Brilliant Freewheel Design...
Old 12-07-19, 01:02 PM
Last ride 76
1/2 as far in 2x the time
Last ride 76's Avatar
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times in 222 Posts
OK I was wrong. I am editing this post to remove my rant about engineers in general. It was dumb. The "in general part", specific truck issue maybe, but silly to generalize like I did. Someone took offense, and called me out on it, in a PM.
Ok, while I'm waiting for the PB Blaster to work so I can remove the hub locknut, someone please tell me why this freewheel was designed like this. I don't understand. Or perhaps just a who cares about you, anyway? (Truck batteries with almost inaccessible side mounted terminals runs right up there...) Does anyone remember Peter Cook's first appearance in Bedazzled? If anyone knows, please pass it on.
More revealed below...
Just brilliant, or am I really missing something?
WTF? Why?
Eric
Last edited by Last ride 76; 12-08-19 at 07:24 AM. Reason: Removing gratuitous foolishness.
Last ride 76 is offline
Old 12-07-19, 01:10 PM
Kuromori
Quoted: 237 Post(s)
Liked 83 Times in 64 Posts
Are you sure that's not just a uniglide cassette?
Kuromori is offline
Likes For Kuromori:
Old 12-07-19, 01:12 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26374 Post(s)
Liked 10,346 Times in 7,189 Posts
...this.
3alarmer is offline
Likes For 3alarmer:
Old 12-07-19, 01:40 PM
miamijim
miamijim's Avatar
Quoted: 413 Post(s)
Liked 109 Times in 78 Posts
Is no freewheel. And that may be a UG/HG hub. September 1988 would make that a 1989 model year cassette.
miamijim is offline
Old 12-07-19, 02:34 PM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1451 Post(s)
Liked 2,183 Times in 960 Posts
Absolutely a UniGlide cassette. The small sprocket threads on and off. OP will need two chain whips to remove.
Bob
pastorbobnlnh is online now
Old 12-07-19, 02:40 PM
machinist42
mycocyclist
machinist42's Avatar
Quoted: 908 Post(s)
Liked 811 Times in 448 Posts
Julie Andrews!
What everyone already wrote. I wanted the opportunity to "Julie Andrews!" is all.
"Mushroom" rounded/sloped nut suggests UG/HG, and a 130 spacing, but I can't see if there is interior threading.
machinist42 is offline
Old 12-07-19, 02:51 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
Brilliant, IMO. Just use two chainwhips in opposite directions to remove the top cog, and then the rest slide off without needing to remove the ratchet mechanism.
This particular design is a few years older than I am, so congrats on finally stumbling across one.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 12-07-19, 02:58 PM
Last ride 76
Bikes: Yes, Please.
Quoted: 499 Post(s)
Ignorant rant...
OK, I'm an ignorant git. One of the reasons I try not to go off on rants. I have 2 chain whips. Thx all!
The side mount battery posts on my truck still suck...
Likes For Last ride 76:
Old 12-07-19, 03:01 PM
miamijim
miamijim's Avatar
Quoted: 413 Post(s)
Oh, come on....side mounts FTW.
miamijim is offline
Old 12-07-19, 03:08 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I love UNIGLIDE cassettes. It's possible to remove the cogs with just one chain whip too. Leave the wheel on the bike, put the chain onto the largest cog, put the chain whip onto the smallest cog and it'll unscrew. If you have trouble getting the smallest cog loose you can fasten the crank arm to a chainstay by using a toestrap or other strong strap or even strong cord.
Another neat hing with UNIGLIDE cassettes is that when the cogs (other than the smallest one) get worn you can flip them over and they're almost like new.
Cheers
Miele Man is offline
Likes For Miele Man:
Old 12-07-19, 03:10 PM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 441 Times in 314 Posts
Ok, while I'm waiting for the PB Blaster to work so I can remove the hub locknut, someone please tell me why this freewheel was designed like this. I know few engineers consider the end users needs to be paramount.(This is obvious, considering the design of so many products.) But this beats most for a big middle finger to the user. Or perhaps just a who cares about you, anyway? (Truck batteries with almost inaccessible side mounted terminals runs right up there...) Does anyone remember Peter Cook's first appearance in Bedazzled? If anyone knows, pass it on. They were so worried about consumer backlash, there is no name on the freewheel...
WTF? Why?
Eric
The dust cap appears to be for a Shimano Uniglide freehub body. I don't believe it is a Dura Ace model because those said "Dura Ace" right on it and also had 2 little holes, 180 degrees from one another (that could be opened and closed) and then be used as micro grease ports to inject grease into the bearings with a micro grease gun.
If you are setting out to repack the wheel bearings, it is not necessary to remove the cassette cogs. All you need to do is to use your 15mm cone wrench and the correct locknut wrench and undo the non-drive side locknut and cone from the axle, then slide out the entire rest of the axle assembly from the drive side. You can then pull out the ball bearings and either remove the dust caps (carefully) or just leave the dust caps in place - your choice.
If you want to remove the cassette cogs - it is just as the others have said - use 2 chain whips and spin off the threaded outer cog. Then the remaining cogs merely slide right off the splines. Very ingenious and in many ways a more versatile, long lasting system compared to todays HG freehubs which use a Hyperglide lockring. I personally really love old Uniglide stuff. The removal of the freehub does require a special tool which is out of production but can be found on ebay at a premium price. I believe that some people have made their own cogged freehub removal tool or there may be a Chinese vendor making a knock-off that works.
masi61 is online now
Old 12-07-19, 04:25 PM
Last ride 76
Bikes: Yes, Please.
Quoted: 499 Post(s)
Ok Thanks, it all ties together. I had no idea that freehubs were available as early as they were. ("Apres moi, la deluge") The hubs are Shimano 6400 series as were the rest of the parts, on a Gios Nuovo Compact, except for the RD which was a budget Shimano unit with the pie plate size lower jockey wheel presumably to expand the potential gear range. Was thinking maybe a Victory group...on a Red Frame.
Old 12-07-19, 04:34 PM
Reynolds 531
Bikes: a few that I can't recall
Quoted: 342 Post(s)
Liked 299 Times in 146 Posts
I thread in 5/16 studs, bottomed out, and then a brass washer and brass nut to clamp them without stripping the lead recess.
Reynolds 531 is offline
Old 12-07-19, 04:48 PM
Last ride 76
Bikes: Yes, Please.
Quoted: 499 Post(s)
That should make grabbing the posts easier. Thx for the suggestion. I already removed the ridiculous rubber housing.
Old 12-07-19, 04:55 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2738 Post(s)
Liked 3,379 Times in 2,044 Posts
SAme thing here except I just use a short SS bolt with a nut on it. That gives me 2 hex heads for jumper cables etc.
dedhed is offline
Old 12-07-19, 04:59 PM
Road Fan
Road Fan's Avatar
Quoted: 1853 Post(s)
Liked 659 Times in 502 Posts
WTF? Why?
Eric
Could you have just said "I don't get these sprockets. How do I get them off?"
Road Fan is offline
Old 12-07-19, 05:21 PM
Last ride 76
Bikes: Yes, Please.
Quoted: 499 Post(s)
Having read a couple of uniglide threads, I realized the Sante wheels that I have might be free hubs too. I don't use the wheels this season. Used them mostly for test riding C-list bikes before that.
Yup. I have twins..
Old 12-07-19, 05:34 PM
ThermionicScott
Was that a Regina Spektor reference, Last ride 76 ? Love her.
RUSA #7498
Old 12-07-19, 07:05 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 942 Post(s)
Liked 656 Times in 370 Posts
I'll see your Julie Andrews and raise you a Sonja Henny's tutu.
Dan Burkhart is offline
Old 12-07-19, 09:27 PM
Last ride 76
Bikes: Yes, Please.
Quoted: 499 Post(s)
Sure, I could have... But believing it to be a freewheel (never having seen a free hub without a lock ring) I did not.
Old 12-09-19, 04:09 PM
Dfrost
Dfrost's Avatar
Quoted: 500 Post(s)
Liked 466 Times in 256 Posts
My ‘79 Miyata 912, purchased new, had the first cassette (6 cogs) that I’d seen as part of its 600EX “arabesque” group. Everything else in the Miyata catalog back then had a 5-cog freewheel, including the 1200 (no Team Miyata yet). What’s surprising is that they didn’t make a bigger deal about it and the improvements in axle strength and gearing variations it would instigate. Shimano seemed just as thrilled with the “hatch plate” on the RD and “one-key release” for the crank bolts.
Dfrost is offline
