Standard Sprocket size for a 17" rear wheel
Hi all,
I'm looking for what is the standard sprocket size for a 17" rear wheel. I saw two wheels earlier and they had the same sized sprockets (different manufacturers) and just wanted to know the diameter of the sprocket that you would use on a 17" (420mm) rear wheel
er, what hub do you have in the middle of that wheel?
sprocket choice is about the Gear ratio, so what size is a function of what gear ratio you wish too
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
A 17" wheel? I have heard of 12, 14, 16, 18, 20, 22, 24, 26, 27, 28 and then metric but never a 17.
I do with Bob we need more information. is this a FG?
Sugar "Kane" Kowalczyk
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Don't know about current models, but the Lightning P-38 (recumbent) and some Moulton bicycles have used 369 - 17" wheels (front wheel only on the P-38). Sheldon lists that size.
OP says 420 so more info is needed.
Insane Bicycle Mechanic
Quoted: 806 Post(s)
Liked 708 Times
17" x 1 1/4" (ISO 32-369) is standard on Moulton bikes and the front of older Lightning recumbents like the one in my garage.
I agree with the others- there's no such thing as a "standard" size sprocket. It depends on the hub, the intended use, and size of the chainwheel, among other factors.
Jeff Wills
Jeff Wills
Quoted: 1572 Post(s)
Liked 643 Times
Bianchi Goddess
Liked 2,926 Times
More importantly the OP has not checked back in to give us more information.
Quoted: 2026 Post(s)
Liked 1,096 Times
I had never heard of 17" wheels either and that's new info to me too. Accoring to Sheldon Brown's list there is no ISO 420 rim. The closest is ISO 419 used on some Schwinn kids bikes and was called a 20".
Quoted: 806 Post(s)
Liked 708 Times
Actually, the words "standard" and "bicycle" pretty much don't go together. There are a few components that are standardized to the degree that there are only 2 or 3 possible sizes but that's just to lure you into thinking you can order ANYTHING without either measuring or knowing exactly what you have.
Yeah, well, it was worse in the Olde Days (stolen from C&V):
Jeff Wills
Jeff Wills
Quoted: 806 Post(s)
Liked 708 Times
Yeah, that was the case on the thread where I stole the Canadian tire scans from. Someone was trying to figure out the tire size for an old Free Spirit, after throwing the old tires out. Probably 26 x 1 3/8 (EA3), I think.
Jeff Wills
Jeff Wills
