Tire pressure
old newbie
Bikes: Specialized Roubaix
Quoted: 546 Post(s)
Liked 360 Times
Tire pressure
In tubed road tires what are the problems if the pressure is either higher or lower than what is stamped on the tire?
Wouldn’t higher pressure reduce rolling resistance and lower give a more cushioned ride?
Quoted: 8288 Post(s)
Liked 9,067 Times
You can experiment to find your ideal pressure. Too high and it will ride rough and ping off of everything. Too soft and you risk pinch flats and rim damage. Also, if it's too soft it feels squirmy to me. I prefer road bike tires around 100 psi on 25mm tires. I'm 200 pounds.
On my mountain bike I use 15 psi in the front tire and 17-20 in the rear. Those tires are 2.8 inches wide.
Likes For big john:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
For road and quality tires, I use an online tire pressure calculator.
old newbie
Quoted: 546 Post(s)
Liked 360 Times
Liked 9,067 Times
What size road tires are you using? I think 10 psi would make a noticeable difference either way. When I weighed 225 I was using 23s and I used 110 in the rear and 100 in front. You could try one of the on-line pressure calculator or just drop it a little and see if you like it. At that weight I would be most concerned about going too low.
Likes For big john:
old newbie
Quoted: 546 Post(s)
Liked 360 Times
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
Normally the pressure on the tires is the maximum. Use an online pressure calculator to start. You can drop it some but at a point you risk pinch flats. Going up will be ok for smoother roads.
Your weight and tire width are important to start. A wider tire you can run lower pressure.
Likes For biker128pedal:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Higher pressure will reduce rolling resistance on a smooth surface. On real roads, a lower pressure usually reduces rolling resistance, as it absorbs bumps (as well a giving a smoother ride).
señor miembro
Liked 6,491 Times
Likes For SurferRosa:
Liked 9,067 Times
Likes For big john:
old newbie
Quoted: 546 Post(s)
Liked 360 Times
I was curious what going to 80psi would do.
With a range like that what would the difference be between the upper and lower pressures. Are there any advantages in certain conditions?
Liked 9,067 Times
I would stay on the high side at your weight. Like I said, I don't like a squishy or vague feeling. You could lower pressure for wet roads or to increase comfort on the bumpy stuff.
old newbie
Quoted: 546 Post(s)
Liked 360 Times
I think I used the calculator correctly. It shows 85psi front and 90psi rear. I will use that tomorrow.
Likes For pepperbelly:
Tire pressure is all about trial and error. Different tires and tires sizes react differently at different pressures. This is very easy to experiment with, as your tires will gradually deflate after you fill them up to the labeled pressure. In time you can find that sweet spot where you get a good combination of comfort and rolling resistance. When it feels right, check the tire pressure, and stick with that pressure.
Likes For 50PlusCycling:
Quoted: 542 Post(s)
Liked 417 Times
When newbies ask about wanting the bestest psi for them to cycle better, it simply means they haven't cycled enough.
They need to put on more miles, and then they will figure it out.
(Bro tip: optimizing the human body is much better than optimizing anything on a cycle.)
Likes For soyabean:
old newbie
Quoted: 546 Post(s)
Liked 360 Times
This user hit it right on the nose.
señor miembro
Liked 6,491 Times
Increasing pressure tends to reduce rolling resistance because it causes you to lose less energy to deformation off the tire.
But.
Increasing pressure can increase rolling resistance if the tire becomes too stiff to serve as suspension for small surface irregularities.
Or, put another way: if increasing pressure causes the bicycle to become less comfortable, it's probably also making you slower. The energy that's being used to vibrate your hands and feet and butt is being stolen your forward motion.
For a given rider on a given surface, there tends to be an "optimal" pressure, where the tire is functioning as suspension and isn't overly squishy. Going above this pressure tends to produce larger performance penalties than going too low, so it's usually good to err on the low side.
It's possible to measure performance by using a power meter (and using methods like RChung's Virtual Elevation technique to characterize rolling resistance). But if you're not going to bother with that, a good starting place might be an online tire pressure calculator.
Likes For HTupolev:
Increasing tire pressure never decreases rolling resistance, ever. But higher pressures, besides making for a harsh ride, shrink the contact patch, decreasing traction, and increasing the chances of skidding or losing control. FWIW, I worked for some time the motorcycle division of the Pirelli tire company, and understand a little bit about the subject.
Tire pressure influences shock absorption and the size of the contact patch. Lower pressures increase yield and the size of the contact patch. A larger parch gives more traction, to a point, but also has the effect of decreasing tire circumference and deflection angle. The compression and decompression of rubber absorb energy, some of which is converted to heat, too-low pressures increase energy absorption and heat generation.
What you need to do is simply fill the tire to the sidewall pressure and ride the bike.
Over the course of a week ot two, the pressure will decrease, you will, or you should be able to feel the difference. Fill the tires again to the sidewall pressure, and ride another week or two. You’ll eventually find the particular pressure which suits you.
if you are a heavier rider, you may want to go a few psi above the sidewall pressure, but the overall process is the same. On my conventional bikes I run a little south of the sidewall pressure, on my suspension bikes, like my Moulton or Birdy, I higher than the sidewall pressure.
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 171 Post(s)
Liked 395 Times
I ride on 25mm tires with a psi max of 120. I generally ride between 105 and 110. I weigh around 190lbs which is down from a year ago at 205.
Likes For SpeedyBlueBiker:
Quoted: 4427 Post(s)
Liked 4,879 Times
Likes For PeteHski:
