Can the Alex Rim DA 16 accommodate a Tubeful glue on tire?
I am thinking in advance that the famous DA 16 can only use clincher tires. Picked up a pair of tubeful sewn Continental gatorskins at a garage sale in brand new shape but guess I can't use them. Just wanted to doublecheck.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
TUBULAR, not tubeful. And no, absolutely not possible to use that on a clincher rim. Please google 'difference between clincher and tubular rim' so you know exactly why.
Bikes: lots
Liked 2,932 Times
Why you mad? It should be obvious when looking at a clincher rim and a tubular tire that they aren't compatible.
Quoted: 1608 Post(s)
Liked 2,588 Times
The good thing is you should be able to trade them for a set of clinchers. You may want to check into the classic/vintage forum. A lot of members up north.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
"Tubeful glue on" OK, we were all newbs once... but that's a funny clue as to what the real issue is.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Inverse possibility offered by Tufo https://www.tufo.com/en/tubular-clincher/
g'gl shows a clincher
https://rs.130928.mrsite.com/images/t...305_600_0.jpeg
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,985 Times
I'm not mad. Its my fault. Thank you very much for your information.
Apologies, my friend.
I'm not totally witless. I did a lot of reading. People have tried Tape with using Tubeful (LOL) tires with various Clincher rims. A few succeeded but many have found they have found that they shift and they damage the Presta Valve... That would be scary at 50 mph.
Quoted: 1074 Post(s)
Liked 295 Times
I've used tubulars on 27"(630mm) clincher rims. It worked somewhat after lining the rim with double-sided sticky tape.
What made me stop that was that those rims were so deep that the wheels became very prone to flats, not enough air chamber visible.
Bikes: lots
Liked 2,932 Times
Hello Professor Cxwrench and All
Quoted: 1324 Post(s)
Liked 927 Times
A 700C tubular tire can be used on a 700C rim in an emergency. However, there's a possibility that with long term use the clincher rim walls will chafe through the sides of the tubular tire.
Cheers
Cheers
Bikes: lots
Liked 2,932 Times
I can't even begin to imagine what kind of emergency would lead to this. Forget 'chafing'...the tire has so little contact w/ the rim it will roll. Again...massively stupid.
Liked 295 Times
Why?
I had the wheels.
The rims weren’t hooked.
I wanted to run higher pressure tires.
I had the tubulars.
I used up some of my time and some of my resources at something that didn’t pose any particular risk to anyone else.
If that is your idea of ”massively stupid”, there has to be a lot around that doesn’t meet your approval.
Luckily, I don’t need it.
The basic idea worked. If I’d had a wider tubular, it’d have worked fine.
I had the wheels.
I had the tubulars.
Liked 927 Times
I've used a tubular tire on a clincher rim a couple of times.Once was to get home from a long ride and another time it was to get the bike to a bike shop a number of miles away. In both case I used the tubular tore because the clincher tire normally on the wheel was toast. In neither instance was there and "rolling of the tire off the rim". Actually, if you put a tubular tire on a clincher rim and pump up the tubular tire until it's hard, you'll find it's pretty hard to roll the tire off the rim without deflating it first.
Cheers
It's MY mountain
Liked 2,980 Times
It is pretty impressive how well a fully inflated sew-up fits on a clincher rim - I would totally trust one in a situation where I had no other options... although it's a little hard to imagine being in that kind of situation. There's no way I would do this for anything besides getting home or a repair place though; I'd corner very carefully and I would minimize braking on that wheel too to prevent the tire's creeping and ripping out the valve.
Now the Czech company just stuck with glued on cross tires,, (swap bikes in the pits run by, crew changes wheels )
Quoted: 1814 Post(s)
Liked 923 Times
You're out with your clincher-riding group, and someone slashes their tire on a broken bottle.
After chiding their carelessness, you give them your spare tubular which they put on and ride home.
Clearly you have never tried this, or you would be less dogmatic.
Likes For woodcraft:
It's MY mountain
Liked 2,980 Times
Bikes: lots
Liked 2,932 Times
Ok, I agree w/ some of these emergency situations. To get home when no other fix will work, ok.
But...
To do this with the exectation of riding like that for an extended period of time...crazy. Not as crazy as trying to put a clincher on a tubular rim but not smart.
But...
Liked 295 Times
Or one of those MacGyver situations where the desire to get something to work with what’s at hand at the moment is very strong.
As stated, I’ve tried it. Admittedly not during alpine descents or podium-finish efforts, but certainly under what for me goes as ”regular” riding, no special considerations.
On my wheels they became prone to flats, which made them long-term impractical. But getting a flat is hardly a new risk, so not much of a concern.
I can think of one or two other reasons.
But I agree with your general opinion. Running a tubular/clincher combo isn’t a goal in itself, it’s a tolerable way of achieving something else. Getting a bike rideable with what’s at hand, extending the use of some vintage wheels etc.
Liked 927 Times
In Canada, a monetary tire boot would have o be made with a $5.00 bill since we have coins for $1.00 and $2.00 amounts not bills.
Cheers
Cheers
Liked 2,588 Times
