Mechanical Disc vs Rim Brakes
Bikes: Classic lugged-steel road, touring, shopping, semi-recumbent, gravel
Quoted: 46 Post(s)
Liked 81 Times
My new gravel frame was built up with TRP Spyres and the braking was horrible, I changed out the housing to compressionless and finally used organic Swiss Stop pads and got braking to be almost as good as my calipers. On long downhills the organic pads last one ride and then they need to be replaced. The heat on the rotors is so high it burns my long fingered gloves on contact.
I sold my bike and am getting a frame built with cant studs for V brakes. Why use a brake that is heavy, expensive, ugly and does not work as well as V Brakes or Calipers brakes? I have never had any trouble with calipers in rain or otherwise. Disc brakes for road bikes are a solution for a problem that does not exist.
The call of the Sirens can be irresistible, unless you tie yourself to the mast.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
I have juintech f1 hydraulic-cable brakes on my gravel bike, mtb hydraulic on my mtb, and mtb hydraulic on one of my daughter's MTBs. All work perfectly fine.
I've set up probably half a dozen bikes with spyre brakes for friends and they work quite well for a long time without adjustment or maintenance.
I got compressionless brake housing for mine and it's really fantastic. Worth the $30.
I like these disc brakes more than my old gravel frame that has cantilevers. I still use that frame for commuting/touring and love it, so it's not like that setup is bad, to be clear. The brake feel of my currently setup is nicer, though I stop the same with both(I'm still alive and not hurt).
It honestly could be that I just like the compressionless housing a lot and if that were on the cantilever frame I would like the feel of that equally.
Quoted: 741 Post(s)
Liked 818 Times
I've been very happy with my TRP mechanical discs. Had them since 2013, no issues, easy to adjust, pads last a long time, I'm a 200 lb rider, and they stop me every time.
My friend prefers flat bars, mine is on the right.
Quoted: 430 Post(s)
Liked 460 Times
It can be done fairly easily but unless you're riding in the rain/mud a lot I'd rather just stick to rim brakes. I'm too OCD about front/rear matching for lever feel, the brakes themselves, and wheels for this endeavor to be appealing.
I have been pleased with the performance of TRP Hy/Rd mech/hydraulic brakes on my winter bike.
I have used compressionless housing (Yokozuna Reaction) and reduced the lever pull with replacement parts.
95% as good as well installed full hydraulics from my experience through several northern England winters.
