Are Drop bars just an illusion for most?
#126
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
They aren't mutually exclusive.
Stuart Black
Stuart Black
#127
Quoted: 1218 Post(s)
Liked 298 Times
And, yes, my bars are angled up more than would be fashionable but that all a horizontal drop is...fashionable. There is no advantage to having them flat and, since I and most of the rest of the world ride on the hoods most of the time, it's more comfortable to have the tops more horizontal.
2. if you put your bars on the bike correctly, then you wouldn't have so much issues in the drops.
3. with incorrectly positioned bars, you are compromising control in both positions. the hoods and the drops.
4. drop bar angles is not a fashion statement, but something that works. Like the knob on a baseball bat. Or a wrist lanyard on a Wii remote.
#128
Quoted: 18415 Post(s)
Liked 15,539 Times
Hello. What's this thread about?
Likes For indyfabz:
#129
Whenever I get the urge to "go really fast" (fast for me that is....relatively speaking for sure!) I use the Drops. At any speed above 20 mph or so, I can feel the drag difference between drops and when on the hoods.
Likes For rayooo:
#130
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
The pics show bikes that are set up to be used in a presumably comfortable way and that should be highlighted. The whole point is for cyclists to get out and ride- and these setups allow that.
The pics also show another point thats made in the thread- people buy bikes that dont fit them and then rig and modify the bikes to fit, instead of just getting bikes that fit better in the first place. That many spacers should clearly show the a different size and/or style would fit better.
Likes For mstateglfr:
#131
Liked 4,218 Times
What, you want a cookie?
I don't have "so much issues in the drops". I just don't find them to be all that useful. Most people don't from what I see while riding. Very few people use the drops while riding. Even if you google "pro cyclist pictures", most of the riders are on the hoods. There are even a few pictures of pro riders on the hoods at speed on what appears to be a down hill.
How am I compromising control? Considering that I don't crash on fast downhills on a regular basis (or ever) nor do I slip off the hoods on a regular basis (or ever) nor do I loose control and go all wobbly when I hit a pothole on a regular basis (or ever), I just don't see how my ability to control the bike is compromised.
"Works" for you. There are more than one way to skin a cat.
Stuart Black
Stuart Black
Likes For Metieval:
#133
Liked 4,218 Times
Only if you are dumb enough not to be holding on.
Stuart Black
Stuart Black
Likes For cyccommute:
#134
Unless, of course, your thumb happens to slip off because it is extended so that you can reach the brake lever. The distance from the drops to the brake lever is longer than the distance a brake lever would be from a flat bar. Smaller hands have more of a problem with this but my average sized hand is extended quite a bit to reach the lever from the drops.
Thumbs can slip off flat bars. And, with a flat bar, the bar isn't dropping away and back from the lever so the outer two (or three) fingers can hang onto the bar.
It's wrapped around the hood. My index finger and thumb encircle the hood. It's highly unlikely that my thumb would just "slid[e] up and off the hood".
1) why would your THUMB be reaching for a brake lever? That's what your index finger is for. Thumbs don't do shifting or braking on drop bar controls so keep the thumb around the bar when braking if it's bumpy. Brake levers on drops are about the same distance from the bar as on a flat bar - an index fingers reach. I don't have really big hands, run my SRAM levers adjusted all the way out and can comfortably ride in the drops with the tip of my index finger resting on the brake lever if I'm in a place where I feel I may need the brakes.
2) My other fingers are on the bar or can be when I brake with drops. Again, index finger only for brakes. Plus your hand is in the forward part of the curve, there's no place for it to slip to, your hand is being driven into the bar.
3) I think for most of us, the thumb wraps around the front of the hood. My thumb only reaches fully underneath the hoods if I am out of the saddle.
#135
Quoted: 2236 Post(s)
Liked 1,314 Times
I think what he means is the reach, from the drops on a modern set up, has the brake lever too far away from the bar so that you need to stretch the hand to reach it. Which is fairly accurate. When I began using my drops more I had to really look at adjustments so that I could reach them reliably. They didn't come that way. Eventually I found flared bars and brake levers with limiters for smaller hands to work even better.
People arguing about proper set up for drops etc... tend to miss a point. Bicycles are very personal machines. If a person spends more time on the hoods they will want that position maximized. In the drops.. ditto. If they are happy great! Trying to suggest they are wrong because they don't do what another might is misguided at best.
Likes For Happy Feet:
#136
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
#137
Liked 298 Times
applying the cyccommute theory of 40 years, some people have ridden 40 years without a bicycle helmet without a brain injury. No need for helmets! to think other wise is just "misguided" at best.
#138
Liked 1,314 Times
Sorry, but no one elected you the bicycle police. Cyclocommute has ridden many years successfully as is well documented in the touring sub forum. You?
Stop trying to win the internet in every thread with your absolutism. It's tedious.
#139
climber has-been
Quoted: 3430 Post(s)
Liked 3,566 Times
2. In the drops, your thumb wraps around the bars, and it takes the force of a rapid deceleration. You may sprain your thumb when taking a big hit, but your hands will not come off the bars.
Likes For terrymorse:
#140
Liked 298 Times
No I won't. A helmet is not a drop bar.
to quote you
as far as the drop bar conversation goes. it isn't about my way, their way, your way,
it is about physics, anatomy, etc....
#141
Again, this thread would be far more useful to discus drop bar setup so that the drops are NOT an illusion and all positions on a drop bar are useful.
#142
Quoted: 551 Post(s)
Liked 277 Times
#143
Quoted: 1027 Post(s)
Liked 325 Times
That's the biggest difference for me too. When I need to go hard/fast (like when I'm taking a pull), I use the drops. I go a km/h or two faster for the same power output.
Likes For OBoile:
#144
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
Pardon me for butting in, but if there are only drops and flats, where do these fit? I choose not to use drops, in large part because I like to admire the scenery on my rides and not have a permanent neck cramp. Also the belly fat thing.
Likes For Korina:
#145
Liked 1,314 Times
When I read about how non secure hoods are I have to wonder if the poster has seen or used modern versions. They are ergonomically designed for hood riding so differently than older generations of brake lever it's day and night. You can have a very secure grip on them and still easily use the brakes.
Looking at older drop bars, with the levers half way down the hooks it's easy to see how those would not feel secure.
In order to make old school levers reachable in the drops you have to position them that way and thus compromise the hood position. Modern design addresses that issue.
As to safety. How many old school drop bar roadies will poo poo aerobars and say you can rest your grip by leaning on the flats with their forearms. Super safe
#146
A bicycle is a highly personal machine. It has to fit your body perfectly for your comfort and long term enjoyment. And to achieve such state of affairs requires time and effort. For most of us, there was no "perfect" bike from the get go. Back in the day, we had to make changes and add other items to make our rides more comfortable and enjoyable. Today, there are countless different models and frame sizes/shapes to choose from. That is great because now you can at least find a rather more fitting canvas to work on.
So when people argue about "which setup is the best", i am sorry but it is just babble. "Whatever floats your boat" should be the normal thing to say.
#147
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
OP said that drop bars are merely an illusion, which had me doubting my sanity. I ran downstairs to check my bikes, and they have drop bars as far as I can tell. If I'm hallucinating, at least I'm consistent.
#148
The pivot position does make effective braking from the hoods difficult, though. From the hoods, you have to push the lever down more than pull it toward you.
But I also think it's easy to exaggerate the issue. All of my vintage bikes have their non-aero hoods significantly higher than where Merckx would have stuck them, but I can still use them effectively in the hooks.
#149
Liked 15,539 Times
Funny you should mention hallucinating. Get a load of this super trippy video:
https://mobile.twitter.com/dangela20...wo5yml8envsslu
I challenge everyone to watch it only once.
Likes For indyfabz:
#150
Tragically Ignorant
Liked 9,098 Times
it doesn't matter if it is a helmet, a drop bar, a coke, or a pepsi....
to quote you
even applies to fasting also. but you all love to tell me I am wrong because I don't do it your way.
to quote you
