Unofficial Bonehead Moves Appreciation Thread
#76
For those interested (I know I was)...
If anyone else reads the Mechanics section, there was recently a guy who tried to fix some cracks in his head tube with epoxy, wire and fiberglass. That is another interesting read
#77
Quoted: 659 Post(s)
Liked 595 Times
https://www.bikeforums.net/bicycle-me...heel-fire.html
#78
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I didnt much care for the plastic thing that prevents the chain from going over the highest gear
Real cyclists use toe clips.
jimmuller
jimmuller
#79
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
I'm almost to embarrassed to post this, but the other day I wasnt paying attention as I removed a left crank arm off a bike. Apparently I had forgotten to remove the crank arm bolt first and the arm puller did a very nice job of pulling the threads right out of the aluminum arm.
Fortunately I was tossing the arm anyway, but man if this had been a nice higher-end crankset I would've seriously cried.
#80
My last build I was putting a bb and crankset from a 87 Ironman on an 89 Ironman and wasn't sure which spindle was the long /drive side and it was really worrying me. But I figured I had a 50-50 chance getting it right. After putting it on I realized I put the wrong side spindle in, so uninstalled reversed spindle, buttoned it all up, same thing. What gives? So I checked it to my other Ironman and the chainring was closer to the chain stay than my other ironman and no way the chain could fit between the chainring and chainstay . And to make things worse when I'd spin the crank arm some spots were closer than others. So I go to harbor freight and get some measuring calipers. Uninstalled bb and crankset again, Measure and no detectable difference in the bb spindle sides. ??? So I go to the Centurion thread and ask what gives? Answer: Your chain is never gonna be between chainring and chainstay. Doh! And the size spindle I was using doesn't have a long side. Doh! As for the wobble? I figured that out myself, I had to tighten up the the chainring bolts. Doh! So reinstalled bb and crankset again.
Before that I had only done a couple of bb installs now I'm experienced.
#81
52psi
Quoted: 790 Post(s)
Liked 802 Times
#82
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
The one that haunts me... I've put long boards and poles in the rafters of the garage. I didn't take into account that the rafters may vibrate when the garage door is opened and closed. One day I go out to the garage and see a 4 foot long 2x6 sitting in the center of the garage - I figured the kids were digging around and didn't put stuff back. I grabbed my Voyageur SP and rode to the bike shop. While I'm there, I had one of the kids put my bike in the stand and look at something for me. He even makes a comment about how pristine the bike is. I ride home, park the bike while I open the garage, as I'm walking back to the bike, something doesn't look right... and there's a dent about the size of a dime on the top tube, just forward of the center TT cable guide.
After thinking about it, the 2x6 must've fallen out of the rafters and clocked the top tube... I was actually sick to my stomach.
So easily preventable, but...
I was just working on that bike last night - threw on a Stronglight 99BIS - I think it'll work out nicely on that bike. Now about fixing or concealing the dent so my eyes aren't drawn to it as I ride.
Commence to jigglin’ huh?!?!
#83
Quoted: 2588 Post(s)
Liked 4,824 Times
I got about 5 miles before I saw this:
Made it home safely
DD
Made it home safely
DD
#84
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
"Fire is cool, but not as a bicycle tool."
#85
Quoted: 140 Post(s)
Liked 13 Times
In hurry one day, one crank arm was really really hard to get off - then a big pop and and the arm came off - as I removed the crank puller, I discovered the nut under the crank puller! Lucky it wasn't a bolt type
#89
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I was fine tuning the curve of my rear brake cable over the seat lug, so I trimmed a bit off the end of the cable housing, while leaving the cable in the housing.
I received a (fortunately cheap) dynohub from a UK seller, it was poorly packaged, and a flange was bent. I was too impatient to return it, so I put the flange in my bench vise and snapped it clean off.
#91
Must be that time of year. I just did the same thing.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
#92
I disassemabled a recent purchase of early 80s Peter Mooney to re-grease everything. (I have two children, so I get interrupted to attend to them for various things.) I offten forget where I left off with my bike repairs. So, I am riding a week later. The chain keeps rubbing the front derailleur. When I get home I check it out. I never tightened the bolt holding the crank on the drivetrain side. Also, discovered I never tighten the bolts holding the rings to the cranks.
#93
52psi
Quoted: 790 Post(s)
Liked 802 Times
Been looking at this off and on all day. "What am I missing?" First I thought it was a hilariously subtle take on the much-maligned Campy sidepulls. Then I thought maybe the quick release was left open, but didn't look like that was the case. Too high and braking on the tire? That's just silly; must be the Campy thing. And so it went.
Nine hours later I finally see what you did.
#94
Quoted: 1627 Post(s)
Liked 630 Times
^ I caught it right away. Because I've done it too.
Had a block start walking out on me, but I caught it before it came out all the way.
#95
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
#96
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Edit. I think it was my arsehole friend who released my front QR but no one ever copped to it. It's what 17 year olds do.
#97
Liked 4,824 Times
Glad I could provide you some Friday night entertainment
DD
#98
Liked 4,824 Times
Yes, 1975. Went off of a curb. My first decent road bike, an Orbea with Zeus Alfa components. I yelled 'Evel Knievel' and got a foot of air. Wheel disappears from sight, forks hit the pavement, face slams and scrapes the road for five feet. 3 front teeth ground down to the nerves. 27 shots of freezing in emergency. Still have a partial plate to this day. Worst. Night. Ever.
DD
#99
52psi
Quoted: 790 Post(s)
Liked 802 Times
@Drillium Dude No arrows. It was like Where's Waldo? or something. Notice I deliberately didn't say what I finally saw. Maybe somebody else can play tomorrow. hahaha
#100
Liked 4,824 Times
DD
