ftp test
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
ftp test
a few weeks ago i've done the "effort test" to obtain the 2024 certificate to have access to the races.
During this test the doctor had a bike wich measure cadence, power, kcal etc. Basically was one of those bikes you can find at the gym.
Since my brother in law has a gym with almost the same bikes, i would like to know how to replicate this watt measure.
The doctor was adding 25watts every amount of time (wich i suppose depends on the bike itself).
To make the exactly watt measurement should i start from x amount of watts and then increase the resistance effect every minute until i do not have more energy.
is this correct?
is this correct?
Quoted: 4428 Post(s)
Liked 4,879 Times
This is called a ramp test. A typical protocol is to warm up and then increase wattage by 20W steps every minute until you eventually fail. Your FTP is then estimated as 75% of the max power you achieved in the ramp. The starting wattage for the ramp is not that important as long as it is relatively easy.
Edit: The gym bike might well have a built-in ramp test program. Worth a look.
Quoted: 333 Post(s)
Liked 168 Times
Liked 4,879 Times
Yes, if it has ERG mode that you can adjust power to set targets. Then just follow the ramp protocol with manual 20W power steps every minute. Make sure you do a good warm-up before starting the ramp.
Likes For PeteHski:
Anyway, the estimate of 1 hour power from the ramp is to use a range of 72 - 77 % of the best 60-secs of the ramp test.
Likes For RChung:
gawd, i was youngish then. Thanks Robert.
It was weird, i started collecting power data in 1994 (i was 25 then) but wasn't overly sure what exactly it meant. I turned up to Uni (to do a degree in sports science in 1995) and it literally took a month for it all to come together. I remember riding a "Kingcycle" (there's something to google) at 200 W and proclaiming that this was about the average power of a road race (which caused raucous laughing, as everyone said it was way harder than that). Turns out that many of the road races i do are less than 200 W (and it's simply the stochastic nature that make them hard). i then started collecting data on other riders (gawd this was before stuff was downloadable) and worked out power curves and estimated powers from a ramp test for all sorts of durations. Happy days!
Likes For Ric Stern:
i thought you might and just mentioned you in a post (i only just joined ****** this week). Also mentioned Andy C as well - i have an inkling he may hang out there under a pseudonym (as i saw some text that looked like Andy). I'm on as RicCycleCoach .
Likes For RChung:
