Appropriate Bike Shorts
Bikes: 1966 Western Flyer Cosmic Flyer, 1975 Raleigh Record, BSA 10 Speed
Quoted: 11 Post(s)
I am going to be attending a 70 mile ride on a Rail Trail. I have a '75 Raleigh Record that has been modified with more modern drive-train. I was told I need bike shorts because they are more tight fitting and thus improve circulation. I would like to get a pair of the baggy mountain bike shorts so I can have a place to put valuables (pockets), but was told they might not be the best for the longer rides. Thoughts? Any recommendations?
WALSTIB
Either should be fine. I have both kinds and mountain bike seem a little more grippy on saddle and can snag on nose of saddle when getting on or off bike. But maybe that's just me. I'd just recommend buying a nicely made pair with a good chamois.
Likes For hillyman:
Quoted: 12 Post(s)
Liked 6 Times
I have a pair of Zoic Black Market MTB shorts that I really like. They have a tight liner, to improve my circulation and lots of handy pockets.
Don't bother with cheap cycling shorts they won't last. E.g. my kids got me a pair of cheap local sports store branded shorts last Father's Day. One 35 mile ride and the chamois stitching failed. I was able to return them and use the credit towards a pair of decent Pearl Izumi shorts.
2. 35 mile days?
A baggy outer and a supportive inner is often combined in a shorts made for cycling ..
Or you can get the 2 separately if you choose.. and wear one over the other..
Likes For fietsbob:
Quoted: 169 Post(s)
Liked 84 Times
I wear lycra shorts with no padding and use leather saddles. I have done a handful of 100+ mile days in a row with that combination and mountain bike shorts (baggies). But, I'm conditioned to riding that way.
I'll never wear padded shorts ever again but that's just me.
Quoted: 18415 Post(s)
Liked 15,545 Times
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I just wear cargo shorts on long road/paved rail trail trips (usually 100+ miles). I just buy 'em cheap, and they're extremely handy because of the pockets. What I really like about them are the pockets that button so I can carry my wallet and keys at easy access without fear of them falling out while riding.
I have no idea why someone would even think tight clothing would improve circulation, that's ridiculous and would cause me not to give that person's advice in other areas much credit.
What kind of rail trail? They vary from single track rough to really wide paved paths.
They were probably thinking of some type of compression wear, I do not have any but have been tempted to try them and see what the fuss is about.
Liked 15,545 Times
https://hillcrestsouth.com/news/when...pression-socks
When I had my heart valve replacement surgery I woke up wearing TED hose because I was likely going to non-ambulatory for several days. Quite stylish, especially on a 25 Y.O. man. I was so happy that they let me take them home. So was the GF.
Quoted: 5224 Post(s)
Liked 3,581 Times
for me, it took a few tries to finally settle on my go-to setup, which I'm very happy with on all day rides
thin lined trishorts Zoic Ether Cycling Shorts (no longer available on Amazon?) hmmm, these might be close 2XU Mens Active Tri Short
unlined MTB shorts Zoic Ether Cycling Shorts
this is what they look like IRL
reg. sizing, I use size 38" waist jeans but for these units I buy XXL cuz I'm 60 & weight 230, with a little bit extra in the belly.
Tragically Ignorant
Liked 9,098 Times
Things like TED hose and compression socks are used to keep blood from pooling, so in some sense, they enhance circulation. They have different uses/purposes, however:
Tight shorts may have some benefits, but improving circulation just isn't plausible as one of them.
Liked 15,545 Times
Likes For indyfabz:
Quoted: 2952 Post(s)
Liked 3,106 Times
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
I've never felt that bike shorts do anything for circulation; the benefit is that a good chamois (not necessarily a thick or padded chamois) will help prevent saddle sores.
Tragically Ignorant
Liked 9,098 Times
Not saying you are wrong, just that they're not necessary for this for everyone.
If OP is comfortable in baggy shorts, it's not likely he's going to have problems if he increases mileage without buying expensive new clothes.
Wear whatever you want to wear based on your experience. Clothes while biking is part of the equipment and setup. Some people need or desire X while others Y. I used to wear bike shorts with a pad/chamois but over time they were causing more problems than they solved, mostly with moisture buildup and I no longer needed the padding effect for comfort. Now I wear regular athletic wicking underwear and regular shorts. Not all are the same and it took some experimenting but I know exactly what to look for now. I just did a 5 day 350 mile gravel trip, I packed a pair of road bike shorts just in case but did not need them. Again.... It depends on what works for YOU. There is no right or wrong.
Likes For u235:
Quoted: 1188 Post(s)
Liked 1,154 Times
Club Ride MTB shorts with liner, quality made clothing that looks good and works on the bike, so you can get both kinds of circulation. I'm about to wear them every day for a 2 month tour through the Balkans, so yeah they are comfortable.
