Downtube Shifters
Bikes: Bianchi Brava 1986-1987
Quoted: 14 Post(s)
Downtube Shifters
Are downtube shifters hard to use, just bought a bike that has them.
Quoted: 4806 Post(s)
Liked 3,930 Times
No. There is a learning curve but it is not difficult. You will find you can feel as well as hear when the chain shifts and when it is in good alignment with a cog. (There is far less housing and no mechanism inside the lever so the connection between the derailleur and your fingertips is quite direct.)
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Not hard at all, just takes a little practice.
Car dependency is a tax.
Bikes: Trek 460, Trek 1420, Schwin High Sierra
Quoted: 16 Post(s)
Liked 15 Times
Are they friction shifters or indexed? Indexed are easy to operate. Friction take a bit more practice and maybe a bit more planning ahead to avoid panic shifting.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Maybe go ride it and then you'll know.
Bikes: One of each: Road, Hybrid, Trekking
Quoted: 137 Post(s)
Liked 115 Times
I like ‘em! More direct control of the shift. I feel a better connection with the bike. It’s the same reason I like driving stick shift sports cars.
Aside from not being able to shift while riding out of the saddle, they're not really at much of a disadvantage compared with other shifter types on road bikes. For double-shifting (shifting front and rear simultaneously), they can actually be pretty nice, since you can actuate both shifters with one arm movement. Overall I do prefer bar-end and integrated shifters, but it's not like I never ride my bike with downtube friction levers.
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 336 Post(s)
Liked 782 Times
When compared to my three bikes with modern Campy Record, downtube shifters seem like a royal pain but when I simply enjoy my vintage bikes for what they are, I actually enjoy downtubes a great deal.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Not hard to use. Finding them without looking down will take a few rides to get used to. I hook my thumb on the top tube so I'm not just stabbing at the air reaching for them.
Likes For c_m_shooter:
Quoted: 1572 Post(s)
Liked 643 Times
How tall are you? Assuming the bike is sized appropriately, the taller you are the farther you have to reach down for down tube shifters.
What's your riding style? If you are a top of the bar rider, shifting will require a greater amount of body movement.
Likes For Retro Grouch:
No complaints here. Easy to get the right gear; like was posted earlier, you can tell by feel and sound when you have it right. If not, just adjust.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
DT shifters are fine until the Italians get you.
Likes For mack_turtle:
Note to self: Stay away from anyone on a Colnago!
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I have ridden using downtube shifters since the early 1970s. As others have said, there was a time when friction shifting on the downtube was the most common type on better bicycles. Bar end shifters were also in use, even by professionals. We all learned to use them because we didn't know anything else. There were subtle differences between brands in how much you had to "overshoot" the downshift (toward the larger cog), and then back off the lever. I'm looking at you, Campagnolo, and to a lesser extent SunTour. This had to be done by ear and by feel.
Fast forward to the mid-to-late 1980s when indexed shifting emerged, and that made a marginal improvement in how rapidly one could move across the rear cogset. Then the shaped teeth on the Hyperglide style freewheel changed everything. The chain jumped and settled onto the correct cog very quickly with less fiddling, even using friction shifters.
I have three friction shifting bikes now: two on the downtube and one with bar ends. They're fine for what they are, and are enjoyable to ride.
But after saying all of this, I prefer STIs for their ease of use. This is especially true in cold weather with cumbersome gloves or mittens. Plus, with added hats, and layers on the head, it's tougher hear the mis-adjustment of slight errors in friction shifting. With indexed shifting, you don't worry about that as much, if at all.
Quoted: 3352 Post(s)
Liked 1,056 Times
Not hard at all. And there are advantages, such as very little housing to wear, so shifting adjustment are few and far between. And it makes the bike much cleaner without all the cable housing flapping around.
They were around in the late 80s, and to my mind with down tube shifters, and lugged frames, it was a zenith in bikes.
I am 6'4" and do not find it to be an issue. The taller you are, the longer your arms are to reach the shifters.
Likes For bikeaddiction1:
Quoted: 1944 Post(s)
Liked 2,164 Times
I still use downtube shifters, but went to index from friction in 2015. I have used STI’s and they are better, but downtube can be fun. They work well with a triple crank and massive gear changes can be down quickly.
I changed to index for those times when transitioning from downhill to a quick out of the saddle uphill and hitting the downshift perfectly. As I’ve gotten older I need more of a downshift and I wanted the shift to be there.
What I find interesting about downtube shifters is the right or left hand shift technique. I learned to use my right hand for the right shifter and left for the left. But there are those that use their right for both and reach across.
John
John
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
Downtube shifters aren't difficult they just require some getting used to and a little riding skill but the shifters themselves are the best for usability. If you do find that you want to move your shifting up towards the bars which is not a bad thing these will help: https://www.gevenalle.com/product/audax/
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
I grew up with downtube shifters, or worse, those friction shifters on the stem. Fast forward to the mid 90s, and I bought my first bike with indexed shifting. Then fast forward to the mid 2000s, and I kind of felt the desire to go back to downtube shifters, so I bought myself a mid 80s Schwinn LeTour Luxe. I tried to love it. Really. But after 2 seasons of riding that bike, I went back to my 90s era Bianchi hybrid, and eventually, a modern bike with brifters. I won't ever go back to downtube shifters.
Likes For MRT2:
I really like modern indexed shifting at your fingertips where you don't have to let go of the bars in a technical situation in order to shift. That being said, downtube shifters work very well, cost a whole lot less, need almost no maintenance, and never leave you unable to shift because they just don't break down.
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 163 Times
Not hard at all. It's also nice to line up the RD perfectly with older DT shifters. You cannot fine tune a shift up/down with STI's like you can with DTs.
The only bad part is making sure you shift to the gear you need before a hill. Shifting gears with DTs on an uphill climb isn't the best.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I found friction shifting kinda nice on long distance rides. If for some reason the derailleur is a slight bit out of adjustment or the cables stretched on you or what ever. You can still shift without annoying clicking/chain rub etc.
It is just as hard on your drive train when shifting under load with modern indexed shifters. The derailleur doesn't know what type of shifter you are using. You just don't feel it in your fingers as as much as you shift with modern indexed shifters.
