27.5/650b Street/Multi-Use Tire Recommendation
Old 09-10-16, 07:17 PM
DarKris
DarKris's Avatar
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times in 54 Posts
I wanted to ask around and see if anyone had a recommendation for a fast 27.5 tire between 1.75/2.0. I plan on using these tires with a set of wheels that I got to convert my CX bike to 650b. My only issue is that my max tire clearance is 50mm/2 in.
I also want to get recommendations from those who know the actual width of their tires. The last pair of tires that I tried were the Vittoria Revolution G+ tires which has a size rating of 50-589. Idk if it's because of my 21.5mm wide rims but tires were 53mm wide and did not fit my fork.
I was looking for a tire that was between 45 - 50mm wide, but not wider (Under-sized 2.1 tires would be nice as well). Also if the tires were around $40 or less that would be ideal. Thanks.
DarKris is offline
Old 09-11-16, 07:23 AM
Spoonrobot
Spoonrobot's Avatar
Quoted: 1217 Post(s)
Liked 187 Times in 118 Posts
I think most 650b non-knobbie tires are going to be up to 42mm or 47mm+.
I'd recommend the switchback hill from compass but the on paper rating of 48mm wide has been shown to be a little conservative and they are closer to 51-52mm so they probably won't work for you.
Which kind of leaves you with one option in the 47mm WTB horizon. It's pretty true to size so it should work for your fork.
Course $40 price point is going to be a problem. Barring any sales, tires at that price point are not going to be "fast" and most likely perform noticeably worse than the $59+ offerings.
*I only know about smooth tread tires. Any of the knobbie or hybrid styles I'm not up to date on.
Spoonrobot is offline
Old 09-11-16, 07:41 AM
mongol777
Bikes: are all mine
Quoted: 179 Post(s)
Liked 42 Times in 24 Posts
Surly Knards, Tires | Parts and Accessories | Surly Bikes
I have them in 700x41, 26x4.8 and 29x3, excellent all round tire.
mongol777 is offline
Old 09-11-16, 08:31 AM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
I guess I'm not looking for a pure slick tire. I would say more of a semi-slick or a knobby (more micro-knob) that is exceptional on pavement.
Another thing that I would prefer is a tire that's around 30-60 tpi, leaning more towards the 30. I know these tires are heavier and less supple, but I have had problems with glass getting in to my tires and it's a pain constantly checking my tire.
In addition because of my weight I have to run my tires pretty high to avoid pinch flats/damaging my rim. With this my rear tire gets worn out fast, at least I notice it more with 60tpi tires (I can't imagine being able to run a 120tpi tire for more than 3 months).
DarKris is offline
Old 09-11-16, 08:38 AM
travbikeman
travbikeman's Avatar
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times in 123 Posts
I put these on my son's bike: Kenda K841A 27.5" Bike Tire | DICK'S Sporting Goods
The kid notices a big difference from riding his knobbies to these Kendsa on the road.
But the info stated it's 2 inch, but for some reason I had thought it was 1.9 inch.
Specialized also has this tire in a 650x 1.9, but it's a bit more knobby on the outer edges. It's more like a hybrid type of tire for trails:
https://www.specialized.com/us/en/co...reflect/117825
travbikeman is offline
Old 09-11-16, 08:57 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
compass cycles make high end spec 650B tires.
fietsbob is offline
Old 09-11-16, 12:45 PM
canklecat
canklecat's Avatar
Quoted: 4560 Post(s)
Liked 2,802 Times in 1,800 Posts
Look for a chevron pattern tread, like the Surly Extraterrestrial, Michelin Protek Cross or Cross Max (the latter has a bulletproof puncture resistant liner -- my favorite tire so far), Innova IA-2068-4 (cheap, often sold under the Schwinn name, very good -- got a new set with a recently purchased used bike), or the popular Schwalbes. A couple of the Schwalbes have remarkably good ratings for low rolling resistance despite the all terrain tread, and may well be worth the extra money.
I've ridden two different tire brands with virtually identical chevron patterns and they do remarkably well on everything from smooth pavement to grassy and weedy pastures to gravel trails, including tricky diagonal off-camber ruts and sandy washouts. Only thing I couldn't do was ride mud or climb loose dry black gumbo dirt slopes. But I don't do enough off-road riding to justify knobbies.
Also, the chevron pattern doesn't pick up bits of tiny gravel between the tread like the Specialized Hemispheres, which have tread blocks. The Hemispheres are smoother rolling, especially on tight curves, and can handle higher pressures, but I'm constantly picking out bits of pebbles. And while more supple (whatever that means) with thinner sidewalls seem nice in theory, in practice they're not very puncture resistant and I'm often checking for punctures by goat head grass burrs and shards of metal.
canklecat is offline
Old 09-11-16, 12:58 PM
jade408
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times in 44 Posts
I have Soma New Xpress tires. These are narrower than you are looking for but a good around tire.
38s are more like 35 actual. I run mine at about 80psi. Still experimenting. I have had them for over a year. Got one slow leak that got patched and no issues. The patch has been in place for 6 months.
We have load of potholes and glass in my neck of the woods. Streets are horrible.
My LBS picked them for the blend of durability / decent speed.
jade408 is offline
Old 09-11-16, 01:16 PM
DarKris
DarKris's Avatar
Quoted: 160 Post(s)
I appreciate the recommendations, but I can run 700x38c tires already on my bike. I'm specifically looking for 1.75/2.0 27.5 tires
DarKris is offline
Old 09-11-16, 01:25 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,472 Times in 2,079 Posts
Soma grand randonneur 650b x 42c is a quality heavy duty tire.
bikemig is offline
Old 09-11-16, 02:06 PM
dim
dim's Avatar
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times in 22 Posts
compass tyres .... the fastest, but not the most puncture resistant ...
https://www.compasscycle.com/product...ts/tires/650b/https://www.compasscycle.com/product...ts/tires/650b/
or if you want another good tyre in 650B that rolls ok, and has good puncture resistance, look at Schwalbe Marathon Supreme ... I have them fitted on my Bridgestone MB2 mountain bike (converted with drop bars and bar end shifters) and they are very good
dim is offline
3speed
Classic & Vintage
10
04-24-18 07:44 PM
ZepoL
10
07-21-17 10:29 AM
frantik
Classic & Vintage
60
05-06-17 06:01 AM
abdon
17
06-01-14 12:23 AM
southside
Bicycle Mechanics
4
08-20-10 12:39 PM
