Gary Fisher MTB, threadless headset options
So I bought a Gary Fisher 1999 Aquila MTB for the steel frame, as an extra bike for the trails. But the handlebar height is too low. It has the Aheadset SE-1 (1-1/8") threadless headset. It has spacers, but still isn't high enough. Anyone have any ideas on getting a little more height on the bars? Any ideas on vintage parts to replace the handle bar stem with a higher version?
Thanks.
Thanks.
Bikes: 74 Romic, 83 Basso, Lotto, 88 Condor, Prestige MTB, 12 Soma, Groove
Quoted: 23 Post(s)
Thanks.
Thanks.
Quoted: 2026 Post(s)
Liked 1,095 Times
There are adjustable angle stems that can raise the bars significantly. They tend to be heavy but are functional. Here is one of the better examples:
https://www.nashbar.com/ritchey-4axi...48194?v=483140
Another option is a high up-angle fixed stem like this one :
https://www.nashbar.com/dimension-11...69243?v=322537
Keep in mind as the angle increases then reach decreases so compensate for that in the length you choose.
Quoted: 453 Post(s)
Liked 104 Times
A bike from 1999 will have a long stem vs what we are used to today, I have a few mid/late 90's MTB's and they have all benefited from having a much shorter stem than was orginally fitted, 20-30mm shorter + risers make a nice ride on an older bike
I went with the steering tube extension, seemed like the most simple solution. Thanks to everyone for their help.
