Quill stems installation marks
Almost every quill stem that I have bought/installed had this typical marks, same scratches you see on the handlebars after forcing the stem into them. My guess is the ones with a lot of marks were harder to get off the steering tube, or maybe the rider played a lot with the height...
is there any tip to avoid those, apart from using grease and the correct size components?
Like this.
Like this.
Quoted: 4510 Post(s)
Liked 6,374 Times
And chamfer the top.
Likes For merziac:
framebuilder
Just to add a bit to what merziac said, it is the corners and edges that cause the scratches. I'm a frame builder so it is not effort for me to take one of my fine toothed files and put a slight chamfer on every edge. Aluminum is soft so one has to do this carefully so not to take too much. When handlebars have been clamped they don't necessary spring back to their original size. I use a large flat tool (like a Campy 15mm crank tool) to spread the stem head apart while wrestling the handlebars onto the stem.
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
Take a small and a small to meduim ball peen hammer and just tap tap on the gouges on the post until they start to fill in...move the metal by tap tap tapping it. You’ll see what’s happening eventually...use both sides of the hammer...starting with the peen, the rounded side...then tap tap the little round indents with the flat side...in the end use med steel wool...aggressively...then work forwards fine steel wool until the gouges just disappear...
Quoted: 4722 Post(s)
Liked 3,036 Times
Another advantage of threadless headset systems.
Quoted: 3464 Post(s)
Liked 2,827 Times
I have had to take a bastard file to the inside of a steerer on a Confente no less decades ago where the other mechanic did over-hone the steerer. Too much of a good thing.
the chamfer or at least emery cloth dressing of the end of the steerer is usually enough.
that and feel the entrance of the steerer after the headset is installed to know if there is a hitch.
most frequent I have found is a stem gets slammed just beyond the round region and the top nut leaves a mark.
Likes For repechage:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,461 Times
Polish it to a mirror finish.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
I think the older style ones like this is a bit difficult because the cone/wedge spreads the stem itself making contact with the fork tubing. Like a stuck seat post it's going to scrape against any corrosion or dirt in there when removing it. If I knew it was this type of stem before hand I would soak it with a really good penetrating oil for a while to reduce the scraping. But to be honest my experience with these stems is a bit limited and the few I dealt with came out easy.
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 375 Post(s)
Liked 1,081 Times
I believe some of you might be wrong or at least barking up the wrong tree. I understand this could come cross as pompous but please hear me out.
Have any one of you had problems installing a quill stem? Has it snagged and/or scorched (please take into account I am not English speaking) when installing it? This is an important question for what is following. Please think about it and be honest. Have any of you actually had problems installing a quill stem because of tight tolerances?
I have just short of 40 years of experience of quill stems and to my knowledge I have never ever had a problem installing one. OK - there are some different standards but if you are within a specific standard there is no problem. Some grease and then it slides in. I hope all of you grease up the stem and wedge/wedged ring before installing stems?
So... my dear fellow C&V enthusiasts... Why would it suddenly become a problem when you want to remove the stem and causing all these grinding marks on stems?
It is not like with the seatpost where you in 99% of the cases have a variable size hole (a slot with a bolt changing the size - clamping down on the seatpost). In 90% of the cases you do have a problem installing the seatpost. In that case there is cause to use a reamer or a honing device - or simply de-burr the slot with a file. Often this has to be done because of the slot having irregularities, the lug has been brazed and lost its roundness, etc. I correct this using appropriate measures depending on graveness.
But - the fork tube...!? OK - there might in some unusual cases be a need to use a file because someone has hacksawed off the tube but that is very uncommon. I believe I have used a file once in almost 40 years.
I belive the problem with scorched stems stem (pun not intended - but...) from two things (in order and often in combination):
1. Mainly - when installing a quill stem you should absolutely not adjust the headset until after the stem is properly fastened. And of course you should not try to remove the stem until you have unscrewed the headset lock nut and washer being lose.
2. You did not grease the stem when installing it (or more likely the schmuck that did it did not) and when many years later you need to get it out - to get it moving you are not able to use upward force without "wiggling" it.
OK - lash out. I can take it.
Last edited by styggno1; 04-08-21 at 01:47 PM. Reason: Got problems with spelling measures.,..
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
It is not like with the seatpost where you in 99% of the cases have a variable size hole (a slot with a bolt changing the size - clamping down on the seatpost). In 90% of the cases you do have a problem installing the seatpost. In that case there is cause to use a reamer or a honing device - or simply de-burr the slot with a file. Often this has to be done because of the slot having irregularities, the lug has been brazed and lost its roundness, etc. I correct this using appropriate mesaures depending on graveness.
99% of your issues are solved by chamfering the top. On an older bike, the inner surface of the tubing may have been dinged from a poor installation of a stem. Expander wedges are often steel, sometimes they're over tightened.
If when building up a frame I notice that the stem isn't going in smoothly, I'll back out and chamfer the top. I've never honed a steerer, but realize it might have to be done.
Steel is real
Quoted: 375 Post(s)
Liked 1,081 Times
Edit + I have never had a quill stem come up with more marks than when it went in... ;-)
Edit II, Gugie - how would a over tightened steel wedge scar the stem. It is at the bottom...? It comes up still at the bottom. ;-)
Quoted: 1635 Post(s)
Liked 824 Times
Most of the time, these zig zag scratches on stems and seatlosts are caused by people that are impatient and tried to twist off the stem or sestpost from the bike, before the stem quill or sest lug seatpost clamp is adequately loosened. I always cringe when I see people do this in videos of people working on their bikes.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Yep, right now, it's the first time I have a problem getting in a quill stem, is always the other way around, the stem I am installing has already some little zig zag marks from the previous owner, and it doesn't slide all the way down like it should, so I want to be very cautious, it's in great shape for his age (50s-60s) and leaving some nasty marks would ruin it, even though I am going to slam it all the way down.
Bikes: Fuji Touring Series V 1985, Motobecane Grand Touring 1982, Specialized Stumpjumper 1993, Raleigh International 1972, Raleigh Grand Prix 1972, Kuwahara Count 1983, Trek Cirrus 1987, Shogun 2001 1983, Cannondale SM700 1990
Quoted: 90 Post(s)
Liked 174 Times
I do this to all my stems but I find it happens coming out not going in. The trick is to pull it straight out not rock it around.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
styggno1 I agree- I’ve never had that result on a stem, but several times on seatposts. I think you looked perfectly at some of the reasons why.
Apparently this can happen on this kind of expander-plug stem too!
