Should I use flat-bar or TT brake levers on bullhorn bar?
Quoted: 128 Post(s)
Liked 12 Times
I'm switching to bullhorn bars on my commuter, and am curious about people's preferences for brake lever type.
My bullhorn bars have a horizontal straight section, so I'll have hand positions equivalent to bar-tops and brake-hoods on a drop bar. I could use interrupter levers on the flats, and/or TT levers to brake from the hands-forward position. Pics below show bullhorn set up with each type of lever.
The bike is a singlespeed, so no interactions with where to place shifters.
I haven't used a bullhorn bar before. I'm used to braking from the hoods while on a drop bar, and braking from the flats on a flat bar with old mtb bar-ends (setup on a prev commuter, and my singlespeed mtb).
I'm mostly curious to hear about people's experiences and preferences with where to place brake levers. And of course I could do both (since I'd be using interrupter levers on the flat part anyway) but that's some extra setup hassle.
Quoted: 7348 Post(s)
Liked 2,470 Times
Maybe you should try both. It's a small investment considering the usage you'll get out of the setup.
You get more braking power if you can shift your body weight backwards on the bike, so if you have to choose, maybe you want the levers closer to the saddle. Then again, on fast descents, you want maximum control and don't necessarily need maximum braking, meaning you'd want the levers forward.
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Flat bar with flat bar levers and bar ends.
Brake levers located as lateral as possible on the flat bar. For maximum braking power and steering torque.
Position 2 is my general purpose position. I can move to 1 and 3 easily from here.
Position 3 is for cruising.
Position 1 is for hard braking and turning.
4 and 5 are alternate positions. Seldom used.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Have you checked which levers fit the bar?
MTB, City bikes, cruisers, three speeds, etc, usually have a 7/8” bar (22.2 mm). Drop bars and other road bike shapes are usually 15/16” (23.8 mm). It's maddening, but there's a long tradition for it.
Anyway, your bullhorn bar is probably 23.8 mm and you probably can't use MTB levers.
incazzare.
In my experience most casual riders are on the flats most of the time and use the interrupter levers.
I'm not 100% sure about how the TT levers are cabled, but you may be able to use both at the same time if you wanted.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Looks like the TT levers might give you more control when braking. Personally, I don't like the feeling of having my hands on the tops too close to the stem. And since I'm offerring my personal opinion, both setups are ugly. Sorry.
Liked 2,470 Times
There is a certain appeal to having an ugly commuter bike. Sometimes I want mine to be as ugly as possible.
Quoted: 943 Post(s)
Liked 172 Times
Likes For robertorolfo:
Should you be compelled to do what this forum says .. ?
If the Reverse lever has a housing run under the tape , You can use Both.. '
In Fact You are using the mid bar Brake lever more as intended if running the cable uninterrupted , through the lever
and spreading the 2 sections of housing apart to apply the brake ..
Quoted: 128 Post(s)
Liked 12 Times
Interrupter levers (as pictured in my OP) fit on 23.8mm bars, and are what I would put on the flat portion of this bar.
This would allow me to run both brake levers simultaneously if I want.
If you have experience with bullhorn bars, where do you prefer brake levers, and why?
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Shimano makes a group set called Metrea that includes bullhorn brifters. They don’t market it in the States but you can find it from EU sites. Might be fun to try.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
For my commuter bike, I'm more upright, so I use the interrupter levers. I'm mostly on the horns when accelerating hard from a stop.
For my track bike, I'm more aero, riding faster/harder and riding out on the horns, so I use the TT levers.
It all depends where your hands are going to spend most of their time.
I don't use your chosen bull horn* bar, but I did get 23.8 clamp levers to fit on my C X bikes drop bars ,
there they shoulder up against the center sleeve of Nitto made bars..
I did use a bullhorn aero bar combination, a bent single tube type , 30+ years ago, but only had the reverse levers in the ends..
interrupter levers did not exist, back then..
So, used both , but not on the same bike ..
Quoted: 128 Post(s)
Liked 12 Times
I've done both (riding fixed gear)
I'll probably put interrupter levers on first and ride for a couple weeks without wrapping the bars with tape (it's gloves season anyway) and see if I find myself wanting the levers for hands in the forward position.
I converted a MTB bike to bulhorns so used a 22.2mm bar to fit the stem and brakes (wanted cheap so saved on new levers). I used the flat bar brakes positioned on the horns. They may not look great but they work just fine (I don't like the idea of having them by the stem...would feel weird). I'm tempted to upgrade but haven't seen a reason to.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I rode bullhorn bars for a few years, and always preferred the TT levers (I did not use interrupters), as in the second picture. Having come from drop bars, I found that the most comfortable hand position was forward; I never really used the flat part of the bar.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
I've had both on my daily commuter. I started with regular Origin 8 bullhorns, with a rack on the rear of the bike, then I ditched the rack for aesthetic reasons, and also switched out the regular bulls to Origin 8 pursuit bars - similar, but different.
My bullhorns had TT bar-end levers, and the pursuit bars had the flat-bar style breaks.
To be perfectly honest, neither was perfect.
On my bullhorns, when I needed to break I had to lean forward a lot more - and this was uncomfortable sometimes when slowing for an intersection - and was harder for immediacy. I liked to ride on the forward bend, or between that and the end of the horn.
On the pursuit bards, I liked to ride about the same positions - but the brakes were too close to the stem, making it hard to hang on when track standing at a light or stop sign - and getting going again was awkward because the grip stances was so narrow (I think someone mentioned that already.
Anyway, I think my TT bar-end levers would have worked better if I had found a better set of bullhorns that weren't as long. The Origin8 ones had a long reach - but they were all I could find/afford at the time. I enjoyed them though, and they looked good. I now have regular drop bars & brake hoods/levers on it now. I find it suits my needs just right.
Here's some pics of the iterations:
Current setup:
Current setup:
I'm very tempted to give bullhorns a shot just for something different.
Liked 2,470 Times
I've had them and liked them a lot. I like variation in reach but don't need variation in drop, as bending down is hard for me. I'm even tempted to put them on my road racing bike, which might make it ugly but comfortable.
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times
I am biased towards flat bar style shifters, mainly because I like the integrated brake/shifter combo and long pull leverage. My hand position is near the elbows and I brake with my middle,index, and pinky fingers from the underside of the bars. I tried the tektro reverse brake levers, but didn't like them as much and the reach was a little too far for me.
mozad655
Bicycle Mechanics
16
06-21-15 09:04 PM
o.p.mickey
Singlespeed & Fixed Gear
51
07-24-10 05:24 PM
