Should I wear a mask?
Quoted: 6193 Post(s)
Liked 4,809 Times
If you have more surface area in a filter of any sort, then more volume of air can flow through. More volume passing through at any one moment means easier breathing. Pleats give you the ability to have more surface area in the same space compared to no pleats.
I thought I'd already mentioned that sweat or any wetness will significantly reduce airflow whether pleated or not. So anyone wanting to wear a mask should take several.
