Nexus IGH grease: info requested
Hello
Need some info about Nexus IGH grease Y04120800
1. What is the NLGI grade?
2. Base oil: what is kinematic viscosity at 40c and 100c? Viscosity index?
3. Is the base oil mineral or synthetic?
Thanks
Thanks
Quoted: 506 Post(s)
Liked 639 Times
Feel free to demonstrate your mastery of Google by posting your search results here and the search techniques you used to obtain the same.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Internal gear hubs are one case where it is probably best to use the specific grease recommended.
OP:
I don't remember the exact grease recommended. I do however have a faint recollection of lithium grease for roller bearings inside the internal assembly. Phil's Tenacious applied liberally, & the end cap packed with Park Tool green (marine) grease to hold the oil in. Whether or not any of that is correct or even recommended is anybody's guess. So don't do it (or anything) based on anything from my foggy brain.
Likes For base2:
OP:
Shimano IGH grease + dipping oil unavailable.
Searching for equivalent alternatives. Hence my request.
Quoted: 981 Post(s)
Liked 584 Times
I use the same Royal Purple oil in an Alfine 11-speed hub that has almost 11,000 miles on it; this oil is much less expensive than the "official" Shimano oil.
One of my 8-speed Nexus hubs was lubricated with a black grease resembling a molybdenum disulfide type grease; the other one had a white grease that looked like a lithium type. I've used the moly grease on both of them.
Hope this helps.
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
The OP's question has been asked before over the years and I've never seen it answered.
Big boo on Shimano for not stating a commercial equivalent to their IGH grease & oil.
Others have used NLGI #2. Shimano Internal Gear Hub Service
Chapeau to Sturmey-Archer who sells their own proprietary lubricants but stated back in the stone age that 20wt motor oil was good for their oiled hubs and published in 1984 that they used NLGI #00 semi-fluid grease inside their greased hubs.
I use John Deere Cotton Picker Spindle NLGI #00 inside my Sturmeys with Sta-Lube marine NLGI #2 for the bearings and labyrinth seals.
Likes For tcs:
Might be a bit late since OP likely found info elsewhere. But for others who are interested some of the info cen be found in Shimano's publicly available SDS
The white IGH grease version Y04120800
- Mineral oil
- Bentonite Clay thickened
- White solid lubricant (confidential)
- Other additives
- Mineral oil
- Graphite solid lubricant
- Other additives
Likes For baggewagge:
Are you attempt to perform some kind of task based on that information? If so what task?
Shimanos grease is for the whole hub brake included. Shimano do recommended their oil bath + ggrease on the gear teeth as maintenance. THe coaster brake needs a grease with a high temp compatible thickener which is why the clay thickened shimano HUB grease is uitable. But mixing incompatible greases can lead to issues.
Mostly harmless
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
- Mineral oil
- Other additives
- Mineral oil
- Other additives
Seams reasonable. It is rare though that the NLGI grade is sufficient for selecting a grease. I have been experimenting with relativery thin full synthetic gearoil (and ATF oil) similar to the official shimano mineral oil maintenance set mixed with a bit of the Shimano IGH grease. And then with synthtetic calcium sulfonate-complex grease for the bearings and coaster brake. Provides a litte more drag on the bigger righ-hand side bearing. But seems to work fine in temperatures down to -15 and up to +25 celcius and with heavy rainfall. With the added benefit of the increased wather protection..
Mostly harmless
Liked 216 Times
https://www.crazyguyonabike.com/foru...1&nested=0&v=M
Relja OurWhiskeyIsBetterThanTheOriginal Novović
Likes For Bike Gremlin:
If you ride in colder climates with lots of downfall like Northern Europe you really need the appropriate grease. Or the pawls will stick and gum up due to using a soap thickened grease.
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 868 Post(s)
Liked 721 Times
FWIW, I disassembled my Nexus 8 at about 6000km, drilled and tapped the body for a 4mm screw and used 15ml of ATF from then on. 10 years and 52000km later, it still works flawlessly. Had to adjust the cones once. Used with care and never below 0C though.
But just like your experience it is just anecdotal
1 Mobil Gear Oil FE 75W
Immerse all internal parts. Let excess drain.
2 SWEDOL Graphite grease
https://www.swedol.se/swedol-grafitfett-pg-1004863.html
Apply to all gear assemblies.
3 STARTA NLGI 0 grease
https://startaprodukter.se/produkt/s...lfett-bio-tub/
Apply to coaster brake shoes/rollers/hub area.
Quoted: 981 Post(s)
Liked 584 Times
I have a Nexus 8 that gets its innards dipped in gear oil once a year and used through the winter in Chicago temps as low as -30C. It's got about 16,000 kilometers on it. I've yet to see any evidence of wear on any gears or bearing races. I guess the only extra care I give it is not shifting under load. A very durable hub, IMO.
