Rear rack help needed!
Does anyone have any advice or recommendations for a steel rear rack? I gotta trek 920 that came with weak aluminum rear bontrager rear rack and it cracked about a year ago... and they replaced it with a new one. and that just cracked! So i'm in the market for a Steel rear rack, disc brake compatable. The frames got NO eyelits. Was looking at the Surly Rear Rack and the Surly Rear Disc rack as well. But not sure they are compatable. Would P clamps make it work? Thanks for taking the time to read this and help
Likes For Atlas Shrugged:
Likes For phughes:
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Agreeing in going steel. I also reccomend Tubus.
In time, I break anything made of Aluminum
Likes For Toadmeister:
A 920 with no eyelets? Did that change with the model year? I have one on order that will have two sets of rear eyelets, for a rack and fender.
Quoted: 529 Post(s)
Liked 255 Times
I have an aluminum rack which also broke. I have repaired it so I can use it for now.
I am thinking of making the next rack myself. If you make it yourself, you can make it how you want.
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
I've used an aluminum Blackburn rack for many years with no cracks. And hauled stuff on it too!
If you're eyelets are not where you need them you could go with a strap on type design, like THULE' (see pick below). It'll strap on to forks or seat stays or any other way you can figure it out. It's rated for 50lbs, I believe. Which I guess means your frame will bend before the THULE' rack does.....
Quoted: 18403 Post(s)
Liked 15,495 Times
So where are the attachment points? This version clearly has eyelets on the seatstays.
https://www.trekbikes.com/us/en_US/b...0/920/p/21996/
Quoted: 1034 Post(s)
Liked 1,289 Times
Just get a seat post clamp with rack mounts. Salsa makes one. Many make them. https://salsacycles.com/components/c...lars/rack-lock
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Liked 15,495 Times
I still want to know what the OP's rack that came with the bicycle was attached to if there are no eyelets on the seatstays as pictured above.
Quoted: 1246 Post(s)
Liked 1,321 Times
Liked 15,495 Times
[url=https://bikepacking.com/bikes/trek-920-review/]Trek 920 Review - BIKEPACKING.com
Sorry, but this thread makes no sense without a proper explanation. Part of me is thinking the "ghost" of SB.
Likes For indyfabz:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Another huge vote for Tubus. Probably some of the best non-custom steel racks on the market.
Liked 15,495 Times
Calling double
Likes For indyfabz:
Liked 15,495 Times
Likes For indyfabz:
Half way there
Quoted: 985 Post(s)
Liked 879 Times
I commuted for many years with a 30+ years old Blackburn aluminum rack and it performed wonderfully despite routinely carrying up to 40 lbs. Still in service, too. You get what you pay for.
