Quick questions and answers
#1126
Quoted: 399 Post(s)
Liked 274 Times
Carry on
#1127
Calamari Marionette Ph.D
Some relevant highlights.
One of Shimano’s main tech gurus, Nick Murdick
The grease that comes on a Shimano chain is applied at the factory to the individual pieces before the chain is assembled. The grease does a better job of reducing friction than aftermarket chain lubes and it lasts longer.
So the best thing to do when installing a new chain is to leave the factory grease on, not apply any other lube, ride until it wears out and then start applying liquid chain lube.
The factory grease also keeps the chain nice and quiet. After soaking a chain in degreaser and then lubing the chain with liquid lubricant the chain gets noticeably louder.
#1129
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Thanks for that.
So it appears I was not hallucinating.
What I don't understand is why everyone acts like the factory lube is made of unicorn blood, that is is completely unavailable to anyone apart from the guy who operates the lube machine in the Shimano factory in Japan. It must be commercially available somewhere.
Imma find it, package it and sell it at high end bike botiques, enough to do one chain for like $50.
Feeling a kickstarter coming on.
#1130
Bikes: Not As Many As I'd Like
Quoted: 16 Post(s)
$50? Come the fk on. People already pay $140 for pre "optimized" chains. ( https://www.ceramicspeed.com/sport/products/Chains ) You should be able to get at least $200 for a jug of "optimal" lube
#1131
Quoted: 71 Post(s)
Liked 12 Times
#1132
- Soli Deo Gloria -
Liked 736 Times
It's not that factory lube is unicorn blood or something beyond reproach. It really boils down to the fact that it's a new chain free of grit and dirt, and each part has been lubed pre-assembly insuring all of the spaces between the pins and bushings etc. have adequate lubricant. It's hard to get a used chain fully clean with a fresh application of lubricant to soak into every nook and cranny. Not that it's the end of the world if you don't, it's really just lube on a chain
I still say its nothing but Cosmoline Rust Veto 342. Some day when I have $39 to blow and nothing better to do I'm going to order a quart of the stuff, heat it in a coffee can and soak a chain in it to find out.
My grandfather used to have cans of cosmoline in his garage. Rolls of 25% silver solder, gallon cans of flux, jars of mercury, benzyne, all just laying around. For some reason he screwed a hose clamp onto the fender well under the hood of his car and used it to hold a glass bottle of carbon tetrachloride. I don't know why.
[h=1][/h]
#1134
Hey Scrod, how big are your thighs? I heard there is some dude running around here with 31 inchers!
damnit meant to put this in the ask scrod thread
#1135
Clark W. Griswold
Quoted: 4332 Post(s)
Liked 3,956 Times
Exactly Sheldon Brown already discussed this at length on his website, why would anyone feel the need to go against his word?
The ShelBroCo Bicycle Chain Cleaning System
#1136
Quoted: 71 Post(s)
Liked 12 Times
But many people are saying that it is "far superior" to any aftermarket lube you can get.
#1137
Bikes: Super Pisa, Vigorelli, Scrambler
Quoted: 32 Post(s)
Does anyone know anything about Lotto shoes? I found a pair in my size, locally on Craigslist. But I can't find anything about them at all. They seem to be a soccer company, and make lots of soccer products. But I can't find any information about their cycling shoes. Model is apparently "1000". Google yielded nothing.
#1138
Quoted: 79 Post(s)
Real dumb question alert: I just popped my crabon wheel cherry ... but I'm not using carbon-specific pads (yet). I intend on getting some, but in the meantime, I'm using brand-spanking-new, never-before-used Campy Record brake pads (the ones that came with the calipers) which, obviously, were intended to be used with alloy wheels. Initial report is that the bike stops when I squeeze the levers, so there's that at least. Burning questions:
1) am I doing damage to my wheels?
2) what's the worst that can happen?
#1139
Your cog is slipping.
In theory, standard brake pads are made of rubber that is much too hard - and get too hot - for carbon rims and will eventually damage the sidewalls. Pads designed specifically for carbon rims will wear faster, but your rims will last much longer. Cork pads are also suitable for use on carbon but they suck.
You spent the money on carbon wheels, spend a little extra on the right pads.
#1140
Quoted: 686 Post(s)
Liked 5 Times
I have experience with the shimano and enve carbon pads, both seem to be about the same.
I have heard good thing about the blue reynolds pads tho but haven't tried them.
#1141
Quoted: 32 Post(s)
Question about my seatpost. It's been slipping a lot lately.
It fell that much during an easy 9 mile ride, averaging 15mph. Just a casual stroll to get breakfast.
Yes, the seat post is the correct size. The clamp is tightened as tight as it can go. I'm wondering if the clamp is just getting worn out? I can't find any place that sells replacements, short of contacting Bianchi directly.
Doesn't look like the only person that's faced this problem either.
https://www.******.com/r/FixedGearBicycle/comments/2bdf7s/question_my_thomson_seatpost_keeps_slipping_on_my/
#1145
#1146
#1148
Quoted: 1332 Post(s)
Liked 398 Times
Been experiencing more than average post-ride pain in the outer-side of knee area (both legs) recently. Fitment issue or just regular strain? I have been going on longer, harder rides more frequently the past couple weeks, so it seems like maybe I've just been giving my legs a little more than they can handle on the new road bike.
#1149
Bikes: SWorks Stumpy, Haibike Xduro RX, Crave SS
Quoted: 514 Post(s)
Liked 12 Times
#1150
Liked 398 Times
Yeah, that makes sense. Leg extension is basically the same as my other bikes, haven't looked closely at fore-aft saddle position. It also has 172.5mm cranks as opposed to 170 and 165 on my other bikes, but I don't know if that would really have an effect here.
