Discoloration on Fuji Carbon Fiber Frame?
I wanted to ask this when I bought it but I kept forgetting.
Its purely cosmetic but I was curious nonetheless.
The portions of the frame that are black have this weird discoloration going on. When i touch the questioned areas, it feels smooth like the other areas so Im assuming its not damage.
I attached some photos. Is this a defect on the fuji frame and should I get it warrantied or is this normal? Or the surprise choice is, it somehow got discolored from weather conditions. That seems unlikely given the material (CF) though. Thoughts?
https://i62.tinypic.com/x4ol4z.jpg
https://i58.tinypic.com/xauycl.jpg
https://i60.tinypic.com/dpjt5i.jpg
L-I-V-I-N
I think that's just what UD carbon looks like. My Fuji is similar.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Seems purely cosmetic to me... if Fuji warranties you out another one the same thing will happen eventually. UV rays is not to be underestimated.
Such an occurrence is less noticeable with matte carbon.
Location: Perth, Australia and sometimes Penang Malaysia
Bikes: Litespeed L1r, Litespeed Ghisallo 07, TCR Advanced Team SL 0 ISP, Giant TCR Advanced SL, Giant TCR Advanced Team - T-Mobile, Giant Propel Advanced SL
Were these patches there from new or have they developed over time ?
If you press the patches that are discolored, do they change shape e.g spread out, if they do it could mean you have moisture under the clear coat.
This may be a batch problem. But I would not be happy with this happening. And because it is below the shiny surface, no-one knows whether it is cosmetic, or in fact indicates a delamination occurring, or deterioration of the resin.
Bikes: 2012 BMC SLR01, 2012 Yeti ASR5, 2013 Trek Crockett
Unidirectional carbon fiber does sometimes look like that. The clear coat probably doesnt help things. It wouldn't look so bad with a matte finish. I think I have seen tubes look like that on other carbon bikes from different brands.
Has it always looked like that or did this appear over time?
I would look at other fuji frames of the same model and see if they all look that way. That may be normal.
If you are really concerned about it take it to your local bike shop and have them inspect it.
Thanks for the speedy replies. You guys are always so tip top on that.
Regarding whether it was there form the start, can't really say. I forgot to ask the original owner (who purchased in June 2012) if it was there from the start. But when he first sent me photos, he did say that the marks were something he realized happened on some fujis when he googled the issue.
At 975, I figured the cosmetic issues were worth the low price. Plus it only had 350 miles (according to him). So if it was stored for the most of its life inside and had only 350 miles ridden outside, I would assume its not the weather.
Regardless, I might gander down to PB (where it was originally bought) or a LBS to see what they think.
I saw fuji's warranty and the frame has a lifetime warranty but the "finish" is only one year? What actually is covered under the lifetime warranty if there are so many exclusions?
Here are some updated photos in better light. Truly miffed on what this could be.
https://i59.tinypic.com/1g3oro.jpg
https://i62.tinypic.com/2s94t9y.jpg
https://i60.tinypic.com/1jfwz.jpg
https://i58.tinypic.com/fop3kn.jpg
https://i61.tinypic.com/211np53.jpg
The following pics are from a friends SL1 Comp. His bike uses C4 carbon compared to my C7 but not sure if that makes a difference.
As you can see, the black portions on his frame has a 12k pattern. His carbon fork also has this pattern. My fork on the other hand follows the google images of "raw UD" with the vertical lines. It doesnt have the same splotches as my frame which makes this more puzzling.
https://i60.tinypic.com/xcsqvq.jpg
https://i59.tinypic.com/2lnwn13.jpg
https://i57.tinypic.com/rtjdco.jpg
https://i61.tinypic.com/hrcug5.jpg
I find it hard to see what you're trying to point out in those photos. But if it's solely discoloration, don't worry. And UV won't destroy any composite bikes unless it was left in the sun for years. I'd only consider it if it were like a "bubble" that's growing over time. (That could be delamination)
Bikes: 14 Wilier zero7,13 Fuji Altimira SL,10 Fuji SL1RC,09 Yeti Mtb
I have almost the identical bike,it's the SL1 Race,and the carbon jut looks like carbon fiber weave under a clear coat,,,no blemishes,mines a 2010,,so I dunno?
blah blah blah
Quoted: 5 Post(s)
Maybe read this and check the picture: https://www.canyon.com/_en/supportce...articles_id=28
Here is another pic of a different frame with UD carbon:
