how to identify a rear derailleur that goes with a 6 speed megarenge?
You don’t really need to worry too much about pull ratio unless you are trying to use a 10 speed and above shifters. The 10 speed shifter has a different pull ratio and won’t work with 9 speed and less shifters. I’m assuming that you are just replacing the derailer on an existing system so shifter selection has already been done for you. That dictates the type of rear derailer you get. If you want to change the number of gears you have, that would mean new shifters as well as other parts. I’d suggest just staying with what you have now.
It doesn’t matter. 6 and 7 speed systems are somewhat obsolete but since they used the same pull ratio as 9 speed, a 9 speed derailer will work. Since those are still available, just use the 9 speed. It won’t make any difference nor will it shift any better or worse.
Now I understand. To be honest, the first step would have been to “first” research hub motor over locknut width required and the rear dropout spacing on your bike.
I only spent a few minutes Googling it, but if your hub motor requires 135mm or more and your aluminum frame spacing is 130mm, or worse at 126mm, it will not fit.
I would ask in the Electric Bikes subforum if it will work. And you need details as to the bike you have and the hub motor you want to use.
You will not save 1cm between a 6 and 7 speed freewheel. You “might” be able to use a 5 speed freewheel with friction shifters and re-space the hub motor to fit narrower dropouts. I just don’t know. But it is way beyond just buying a few parts and hoping for the best.
Good luck.
John
Good luck.
John
Also you suggest friction shifter for 5 speed, why ? friction is less fun to use than indexed
tx
Old fart
Quoted: 3583 Post(s)
Liked 3,396 Times
"Megarange" is Shimano marketing-speak for a freewheel with several relatively closely spaced sprockets for the higher gears and a large jump to an extra-low bail-out gear. I'm not aware that they were offered with anything less than seven sprockets. That said, SunTour and Shimano both offered five-sprocket freewheels with 32 or 34 tooth large sprockets. These should be available on the used market. Modern production five-sprocket freewheels seem to top out at 28T.
There are precious few indexed shifting systems available for 5-speed, mostly pretty low-end, and the freewheels that work with them don't seem to offer sprockets larger than 28T.
Really Old Senior Member
Likes For Bill Kapaun:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I am not aware of any 5 spd indexed shifter. Many 6 spd for cheap. Maybe you can set the limiter screw and not use one of the cogs (either high or low-your choice) and then you'll still have indexed. Unless the pull ratio (cog spacing) on the 5 spd is different than on a 6 spd. Cycocommute would know that answer. Why don't we ask him if my suggestion is plausible because that might be your best option.
Mad bike riding scientist
Quoted: 6201 Post(s)
Liked 4,204 Times
Yes but you probably won’t find a 5 speed indexed system. There were some very early...and very heavy as well as poor operating...attempts at 5 speed index.
Stuart Black
Stuart Black
Quoted: 1943 Post(s)
Liked 2,164 Times
The parts you need are 30-40 years old and are not available from any online retailer. You might find them on eBay. And if you can find them, there is no guarantee it will work.
On top of that, it is not just buying and installing parts. You have to re-space the wheel to be narrower and then re-dish it.
The only “theoretical” option I see is running all old Suntour Accushift 6 speed drivetrain with a Suntour 5 speed freewheel. 5 speed and 6 speed freewheels both have 5.5mm center to center spacing. In theory it should work, but in real life it may not. Or it may shift poorly.
My advice is to find a rear hub motor that fits your frame.
John
Edit Added: You could probably do the same with Shimano and Shimano 6 speed shifters. Those will cost more.
Quoted: 194 Post(s)
Liked 204 Times
All this is very interesting but rather theoretical. There are a lot of parts out there, but I still do not know enough to make any suggestions.
If you have the hub, then have you put it in the frame? Have you put it in the frame with whatever speed hub you already have? Did it fit?
For example, I have a folder and I will be fitting a new hub. At the moment it is not even built into a wheel, but this weekend I will be seeing if it will fit and, most probably, stretching the rear frame to take the new hub. Until hub meets frame, everything is just theory, because the chain might hit the frame for example.
Likes For Geepig:
Liked 2,164 Times
OP said he needs to narrow hub by 1cm (10mm). I’m not well versed on e-bikes and doing a hub motor conversion. But if the hub is 10mm too wide, there may not be a lot of options. Supposedly his bike has an aluminum frame.
Since the OP has not let us know what the dropout and hub motor OLD widths are, we are just playing a theoretical guessing game. Not much is grounded in anything but speculation, without any actual numbers.
I believe the OP’s original solution was picking up those 10mms by going to a 6 speed freewheel instead of 7 speed.
John
John
Likes For alcjphil:
Liked 2,164 Times
Bikes: 1986 Cannondale SR600
Quoted: 20 Post(s)
Liked 7 Times
Going to 5 speed would get another 5.5mm on top of that, or 8mm total. From a 135mm OLD axle, this gets to 127, which is close enough to 126mm it might work, assuming there are 8mm worth of spacers that can be omitted from the hub in question.
As for shifters, a 6 speed shifter would work fine for 5 speeds. The spacing is the same, and the low-gear limit screw when set appropriately (if it can be) will block out the last step. Limit screws could be a problem with 9 or 8 speed derailleurs which normally stop a range about 4mm wider. Might work, but might not. Probably best to stick to something designed for 7 or 6 speeds.
I don't think Shimano makes any 5 speed freewheels any more, but there does seem to be a 14-28 sunlite freewheel still available. It doesn't have ramps like modern HG sprockets, but indexing existed and worked before HG was invented.
Until you get some experience, you'll be much better off if you just match all the components of your drive train. Use the same model and series front and back DR and shifters. Pick cassettes and chain wheels that Shimano shows as compatible with that specific model line..
Don't mix up even the same model with a much earlier series of that same model, because many times it will have some incompatibilities. DuraAce today won't work with DuraAce of 10 years ago.
Shimano has compatibility charts and other tables to help you figure this out. https://si.shimano.com/#/
Quoted: 513 Post(s)
Liked 445 Times
A Megarange-compatible rear derailleur has an oversize jockey pulley. Like this one. https://www.moosejaw.com/product/shi...37912e52ba50a5
so i ask would any 9 speed and lower work well for 5 speed?
I don’t think you have any concept of what you need to do to make that hub work.
John
John
i already have my rays laces on my wheel with the hub, with a 7 speed we were lacking abit of space i maybe i ll borrow a old 6 speed to try and place it to see if the the space is ok before buying a new one, i still have to find a decent derailleur though..
John
John
the hub
the wheel and hub fit in my drop out yes but...... when i add a 7 speed freewh. it is too wide. that is why i search for less large
https://imgur.com/a/h1RPPr2
tx
7 speed is spaced at 5mm, while 6 speed is typically spaced at 5.5mm. So, removing one sprocket from 7, reduces the width by 5mm, but then increasing the spacing to 6-speed spacing adds back 2.5mm, for a net reduction of 2.5mm. Not much. Technically, the 6 speed needs a little more overhang for its wider chain, but I don't think true 6 or 7 speed chains are even available any more, with 8 speed chains taking over for those applications, so this is a moot point.
did you miss frap cm for mm? idont get your @7 speed is spaced at 5mm, while 6 speed is typically spaced at 5.5mm. So, removing one sprocket from 7, reduces the width by 5mm, b
your post is very helpful iget the general idea but could you explain me what you mean by . but then increasing the spacing to 6-speed spacing adds back 2.5mm, for a net reduction of 2.5mm.. why increasing the spacing is necessary and what do you mean by this spacing of what versus what?
for the rest i understand that i could have a second choice by getting a used 5 speed adding 8 mm compared to a 7 speed. do i read you well?
what info do you use to say it is an oversized jockey pulley?
- Pulley Teeth - 13/13T ? what is the normal info for a non oversided jockey pulley?
Liked 2,164 Times
All rims are centered between the locknuts on a hub. Typically when you change the overall width, you want to be able to reduce the width from both the side with the freewheel (Drive Side) and the NDS. It doesn’t have to be equal, but removing a significant amount from just the DS, or NDS, can effect the needed spoke length and there will not be enough, or too much length.
If your hub motor uses no spacers on the NDS, and you need to narrow the overall width by 10mm all from the freewheel side, there is a good chance the DS spokes will be too short and the NDS spokes will run out of threads.
Unfortunately you haven’t thought out what happens to the rim when you make the hub narrower. It is no longer centered in the frame. To center it you need to loosen the spokes on one side and tighten the spokes a corresponding amount on the other. If the amount you need to move the rim to center is greater than the spokes will allow, your wheel will be offset and may not even fit in the frame without the tire rubbing.
John
