The true weight thread
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 375 Post(s)
Liked 1,083 Times
Bought a scale yesterday. Thought it would be fun to weigh my bikes.
Here is the 1989 Bridgestone MB-1 with a 1994 XT group except FC M563 LX cranks and "modern" Shimano M324 spd/cage pedals (filled with lead I suspect...). On the other hand it does not have a bottlecage.
195? oh the bike! I have no idea, because the bike isn't the problem!
Quoted: 1858 Post(s)
Liked 606 Times
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
Admittedly, it gets lost a bit in translation.
Nice Bridgestone, though. Thanks for posting!
He means he weighs 195 lbs (88.4) Kilograms so the weight of the bike doesn't matter
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I weigh my bikes on a scale very similar to that. It was sold on eBay as a fish scale. I don't have a good way to hang it, so I typically just hold it and lift the bike with the hook. It doesn't stabilize to a single number that way, but I can usually figure out about more or less what it's telling me, probably within the accuracy of the scale. In addition to pounds, ounces, and kilograms, mine will tell me the weight of things in Jin. I haven't had a use for that, but I could do it if I did. Also, the ghost of my freshman college physics professor insists on reminding me that kilograms are a measure of mass, not weight.
My Bikes
My Bikes
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Those pedals are good but heavy.... steel cages.
Those who post the weight of their bikes without a picture with the scale... well, they are liars.
Steel is real
Quoted: 375 Post(s)
Liked 1,083 Times
Aha! Thanks. Well I am well over 90 kg... I am not weighing my vintage bikes because it would matter in any perfomance kind of way. I do it because 1 - It is fun to know and 2 - there are a lot of fantasy weight quotes floating around on the net.
Bikes: Yes
Liked 3,868 Times
I kind of look at this like I do the pressure gauge on my pump. As long as it's consistent, I'm happy. I can weigh a new bike and know which of my other bikes are about the same weight. Usually all of them, +/- 2 pounds. Within that range I don't think weight is even the dominant factor in the way the ride of the bike feels.
My Bikes
My Bikes
Liked 664 Times
Again, I don't see a problem. It seems to be a 27# bicycle.
What kind of errors are we worried about, and are they large enough to challenge this answer for any practical purpose?
Steel is real
Quoted: 375 Post(s)
Liked 1,083 Times
I will check my scale for accuracy.
Here is another frame+fork i did today:
https://www.bikeforums.net/classic-v...l#post20729554
Cannot be that far off.
PS - please do not make this thread about performance. It is not.
PS II of course it is kilograms - I am European.
Quoted: 7348 Post(s)
Liked 2,471 Times
I have that same scale. I wonder how accurate it is. It seems very cheap.
Bikes: Yes
Liked 3,868 Times
What? I should have shown the bike in the picture too? Well, it's too late for that now. It was this one.
Non-vintage bike for comparison. I did it again.
But trust me, it was this one.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
I don't see the problem. Stygg's scale says 12.18, and it is reasonable to assume it is indicating kilograms. The conversion factor for kilograms (mass) to pounds (force) is 2.2 kg per pound. The calculation of that factor includes the conversion from mass to force. The necessary factor is the acceleration due to gravity, which is usually considered a standard value.
My Bikes
My Bikes
Steel is real
Quoted: 375 Post(s)
Liked 1,083 Times
Haha! Next bike I weigh I will let you know both pounds and Kg. So you who are stuck in medieval times can relate...
I am really curious on some of the bikes - the Masi/Ferretti/Monark (with a lot of light stuff and tricks) and the Merckx MX Leader with modern Super Record 11. They feel light but it could just be my wishful thinking/feeling.
Quoted: 4512 Post(s)
Liked 6,385 Times
This all brings up a good point, I have a Berkley fish scale I use. Got a frame the seller was very detailed with the weight of, 4lb 12.7 oz frame and 1lb 8.8oz fork = 6lb 5.5oz total on his "Postal scale". Frame came and weighs 7lb on my scale, checked my scale with 1, 2 and 10lb weights and it is spot on. By itself not a huge deal or deal breaker per se, but why is nothing ever straightforward? The weight was just one of several things that collectively add up to quite a bit more than I like to let go.
Liked 6,385 Times
Liked 6,385 Times
Bikes: Yes
Liked 3,868 Times
In addition to the method of clamping the scale in my workstand (as seen in my pictures above), I've also had success hanging it from a U-lock hanging from the stand.
My Bikes
My Bikes
Quoted: 1641 Post(s)
Liked 831 Times
Yes, the scale does not lie, but you do have to get a decent enough scale, or suffer the doubts from others when you call out your bike's weight in any forum.....
Case in point, my recently finished Davidson build. I myself couldn't believe the sub 20 pound weight, considering it's a steel bike with a Brooks saddle and steel epinrpes and adpes.....but there it is,........ on my overpriced digital bike scale I just bought last summer (used to weigh my bike on a digital luggage scale)....
Quoted: 2323 Post(s)
Liked 4,990 Times
52psi
Quoted: 790 Post(s)
Liked 802 Times
