ISO and For Trade thread parts 2 and 3.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I'm terribly OCD when it comes to bike parts. I'm not sure I could tolerate SunTour shifters on a Campagnolo band. I do appreciate the suggestion though.
My Bikes
My Bikes
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Deleted
Quoted: 378 Post(s)
Liked 1,409 Times
dibs if no one else.....
bentrider
Bikes: Trek R200, Bike Friday NWT, Radius Hornet 2, Cruzbike Sofrider, Vision R-40 BF/ R-42, Actionbent Litespeed/ Jetstream, Bacchetta Giro (20 and 26), Tern Verge P9, Ryan Vanguard, Burley Limbo, Rans Stratus/ Wave/ V-Rex, Dahon Helios, others...
Quoted: 14 Post(s)
I have a Takagi Tourney A/D driveside 170mm triple I either would like to find the non drive side match to or help someone else out who needs it. 130bcd
This is a beautiful thread by the way.
CL Addict
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Quoted: 85 Post(s)
Liked 96 Times
ISO 1960s Schwinn Paramount head badge.
Quoted: 288 Post(s)
Liked 330 Times
Anybody got an extra XA stem insert? Preferably black but I'll take whatever color Is available. Thanks.
Quoted: 90 Post(s)
Liked 137 Times
Glenn
Have: Cinelli 90mm Want: Cinelli 80-85. 26.4 Thanks..
Semper fi
Semper fi
Quoted: 1217 Post(s)
Liked 186 Times
Looking for a right side or complete indexed Shimano 7 speed downtube shifter set, brazeon mount. Pretty much anything with aluminum levers would be great.
Bikes: Yes
Liked 3,868 Times
But how does that work anyway? The shifters I have were mounted to standard (?) braze-on bosses. Presumably there is a variation of the Accushift levers that otg is sending me (if not the same lever without the clamp) that works with brazed-on bosses. Doesn't that imply that I'll be able to figure something out to make this work? Or am I wrong in my assumption about the braze-on shifter boss being standardized?
Does this mean I'm also going to have problems putting a barrel-adjuster type cable stop on the downtube bosses on my other bike?
My Bikes
My Bikes
Quoted: 90 Post(s)
Liked 137 Times
That's not what I wanted to hear.
Glenn
Oh, boy, the levers are in the mail as of this morning. I would imaging the bosses are the same as they would be on a bike with braze on bosses. I have a Miyata with accushift 6 speed shifters on it and figured if I removed them I could use barrel adjusters on it with no issue. I would think manufacturers would only put one style of braze on frames no mater what brand of components they would be using. Andy_k, if these don't work out for you let me know and I will send you payment for what you think the trade item is worth.
Bikes: Yes
Liked 3,868 Times
Don't worry about that at all. I'm still hoping it will work for me in some way, but worst case I've traded one part that I wasn't using for another perfectly functional part that I might not be using. I'm OK with that.
My Bikes
My Bikes
Bikes: 1994 Colnago master, 1973 Colngo Super Track, 1980s Conago Super, 1980 Torpado Beta, 90s Fuji,
ISO: Nitto Aluminum "albatross" bars (in think they are technically the B352 or B352A or B352Aa)
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
I have Soma Sparrow bars and Soma Moustache bars. Neither one is exactly like the Albatross -- the Moustache has no flare and the Sparrow has a lot more flare -- but they're both similar. Would you be interested in either of those?
Have: Cannondale SR frame and fork(see pics in classifieds)
Want: Campy super record parts. Enough to work out an even trade.
Semper fi
Semper fi
Quoted: 378 Post(s)
Liked 1,409 Times
It's the threading on the screw, that's all. Don't give up until you try the screws themselves.
tantum vehi
Liked 992 Times
Just be thankful you're not trying to mix and match new French stuff with old stuff - they used rediculous treadings that dont exist anymore...
Bikes: Yes
Liked 3,868 Times
For the curious, I got the shifters from otg today and my 6-speed friction shifters threaded on to the clamp perfectly.
I don't doubt that there is an incompatibility somewhere in this product line, but happily it wasn't a problem in this case.
My Bikes
My Bikes
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
anybody want a Campy non-aero lever with cracked body for parts? The blade (smooth style), pivot pin and set screw are all in very good shape, no clamp...if you were desperate and desperately creative you COULD sculpt in the missing chunk with epoxy putty, but I'm not recommending that...just sayin' (and it would be hidden by the hood). EDIT: lever is spoken for, fork still available and I don't need the V-brakes now. got those.
I have this Ishiwata-made fork from a Fuji Sangres (approx 56cm, 27" wheel) available, would trade this something...not V-brakes.
Quoted: 378 Post(s)
Liked 1,409 Times
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Not strictly in the normal C&V wheelhouse, but...
I've taken the plunge and ordered an adapter for my Schwinn Speedster so it will accept a British bottom bracket. I am thus ISO some kind of track crank, 46-ish teeth. Need not be lovely, or terribly vintage looking, though it should have some life left in it. I'll likely pass on colored anodized cranks (silver, please). I have lots of stuff. Let me know what you are looking for.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 991 Times
ISO 165 mm non drive side alloy crank arm
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Bikes: many
Liked 1,392 Times
What will it match up with on the drive side?
There is an orphan parts Google spreadsheet which has lots of orphaned crank arms:
https://docs.google.com/spreadsheets...5eA/edit#gid=1
The "owner" column is the person's bikeforums handle.
