand on a road/racing bike Blaspheme ?
Old 10-29-14, 07:10 PM
CNC2204
Im not doing it but just wondered.
CNC2204 is offline
Old 10-29-14, 07:14 PM
rpenmanparker
rpenmanparker's Avatar
Quoted: 6514 Post(s)
Liked 29 Times in 23 Posts
Yes. They are heavy, ugly and unnecessary.
Robert
No matter where I go, here I am...
rpenmanparker is offline
Old 10-29-14, 07:19 PM
kc9eog
kc9eog's Avatar
Bikes: Trek 1.1, Electra Ticino 7D
I have one on mine, the only other person I know with one is my brother.
kc9eog is offline
Old 10-29-14, 07:21 PM
jwarner
Fahrradfahrer
jwarner's Avatar
Bikes: n+1
Only if you also don't run a squeeze horn, bolt-on lock, one of those license plate nameplates with your name on it, and fancy handlebar streamers.
It's OK with all that stuff.
jwarner is offline
Old 10-29-14, 07:35 PM
Sullalto
Bikes: Jamis Quest Comp
Quoted: 169 Post(s)
Do touring bikes count as road bikes?
Sullalto is offline
Old 10-29-14, 07:38 PM
canam73
Quoted: 5 Post(s)
It's your bike. Set it up however it works best for you.
canam73 is offline
kbarch
kbarch's Avatar
Quoted: 1096 Post(s)
No, but the idea is heresy.
kbarch is offline
Old 10-29-14, 07:47 PM
IntelXE
I've had a kickstand on my commuting bike but I only parked it in those bike stands so I never used it. For a racing bike, I would think it's unnecessary.
IntelXE is offline
Old 10-29-14, 07:48 PM
beatlebee
Bikes: i may have bike(s)
Quoted: 46 Post(s)
2015 bikes don't need kickstands, DA 9000 and all.
beatlebee is offline
Old 10-29-14, 07:58 PM
Reynolds
Passista
Reynolds's Avatar
Quoted: 535 Post(s)
Liked 102 Times in 71 Posts
It's just not done.
Reynolds is offline
Old 10-29-14, 08:06 PM
JeremyLC
JeremyLC's Avatar
Bikes: 2008 Surly Cross Check, 2010 Fuji Track Comp
Quoted: 255 Post(s)
That depends, is it a crabon fibre kickstand?
JeremyLC is offline
Old 10-29-14, 08:11 PM
bengreen79
Allez means go.
bengreen79's Avatar
Yes...https://www.kickstarter.com/projects...54/the-upstand
bengreen79 is offline
Old 10-29-14, 08:22 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 925 Post(s)
Liked 163 Times in 135 Posts
Those asplode, then the bike will fall over.
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Homebrew01 is offline
Old 10-29-14, 08:39 PM
Kai Winters
Bikes: Merlin Ti
Quoted: 10 Post(s)
I have one on both sides...depends on what side I'm leaning towards on any particular day and I'm covered.
Kai Winters is offline
Old 10-29-14, 09:36 PM
spdracr39
spdracr39's Avatar
Bikes: Lynskey Twisted Helix Di2 Ti, 1987 Orbea steel single speed/fixie, Orbea Avant M30, Trek Fuel EX9.8 29, Trek Madone 5 series, Specialized Epic Carbon Comp 29er, Trek 7.1F
Quoted: 12 Post(s)
Yes
spdracr39 is offline
Bunyanderman
Bikes: NeilPryde Alize Raleigh Misceo 2.0
Quoted: 5 Post(s)
Keeping up with another rider with a kickstand should be humiliating for the other rider. You prove that strength beats weight.
Bunyanderman is offline
Old 10-29-14, 09:57 PM
ChargerDawg
ChargerDawg's Avatar
Bikes: Madone 5.9, Sequoia, World Sport
I don't mind a kickstand, I have one bike with one. It depends how much you stop and get off your bike when you ride it. It seems silly to have a carbon fiber machine fall over and you generally cringe when that happens.
ChargerDawg is offline
Old 10-29-14, 10:00 PM
k_kibbler
k_kibbler's Avatar
Bikes: Canyon Ultimate CF SL
Quoted: 13 Post(s)
I used an Upstand for a while, then stopped. I hated that the attachment point (the metal bit clamped in the rear skewer) gets torqued around by the attached stand itself if there is any forward-backward movement while the bike is leaning on the stand. The metal piece has radial serrations to keep it in position, but unless your QR is locked very (very) tightly, all it does is chew up paint around the dropouts.
k_kibbler is offline
Old 10-29-14, 10:59 PM
coasting
Still can't climb
Quoted: 10 Post(s)
I wish I had one. But I would be scared to ride with one because of all the sneers I would get.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
coasting is offline
Old 10-29-14, 11:01 PM
coasting
Still can't climb
Quoted: 10 Post(s)
My carbon bike has several times been blown over when leaning against a tree. I watched it happen once, just out of reach and something inside me died.
coasting is offline
Old 10-30-14, 12:20 AM
ooga-booga
lead on macduff!
ooga-booga's Avatar
Bikes: come and get 'em
Quoted: 549 Post(s)
Liked 211 Times in 122 Posts
not gonna lie. once, just once, i wanna install curb feelers on the road bike and go for a century ride in a busy cycling area.
ooga-booga is offline
Old 10-30-14, 05:31 AM
rpenmanparker
If a CF bike can't take falling over, that is one you don't want to ride.
Robert
Old 10-30-14, 05:43 AM
bruce19
bruce19's Avatar
Quoted: 1070 Post(s)
Liked 327 Times in 193 Posts
Yes
bruce19 is offline
Old 10-30-14, 07:04 AM
jerrycan42
Cripes, just lean it carefully against something, but if you must lay it on the ground, do so gingerly and keep the drive side up....
jerrycan42 is offline
Old 10-30-14, 07:05 AM
JeremyLC
JeremyLC's Avatar
Quoted: 255 Post(s)
Originally Posted by bengreen79 View Post
Because OF COURSE there would be...
JeremyLC is offline
