wheel size question
wheel size question
Old 05-03-10, 04:07 PM
rgoo92
wheel size question
someone told me that your rear wheel is always bigger than your front wheel.
is this true?
my front wheel is a 700x 23
should my back wheel be a 700x23 or like a 700x35
does it matter if theyre different? or should my tire's width/size be exactly alike?
rgoo92 is offline
Old 05-03-10, 04:12 PM
sooprvylyn
I suck, but you're worse
Bikes: Motobecane Fantom Uno-Got rid of the rest when I moved to LA:(
Actually it depends on the riding you do.
Some keep same size front and back-usually for regular road riding they are the same
Some put fatter rear tires- Nice for better traction and power transfer
Some put the fatter tire up front- Better for steering in loose soil.
Its up to personal preference more than anyting
sooprvylyn is offline
AEO
AEO's Avatar
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times in 5 Posts
doesn't really matter.
normally they're both the same size.
more here:
https://www.sheldonbrown.com/tires.html#mixing
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Old 05-03-10, 04:13 PM
JiveTurkey
Low car diet
JiveTurkey's Avatar
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
Liked 4 Times in 4 Posts
Read this: https://sheldonbrown.com/tires.html#mixing
Edit: Since my post didn't add anything. I'll say that if I run different-sized tires, I will put the larger on the front for better traction and shock absorption, and the larger tires take lower pressures (and I always run about 10% lower in front compared to rear).
JiveTurkey is offline
rgoo92
nice dude perfect answer helped alot!
i have a fixed gear with a 700x23 up front! i wanna do some distance but also alot of skidding and stuff haha. ill always be riding on the street
what would you recomend?
edit: just saw last 2 posts. reading sheldon brown now
rgoo92 is offline
Old 05-03-10, 04:22 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Personally, I'd recommend getting a brake and saving your tires.
(But if you insist, you can put a 25 on your rear and a 23 on the front. I've done with with my road bike and I like this combo a lot.)
caloso is offline
Old 05-03-10, 04:26 PM
AEO
AEO's Avatar
for skidding... just use whatever will fit and cheapest on the rear.
AEO is offline
Old 05-03-10, 04:28 PM
sooprvylyn
For skidding I recommend some Specialized Armadillos- They are pretty cheap and super thick so there is plenty of tire to wear off before they need replacing.
If you like your knees and prefer to continue to use them late into your life you should use a brake instead.
edit:Also if you plan to skid stop use at least a 25-28mm wide tires, it will slow you down a bit faster than a 23mm will
Old 05-03-10, 06:08 PM
rgoo92
well the back tire im picking up is 35mm wide..
you think using a 23up front and a 35 in back is too weird/ big of a gap?
rgoo92 is offline
Old 05-03-10, 06:15 PM
sooprvylyn
Here is what I'd be concerned with:
Are you using a track/fixie frame? If so then the rear spacing will probably not let you go much bigger than 28mm wide tire. If you get a 35mm(which is almost a MTB tire width) you will likely run into problems with frame clearance at either your chainstays, seatstays, brake bridge or seattube. In other words a 35mm wide tire is very likely to rub the frame if it is a track frame.
Unless you are running a 29er, hybrid, cyclocross frame I wouldn't try to fit anything larger than a 28mm tire on, unless your track end openings are like 3cm long.
So its not really the gap that is the problem, if you can fit the fat rear on the bike then go for it, but I'll be surprised if it fits.
Old 05-03-10, 06:17 PM
sooprvylyn
If you've already purchased the tires then you can try putting the 35mm on the front as forks tend to have a bit more tire clearance than the frames do
Old 05-03-10, 06:49 PM
rgoo92
very informative, thanks!
no i can either buy the wheel with or without the tire. i recently learned taht 700 wheels can carry a wide array of different sized tires which works out better for me
yes i will be using a 54 sized frame w/ horizontal dropouts for my project
my curretn wheelset is a pair of 700x23cc and i think i have to use the new wheel 700,35 for the back wheel because its the one with the fixed hub.
im going to either use my 23 tire/tubes form my old wheel onto my new fixed rear wheel or buy a 25
rgoo92 is offline
Amt0571
Bicycle Mechanics
15
08-15-18 11:59 AM
FFMan
Classic & Vintage
4
04-19-17 01:23 PM
hybridbike
Hybrid Bicycles
24
08-11-13 03:24 PM
earthworm94
Commuting
11
07-13-12 05:15 PM
slipknot0129
General Cycling Discussion
1
07-31-10 09:52 PM
