Custom for this Clydesdale
Bikes: Custom Zinn Dolomite Ti
Hi
After many years of drooling over a custom built Zinn - I finally own one.
I wrote a review of it for a local cycling site here in NZ - which gives the full details...
https://roadcycling.co.nz/GearTalk/pr...xperience.html
A few weeks on from that - I still can't say enough about it.
If you want to go faster - and you're tall - then have a good look at this.
Cheers
Adrian.
Cheers
Adrian.
6'7" and 275lbs. It's got custom built 210mm cranks that mean I can finally use my long levers to full effect. It's meant a huge jump in performance. The bottom bracket is built higher off the ground to accommodate the long cranks.
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Cool! Nice bike, but glad I'm a shorty at 6'1. That would be way out of my league and budget!
Quoted: 137 Post(s)
Liked 81 Times
As long as you've got a custom road bike I wonder if you considered a 26" wheeled sport/tour road bike? It would be one way to compensate for the higher bb as the slightly smaller wheels feel a smidge more sure footed with a lower wheel center and the 1.5" tire has LOTS of stick on the ashphalt. I got one made up years ago and although it's not an improvement for speed/hill climbing the 1.5" tires are good for worry free smashing through holes and no loss at average 14-18mph riding speeds.
Nice bike. I'm kicking myself a little for not getting a custom frame that allows longer cranks.
Last edited by shmily_dana; 01-05-10 at 05:05 PM. Reason: rewrote post after reading attached article
Bikezilla
Bikes: Co-Motion Mazama
Super! I looked into Zinn when I was searching for a custom, but they were a bit pricey. I went with a Co-Motion and I have no regrets. Happy riding fellow tall dude!
Thanks Mazama. Nice looking bike!
thirdgenbird: The cranks are custom built for Zinn. Proportional length cranks are a key part of his design philosophy. As to the fork it's an Alpha Q Z-pro fork that they use on all their Project Big bikes. I don't really have anything to compare it with other than my old steel forks which flexed like crazy. All I know is that I was reluctant to stand and sprint on my old bikes because of fork flex - and I'm not now - although I'm having to teach myself this as sitting to sprint had become a habit. I don't know what it's like compared to other carbon forks as I've never used any.
Here's the blub though - which may help...
The special Alpha Q full-carbon Z-pro fork features a 450mm steering tube – way beyond the industry standard 300mm (or, if you are lucky, 350mm)!
The super-long carbon steerer is also super-stiff. It is 1-1/8” in diameter, and its 4mm wall thickness is far greater than that of most full-carbon forks, including other True-Temper AlphaQ models. This, combined with the patented AlphaQ Carbon Rooting™ technology reinforcing the steering tube and crown, not only makes for a stronger fork, but the difference in stiffness is what is particularly noticeable for a tall rider. When you have a long steering tube inside of a tall bike, there is actually quite a bit of flex that you cannot see – flex of the steering tube inside of the frame’s head tube. This fork’s super-stout steering tube minimizes that.
I've posted some more photos of my bike here...
https://www.bikeforums.net/showthread...taniums/page51
(you might need to scroll down to see them.)
TPR950H
0
08-20-10 03:55 PM