Wear what is comfortable but need a good chamois which is the most important thing. I used to wear regular cycling shorts but have since switched to bibs. Never thought I would like them but won't wear anything else now.
Quoted: 1364 Post(s)
Liked 1,677 Times
+1 pockets. I wear black golf pants with pockets and a gel seat on two of my three bikes. I commute 9 miles each way 3-4 days a week with a 20-40 mile weekend ride, and a 50-60 mile ride a couple times a year including gravel. No problems.
Quoted: 2112 Post(s)
Liked 663 Times
Shorts are a personal preference, so any of mountain bike shorts or road shorts or road bibs are fine or pretty much any other shorts that you are comfortable wearing on the bike.
(I often wear football (soccer) shorts, 3/4 training pants on cooler/sunnier days, but that's just me, from my footballing days I've still got lots of perfectly good shorts and training pants and even though I've been off the pitch for a while, they work for me.)
Wear what you want to wear, but most importantly, wear what *you* are comfortable wearing, and wear you HAVE worn.
The day of your 70 mile ride is *NOT* the day to ride with a new pair of shorts for the first time, new gloves for the first time, new shoes for the first time.
It's also not the day to put on new pedals for the first time (doesn't matter if you are switching to flats, clips, or clippless), or switch out where you store your water (down tube mount, seat tube mount, triathlon mount), etc etc etc....
It's also not the day to try new foods or drinks.
Never eaten a peanut butter sandwich? Then don't. Never tried Skratch Labs products? Then don't. Never drank Gatorade? Then don't.
(But the best peanut butter sandwich I ever ate was in the rain in Marshfield Hills.)
You don't want to discover that something you ate or drank is giving you stomach cramps (or worse) while riding.
If it's a supported ride, you WILL find products you have never eaten/drank at the rest stops. Resist. But if you are tempted to try something that you've always wanted to try, you may take it, but pack it away and try it another day.
(That said, jorts are probably not the best choice for long rides.)
Good luck!
-mr. bill
Good luck!
-mr. bill
Likes For mr_bill:
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
The main point of cycle shorts is the pad which helps with saddle friction and can also help hold an anti-friction compound like chamois butt'r (put it on yourself and on the pad and bring more if its a hot day).
If you need that or not depends on you, your saddle, the distance, and the conditions. No doubt someone has done your ride in cutoff jeans.
I started out wearing cargo shorts over cycle shorts; eventually when out on more serious rides I'd take them off and just ride in the cycle shorts, as the cargo ones would get soaked with sweat and be no fun. I still wear them if I'm taking a train or something to the ride, and on rides with a longer passive train return will duck into the restroom, change to everyday undies and a dry tee shirt and wear the cargo shorts home (nothing like sitting under commuter train A/C for an hour and half after your body has shut down post exercise). Actually just bought a slightly oversize swim shorts I'll probably end up using for that pre- and post- ride purpose instead as they're thinner and should dry faster, just need to re-work the closure. Effectively that is not unlike your mountain bike shorts but in decently separable form. But MTB shorts are probably fine, unless you're rolling at roadie speeds where anything loose is annoying. (I'm unsure how the, er, support of MTB short liners compares to stand-alone bike shorts - I've tended to prefer the latter as I have to somewhat jump onto my particular cycle, but as I increasingly land on the pedals before saddle, adjustment becomes more possible)
Not having pockets does get annoying if you do something like stop at a convenience store, I actually keep meaning to rig up some kind of add-on pocket type of thing with a waistband clip for briefly keeping track of phone, wallet, etc. Traditional cycling jerseys have pockets on the back that solve this problem.
This. Test whatever you are going to wear first. Shorts are compact enough you can bring a pair and something else on a test ride; a while back I did a "brief" ride (26 miles) carrying my usual shoes because I thought a new pair I'd bought might be better; turns out they were but didn't want to waste an opportunity for an enjoyable ride if they weren't.
You don't mention what sorts of rides you've been doing recently, but it goes without saying, don't just jump into a 70 mile ride, preferably work up to it in reasonable steps. Personally I step up to the 48 mile length of my rail trail before I start planning longer trips (this spring, something like 8-17-22-24-25-33-48-48-63). A determined person with a high pain threshold may be able to just get on and painfully persist to slowly accomplish 70 miles despite no recent distance rides, but it won't be enjoyable.
Another vote for MTB shorts with padded undershorts. Done thousands of miles with this combination.
For some reason, probably my weight, the padding on regular road bike shorts doesn't adequately cover the critical areas in back. These padded undershorts from Amazon are way better.
Quoted: 930 Post(s)
Liked 393 Times
