Panniers- Left or Right
Live Beautifully
Bikes: 2011 Specialized Sirrus, 2013 Yuba Boda Boda Sport
Curious for those who use only one pannier, which side do you keep your pannier on? Left (traffic-side) or Right (curbside).
I've heard the arguments regarding advantages/disadvantages of left side (positive: it keeps a buffer from the traffic & could slow cars) or (negative: a car has a better chance of snagging a full pannier and taking you down).
Would be curious to know what side you keep your pannier on and the reason. FWIW, I've been keeping mine on the left.
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
Right side here - it allows me to get at what's in the pannier with less trouble, and keeps the PBSF mounted on the left rear leg of the rack from getting moved around by the pannier. Plus it's where the fashion police told me to mount it.
Bikes: 2012 Trek Allant, 2016 Bianchi Volpe Disc
Both
If I did just run one, I'd put it on the left. It would lessen the risk of a car clipping my elbow. If the car is close enough to snag on the bag, I'm getting hit anyway.
When I do use 1 rear Pannier, since it doesn't prompt the bike to topple over on it's kickstand,
I have the bag on the Rt side.
I often pack Both Ortlieb roller bags in one, to head off for groceries ,
I can stow all 4, empty, in 1 rear bag.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Right side- if for no other reason than that the bag might jump off and hopefully will not land in the flow of traffic.
Community guidelines
Not quite there yet
Bikes: A bunch of old steel bikes + an ICE trike
I use the right side one simply because it's easier to get on and off because of way my rack trunk bag mounts. Without the rack trunk, I would probably use the left one to make myself a little more obvious to traffic.
xtrajack
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
If I were to ride with only one pannier, it would be on the curbside. No particular rationale, just feels right.
When I only use one, it's on my left side, opposite the derailleur to avoid loose straps, strings, etc. getting stuck in the chain.
Quoted: 5888 Post(s)
Liked 3,471 Times
Bikes: Windsor Carrera Sport, Fuji Absolute 3.0, Cannondale H400
I ride with on pannier. I ride with it on the left. I have a light attached to it so I want it on the traffic side.
Bikes: currently: electra townie 21d and 7d,i, durban bay pro 7, raleigh hybrid (2001 c40), burley trailer, a few kids bikes. Former: Townie 3i, weehoo trailer...
Quoted: 18 Post(s)
Right side. I figure the movement of my left leg (and pedal reflector when dark) may be more visible/eye catching than the opposite.
Same here. Not worried about it falling off. Sometimes I get carried away and buy a little much to fit nicely. If something falls off or a bungee breaks, maybe it would end up in the grass and I can get it without much harm.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
I keep mine on the left side due to the chain and gears but if the pannier is on right that shouldn't be a problem anyways, I do it that way because it seems from people I talk to that that is tradition. I don't do it as a buffer, a pannier makes a very poor buffer.
Prefers Cicero
Left, but only because if I put it on the right it causes the fender to rub intermittently on the tire. Just a little assymetry in the rear rack and fender.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Left, traffic side for the lights and reflective material and how it parks at home & work the right side is up against things.
Squeaky Wheel
Right. I use a bar-end mirror on the left side and the pannier can block some of the view. Plus, my shoes and tights have reflective material on them, and I don't want the reflective motion to be blocked by the pannier.
Bikes: 2011 Raleigh Sojourn, 2012 Marin Four Corners, 2013 Soma Saga, 2014 Scott Spark 940, 2017 Brompton H6E, 2016 Trek FX 7.2
Quoted: 10 Post(s)
Right side. Sometime I feel like I ought to have it on the left for reasons mentioned above (buffer from traffic?, reflective accents on the pannier...) but I keep it on the right anyways. My reasons for keeping it on the right are that I mount my bike from the left side, so I don't kick my pannier when I swing my leg over. Also, from experience, I have learned that when the bike goes down in a crash, the pannier on the right side is more likely to protect the drive train from damage. Lastly, I have a kickstand, so loading/unloading the pannier on the right side of the bike is easier and keeps the bike more balanced when parked on the kickstand.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
Same side as your "landing gear". Most cyclists prefer to put down one foot over the other at a stop. This is what I call the "landing gear" side.
When carrying heavier loads, this keeps the bike leaning towards you at a stop, rather than trying to fall away from you. This also meansthat when starting again, your first pedal stroke is opposite the weight of the pannier--easier balance. When running two panniers, keep the heavier of the two on the "landing gear" side.
Not safe for work
I prefer a single pannier on the right side. I get off the bike on the left and with the pannier on the opposite side, it feels less likely that the bike could topple over.
