Derailleur stretch, chain length?
Old 09-22-20, 06:22 AM
rbrides
Curmudgeon
rbrides's Avatar
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times in 28 Posts
In the attached picture of my bike in the Big-Big gears, is the derailleur too stretched out?
I installed new double chainrings that are 2 teeth larger but have not lengthened the chain. It pedals fine in the bike stand but I've not ridden it yet.
bike in BIG-BIG gear
rbrides is offline
Old 09-22-20, 06:28 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
Additionally, I seldom ride BIG-BIG, or even BIG-2nd gear to avoid cross chaining. Also, BIG-BIG is the same gear ratio as SMALL-5th gear so I prefer getting into the small ring before steeper climbs so I can more easily move up & down the cassette as needed. But, on the occassion that I might get into BIG-BIG, does this look advisable?
rbrides is offline
Old 09-22-20, 06:35 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
Looks ok to me, but you are getting close to the limit. When you get around to replacing the chain you can reassess the need for an extra link or two. What does the small-small combo look like?
Moe Zhoost is offline
Likes For Moe Zhoost:
Old 09-22-20, 06:53 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 853 Post(s)
Liked 1,434 Times in 816 Posts
I would say close to the limit, but ok. Even if you try to avoid the big-big, it is prudent to have the capability to get there. Very bad things can happen with an accidental shift into big-big without enough chain length. I like the smallest chain you can get away with in the big-big theory.
delbiker1 is offline
Likes For delbiker1:
Old 09-22-20, 07:55 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
Thanks Moe and Delbiker 1,
Finally found my Big Blue Book of Bike Repair from Park Tools.
In their chapter on chains is a pic with the caption "double bends at each pulley indicate adequate chain length".
It SEEMS I have enough chain length, but I always appreciate the knowledge folks here on Bike Forums provide.
All other input is welcomed.
rbrides is offline
Old 09-22-20, 08:55 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Post a photo in small/small.
cxwrench is offline
Old 09-22-20, 09:49 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
It's fine. That's how it's supposed to look by big/big + 1" chain sizing.
woodcraft is offline
Likes For woodcraft:
Old 09-22-20, 01:57 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
This is a quick in situ test so see if you have some slack.
Bill Kapaun is online now
Likes For Bill Kapaun:
Old 09-22-20, 02:49 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
If it were me, I'd consider easing the derailleur forward a turn or two on the B-screw, (Small screw on the top rear of the derailleur that engages the hanger.) I'd do that then check for smooth shifting. (Shifting should theoretically be a touch worse but I'd like the piece of mind knowing that a clumsy shift into the gear I'm not supposed to use at a mountain top wasn't going to leave me stranded. Reduced mental capacity at mountain tops is a problem I've wrested with for years. Doesn't help that I seek out the opportunities to achieve it.)
79pmooney is online now
Likes For 79pmooney:
Old 09-22-20, 05:53 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 178 Post(s)
Liked 177 Times in 101 Posts
What does that show, other than your chain needs to be cleaned and lubricated?
Rogerogeroge is offline
Old 09-22-20, 07:35 PM
cxwrench
cxwrench's Avatar
Bikes: lots
It's how you check to see if you can remove a link safely.
cxwrench is offline
Old 09-22-20, 08:41 PM
Bill Kapaun
So someone with the slightest mechanical sense can see how much slack is left.
Since an addition of 4T ring/cog size means 1" more chain needed, one with the slightest sense of arithmetic can do the calculation to see if they can go to a larger cog without adding chain or not.
To infer my chain needs lube is simply a stupid assumption.
Old 09-22-20, 10:31 PM
csport
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times in 102 Posts
Correct me if I am wrong, the big-big + 1 size is needed for shifting into the big-big combination. The extra two half-links are needed for the chain to climb over the teeth of the big chainring or rear cog. Otherwise the chain will jam during shifting, mangle the rear derailleur and destroy the hanger -- bad things delbiker1 mentioned. If you can shift into the big-big on the stand without the chain jamming you are probably OK.
csport is offline
Likes For csport:
Old 09-23-20, 12:31 AM
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
I always measure the chain long enough to safely run in the big/big combo. Because I know that on some ride when I'm hammering up a climb to snag a PR, or to keep up with a stronger group, I'm gonna unintentionally shift into the big cog before remembering to shift to the little chainring. If it's noisy outside I probably won't hear the telltale sound of cross-chaining. Or I may not want to risk dropping the chain by shifting down to the smaller chainring during a climb. I've done it before under duress and I'll probably do it again.
I've cut chains specifically for certain cassettes and freewheels, because the chain I cut for, say, a 13-24 may not be safe with the 13-28 I plan to use for a route with more climbs. Ditto, switching between 38, 39 and 42T small and 50 or 53T big chainrings. I try to remember to label the chains in a ziplock bag for next time.
It's less crucial on my bikes with long cage rear derailleurs, but I know I'm pushing the limits of some older short cage RDs already when I use 28T big cogs on the cassettes/freewheels.
So far I haven't killed a rear derailleur or ruined a chainstay from chain slap. Although I do need to replace the old tape over my Ironman's chainstay.
canklecat is offline
Likes For canklecat:
Old 09-24-20, 05:32 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
Thanks all for the input. I'm good to go. No pics of small-small but on a ride with some very experienced riders (decades) they too opined it was all good. Approx 60 miles on two rides since my original post and not a single problem.
rbrides is offline
